How Do You Calculate the Coefficient of Static Friction on an Inclined Plane?
  • Thread starter Thread starter Hypnos_16
    Push Sliding
The coefficient of static friction between a 220-kg crate and an inclined plane at an angle of 18.3° is calculated to be 0.534. A horizontal force of 501 N is required to initiate movement down the incline. The calculations involve breaking down forces into components, specifically using the sine and cosine functions for the angle provided. The final equation used to determine the coefficient of static friction is derived from the balance of forces acting on the crate.
  • Understanding of Newton's laws of motion
  • Knowledge of trigonometric functions (sine and cosine)
  • Familiarity with static friction concepts
  • Basic algebra for solving equations
  • Study the principles of inclined planes in physics
  • Learn how to resolve forces into components using trigonometry
  • Explore the calculation of coefficients of friction in different scenarios
  • Investigate the effects of mass and angle on static friction
Students in physics, engineers working on mechanics, and anyone interested in understanding the dynamics of forces on inclined surfaces.
Hypnos_16
A 220-kg crate rests on a surface that is inclined above the horizontal at an angle of 18.3°. A horizontal force (magnitude = 501 N and parallel to the ground, not the incline) is required to start the crate moving down the incline. What is the coefficient of static friction between the crate and the incline?
The only real problem I'm having with this one is that i seem to have two variables
so far i have
Fnet = ma
mgsin18.3 + 501 x cos18.3 - Umgcos18.3 = ma
(220 x 9.8 x sin18.3) + (501 x cos18.3) - (U x 220 x 9.8 x cos18.3) = 220a
677 + 475.7 - U2046 = 220a
1142.7 - U2046 = 220a
though i don't even know if that's right, the cosine and sine sometimes mixes me up.
Since the applied force is horizantal, you can use the angle they give you to break it up into components. The force of the push going down the ramp plus the force of gravity down the ramp must equal the force of friction. Using that and the normal force, which you can find, you can find the coefficient of static friction.
sooo
677 + 475.7 = 1152.7
Ff = UFn
1152.7 = (9.81 x 220)u
1152.7 = 2156u
u = 0.534
like that??
