Unique Factorization: Proving for Polynomials in x
  • Context: Graduate
  • Thread starter Thread starter stoolie77
    Factorization
The discussion revolves around the unique factorization of polynomials in one variable with integer coefficients, specifically within the context of abstract algebra. Participants explore the proof of unique factorization, referencing concepts such as the Euclidean algorithm and the content of polynomials.
  • Omar initiates the discussion by asking for a proof of unique factorization for polynomials in x with integer coefficients, suggesting that the Euclidean algorithm applies using "degree" instead of "norm."
  • Brim expresses interest in seeing a solution to the problem posed by Omar.
  • Roy asserts that the unique factorization of Z[X] is attributed to Gauss and mentions that this proof is commonly found in abstract algebra texts, noting that Z[X] is not a Euclidean domain.
  • Roy introduces the concept of "content" of a polynomial as the GCD of its coefficients and suggests that proving the content of a product is the product of the contents is crucial for the proof.
  • Omar expresses confusion regarding Roy's explanation and requests clarification on how to relate the concepts to the unique factorization of polynomials in Z[x].
  • Roy clarifies that Z[x] refers to the ring of polynomials with integer coefficients and reiterates that the proof relies on the unique factorization of Q[x], where Q is the set of rational numbers.
  • Roy offers specific references from his webpage for further reading on the proof of unique factorization in Z[x].
  • Roy concludes by stating that using the ideas discussed, one can prove that Q[x] is a unique factorization domain, which allows for the deduction of the same for Z[x].
Participants express varying levels of understanding regarding the proof of unique factorization, with some agreeing on the foundational concepts while others seek clarification. The discussion does not reach a consensus on the proof itself, and multiple viewpoints on the explanation and its implications remain.
Some participants express confusion over the definitions and concepts involved, particularly regarding the relationship between the content of polynomials and unique factorization. There are references to specific pages and sections in literature that may not be universally accessible or clear to all participants.
stoolie77
Hello everybody. I had been reading up on Unique Factorization again and I came across an interesting question.
Can someone prove unique factorization for the set of polynomials in [itex]x[/itex], with integer coefficients?
From what I understand, the analogous Euclidean algorithm works for such polynomials using "degree" instead of "norm".
If someone could answer this, that would be great as it might clear up some of my other thoughts I have with Unique Factorization.
Gracias - Omar
Can anyone post a solution to this? I would like to see this as well. --Brim
Gracias - Omar
see the book by Ireland and Rosen "A Classical Introduction to Modern Number Theory" 2nd edition pp 6-8
I don't know exactly where to find page 7 and 8, but here is page 6. I still don't know how to relate it directly in terms that aren't advanced as this.
the fact that Z[X] is a ufd is due to gauss. this proof should appear in every abstract algebra book, e.g. in most of the free ones on my web page.
it is NOT a euclidean domain however. the crucial concept is tod efine the "content" o=f a polynomial as the gcd of the coefficients, then prove the content of a product is the product of the contents. then one can reduce the proof to the case of Q[X].
Hello Roy, I reviewed your webpage although I didn't find any free sources that gave a lot of insight on this, and I didn't entirely make sense of your response. I know that you were using Z[x] as a UFD, however I'm trying to prove unique factorization for the set of polynomials in [itex]x[/itex] with integer coefficients. You talk about defining the "content" of a polynomial as the GCD of its coefficients, then proving the content of a product is the product of its contents. I'm totally lost with what you're saying.
Z[x] is my notation for the ring of polynomials in one variable x with integer coefficients. The proof this is a ufd is what I thought you wanted. this is due to gauss, and is reduced down to the case of assuming that Q[x] is a ufd, where Q is the rational numbers.
let me give you specific refernces to my web page.
math 844.1, section 4, page 18. that Z[x] is a ufd is specifically proved in detail.
math 80006b,pages 19-24, more terse than above.
the last two sections on my math 4000 notes also discuss the ideas. In particular they discuss the fact that Q[x] is a principal ideal domain, hence also a unique factorization domain, using the concept of degree as euclidean norm. Moreover they prove that any element of Z[x] that factors in Q[x] already factors in Z[x], the main step to proving that Z[x] is a ufd, "Gauss lemma."so indeed this topic is discussed in most of the notes there.
If you use the idea you mentioned, you can prove that Q[x] is a ufd. Then the attached notes (extracted from my web page) allow you to deduce it for Z[x], as gauss did.
  • · Replies 24 ·
