Salt Tank Differential Equation
The discussion revolves around solving a salt tank differential equation involving a tank with 100 kg of salt and 2000 L of water. The initial concentration of salt in the tank is calculated to be 0.05 kg/L, while the concentration approaches 0.025 kg/L as time approaches infinity. The main challenge presented is determining the amount of salt in the tank after 4.5 hours, which requires setting up a differential equation based on the rate of change of salt in and out of the tank.
  • Understanding of differential equations
  • Knowledge of concentration calculations
  • Familiarity with flow rates in fluid dynamics
  • Basic skills in setting up and solving word problems
  • Study the method for solving first-order linear differential equations
  • Learn about the concept of mixing problems in calculus
  • Explore the application of initial value problems in differential equations
  • Practice similar problems involving concentration and flow rates
This discussion is beneficial for students studying calculus, particularly those focusing on differential equations, as well as educators and tutors seeking to enhance their understanding of mixing problems in fluid dynamics.
Puk3s
Ok so this is the question
A tank contains 100 kg of salt and 2000 L of water. A solution of a concentration 0.025 kg of salt per liter enters a tank at the rate 5 L/min. The solution is mixed and drains from the tank at the same rate.
A.What is the concentration of our solution in the tank initially
B.Find the amount of salt in the tank after 4.5 hours
C.Find the concentration of salt in the solution in the tank as time approaches infinity.
I found A to be .05 and C to be .025. But I'm not sure how to get B... I know I have to set up an equation but I'm not very good at these word problems and could use some help setting up the equation and answering B so any help would be great!
Thanks!
Rate of change of salt in tank = amount of salt in/min - amount of salt out/min
For the amount of salt in, just plug in the values you are given
[tex]Concentration * flowrate = \frac{.025kg}{L}\left(\frac{5L}{min}\right)[/tex]
For salt out, the concentration will depend on t. More explicitly, since concentration is
kg/L, and the number of liters will never change (since the rate of flow in and the rate of flow out are the same), the amount of salt will change with time.
