Thermodynamic analysis of a simplified PWR plant.
The discussion revolves around the thermodynamic analysis of a simplified Pressurized Water Reactor (PWR) plant, focusing on various calculations and concepts related to the plant's efficiency and flow rates. Participants are addressing specific homework problems related to the cycle's thermal efficiency, the ratio of primary to secondary flow rates, and the implications of pump efficiency.
  • Homework-related
  • One participant requests assistance with several calculations related to the PWR plant, including drawing a temperature-entropy diagram and computing various efficiencies.
  • Another participant suggests that the original poster should provide their work and specify what they are struggling with to receive better help.
  • A participant expresses confusion about how the presence of a pump in the primary system affects the cycle thermal efficiency and the nuclear plant thermodynamic efficiency.
  • One participant notes that energy leaving the primary system must be transferred to the secondary system, indicating that the specific enthalpy changes may differ between the two systems.
  • There are inquiries regarding the source material for the problems being discussed.
  • A participant identifies the book "Nuclear Systems I - Thermal Hydraulic Fundamentals" by Todreas as the source of the problems.
Participants generally agree on the need for clarification and assistance with the homework problems, but there is no consensus on the specific implications of the pump's presence on the efficiencies discussed.
The discussion lacks detailed assumptions regarding the specific conditions of the PWR plant and the definitions of efficiency being used. There are also unresolved mathematical steps related to the calculations requested.
This discussion may be useful for students studying nuclear engineering, thermodynamics, or those interested in the operational principles of PWR plants.
marlh
Can you help me solution:
The PWR plant of Figure 6-6 operates under the conditions given in Table 6-6. Assume that the turbine and pump have isentropic effciencies of 85%.
1. Draw the temperature-entropy (T-s) diagram for this cycle .
2. Compute the ratio ,of the primary to secondary fow rates.
3. Compute the nuclear plant thermodynamic efciency.
4. Compute the cycle thermal efciency .
Figure 6-6:
Table 6-6:
You should post this in the homework help section, and you need to start by showing your work, what you have attempted so far, and what you are having trouble with.
Thank QuantumPion comments! I think it is one of the problems of a nuclear engineer working with thermodynamics. My problem is "Compute the ratio ,of the primary to secondary fow rates" with pump of the primary. How change the cycle thermal efciency and the nuclear plant thermodynamic efciency when have this pump and haven't this pump.
Whatever energy leaves the primary system must go to the secondary system.
The changes in specific enthalpies of the primary and secondary coolants do not have to be the same.
What is the name of the book?
"Nuclear Systems I - Thermal Hydraulic Fundamentals" - Todreas
  • Poll Poll
