Harvesting energy from walking humans
  • Context: Undergrad
  • Thread starter Thread starter WilliamE.
    Energy Harvesting
The discussion revolves around the feasibility of harvesting energy from human walking, specifically through the use of devices integrated into footwear that could convert mechanical energy into stored electrical energy. Participants explore various theoretical and practical aspects of this concept, including energy output estimates and the efficiency of potential designs.
  • One participant suggests a device that compresses a spring in shoes to store energy, questioning how much energy could realistically be harvested per step.
  • Another participant calculates work based on weight and step frequency, proposing a range of 10-100W of power output, while noting that 100W may be excessive.
  • Concerns are raised about the practicality of energy extraction, with one participant stating that excessive energy extraction could hinder walking efficiency.
  • Discussion includes references to existing research, such as MIT's work on wearable energy harvesting devices, which reports varying power outputs depending on design and conditions.
  • Some participants provide estimates of energy expenditure for walking, with calculations of joules and calories, but there is confusion regarding the time frame for these energy values.
  • One participant humorously questions the additional food costs associated with increased energy expenditure from walking with energy-harvesting devices.
Participants express a range of estimates and opinions regarding the potential energy output from walking, with no clear consensus on the feasibility or efficiency of energy harvesting devices. Disagreements arise over calculations and assumptions related to energy expenditure and mechanical efficiency.
Participants highlight the complexity of accurately measuring energy output and the efficiency of energy harvesting systems, noting that practical devices may capture only a fraction of the energy expended during walking. There are also discussions about the metabolic costs associated with energy expenditure that complicate the calculations.
This discussion may be of interest to engineers, product designers, and researchers focused on energy harvesting technologies, as well as individuals interested in the intersection of biomechanics and renewable energy solutions.
WilliamE.
So, this may sound like a homework question but I promise it's not.
How much energy do you think could be harvested per human step? For instance, if you had "buttons" in the bottom of shoes which compressed a spring and somehow moved that energy to some sort of energy storage device, how much could be stored, do you think (using whatever you think are realistic numbers).
I am asking this for this sort of product idea competition. My thought is that something could be attached to the bottom of a shoe which could be used to generate energy when it's wearer walked. From the sound of it, it should seem like an obviously bad idea due to what energy actually costs, and what such a device must at minimum cost, but I'm just trying to throw some sort of idea out there.
Thanks.
Science news on Phys.org
Thanks.
Welcome to the PF.
Here is some introductory reading for you, with links to other information sources:
http://en.wikipedia.org/wiki/Energy_harvesting
Work is force times distance, so if you weigh 150lb, take two steps per second and compress a piston 1" each time, how many ft-lb of work could you do per second?
You measure work in ft-lb? Even if you insist on (middle-north) American units, just type the numbers into google..
Hence, I estimate anywhere from 10-100W of power. Still, might be a plausible way of keeping something like a netbook charged in certain circumstances. In fact there exist areas of the world where I think you'd have a market for a phone charger on this principle, depending on the technology of the button.
It would be like constantly walking up stairs. In the developed world there's probably a place for this kind of thing, just because we are generally so lacking in exercise. And we already eat too much (i.e., more calories than we use, and afterward our nutrient saturated waste streams tend to remain a liability rather than a resource) so by harnessing some of this excess energy from our decadent diets we would be getting this power for free (or for negative cost accounting for health benefits).
Thats about about 16micro furlong-firkins if you want it in real units
Probably nearer 10W, 100W is quite a lot of effort.
A decent competition cyclist can sustain 250W over long periods.
ft-lb was the first thing that occurred to me - you can also do a 2.5 cm compression and 70 kg if you like...though that was meant more for the OP to solve...
...and calculating the number, regardless of the units, is better than pulling it out of thin air.
You can't extract too much energy from walking or it would become very difficult to walk (ain't no such thing as a free lunch)
The reason you can walk easily is that you recover a lot of the energy in each step from the springs in your tendons (and slightly from the rubber soles in your shoes)
A system that extracts lots of energy would be like walking in soft sand or mud - or on those stepper things at the gym where your foot drops away from under you.
is that intentionally omitting a factor of acceleration then?
There's been quite a bit work on this beginning I believe with MIT's wearable computer work. We have a prototype device here, and the Army has been paying attention for years - anything to help with their exploding battery and battery life problem.
MIT Media Lab came up with a working maximum power of ~67W (68kg, 5cm vertical movement, 2Hz), but concedes an 'unobtrusive' maximum power of only about 1W (enough to keep cell phone going all day w/ an hour per day walking), and working models so far obtaining mW ranges. Piezoelectrics seem to be the leading candidate for the most unobtrusive, and miniature magnetic generators for the most power (tens of mW).
http://www.rst2.edu/njheps/resources/energy_scavenging.pdf
How much extra food is this going to cost me? :p
If you have to work too hard whilst walking around the office, you will work up a lather and need a shower - there goes any net energy savings. You can't win, you know.
You can get enough energy to wind a wristwatch, without bothering the wearer.
Yeah, 100 Watts is asking too much. It would be a major effort making the round trip from couch to frig.
A 70 kg person walking at a speed of 5 kmph uses 1300 joules of energy. Practical machines however might be able to capture only a small amount of that energy.
How did you calculate that? And 1300 joules of energy in how much time? A second? An hour?
Check your figures. Only power, Watts, makes sense in that statement without a time limit.
Oh sorry for that, I forgot to write the time period which is 60 minutes. Walking at that speed a person of that weight on average in 1 hour uses approx 290-300 calories which is approximately 1300 joules.
1300J/hour = 0.35W - I think you might have missed a factor somewhere, do you mean kilocalories?
One website is devoted to pop-up adds but features a "Calories Burned Calculator". It tells me a 150 lb person walking for one hr. at 3 mph burns 297 dietary calories (297 kilocalories).
A lot of the weight-loss guides to how much energy you use also include metabolic losses - ie. the power converted into heat as you get hot and sweaty.
Ussualy by just assuming you are say 25% efficent and so giving you a calories/hour that is 4x the mechanical work done.
It's tricky to capture this so you shouldn't really include it in the useful work done calculation.
  • · Replies 26 ·
  • · Replies 41 ·
