Solving First-Order Linear Differential Equations with Eigenvectors
The forum discussion focuses on solving a system of first-order linear differential equations using eigenvectors and eigenvalues, as outlined in 'Elementary Linear Algebra' by Larson and Falvo. The equations provided are (y1)' = (y1) - 4(y2) and (y2)' = 2(y2), leading to the matrix A = [1 -4; 0 2]. The eigenvalues calculated are λ = 1 and λ = 2, resulting in eigenvectors [0; 1] and [1; -4], respectively. The user encountered difficulties in computing the inverse of matrix P and applying the transformation PAP^-1, which led to incorrect results compared to the book's solution.
  • Understanding of first-order linear differential equations
  • Familiarity with eigenvalues and eigenvectors
  • Knowledge of matrix operations, including multiplication and inversion
  • Basic concepts from linear algebra as presented in 'Elementary Linear Algebra' by Larson and Falvo
  • Review the process of calculating eigenvalues and eigenvectors in linear algebra
  • Learn about matrix inversion techniques and their applications
  • Study the method of solving differential equations using the matrix exponential
  • Explore additional examples of first-order linear differential equations for practice
Students studying differential equations, educators teaching linear algebra, and anyone seeking to deepen their understanding of eigenvalue problems in mathematical contexts.
RET80
solve the system of first-order linear differential equations:
(y2)' = 2(y2)
using the equation:
(λI -A)x = 0
in the book 'Elementary Linear Algebra' by Larson and Falvo - Section 7.4 #19
(y2)' = 2(y2)
makes the matrix:
[1 -4]
[0 2]
(λI-A)x = 0
[λ-1 4]
[0 λ-2]
which gives the eiganvalues:
(λ-1)(λ-2)
λ = 1
λ = 2
then input it back into the original matrix A:
λ = 1
(1I - A) =
[0 4]
[0 -1]
which reduces to:
[0 0]
[0 1]
and creates the eiganvector:
[0]
[1]
then continued onto:
λ = 2
(2I - A) =
[1 4]
[0 0]
which creates the eigenvector:
[1]
[-4]
so then I put the two eigenvectors together and create P:
[1 1]
[0 -4]
then I need to find P^-1 so that I may use PAP^-1 to find the differential equation:
I set P equal to the identity matrix and solve (I think this is where things start to go wrong...)
[1 1/4]
[0 -1/4]
then I solve for PAP^-1
[1 1] [1 -4] [1 1/4]
[0 -4] [0 2] [0 -1/4]
I take AP^-1 first in the multiplication and get:
[1 5/4]
[0 1/2]
and then add on P and get:
[1 7/4]
[0 2]
and that just looks wrong, I stopped there in fear of continuing further, but the answer IN THE BOOK reads:
(y1) = (C1)e^t - 4(C2)e^2t
(y2) = (C2)e^2t
and it looks like if I were to continue it would not even come close to that answer...Where did I go wrong?
You calculated the eigenvectors incorrectly.
  • · Replies 18 ·
