How are the Real Numbers distributed?
The discussion centers on the distribution of real numbers and the implications for probability. It establishes that a uniform distribution across all real numbers is impossible, as the integral of a constant function over the entire real line does not equal one. The probability of a random variable X falling within any finite interval [a,b] is conclusively zero, while the probability of X being in the intervals [a,∞) or (-∞,a] is 50%. The conversation highlights the flexibility of defining probability density functions based on specific requirements.
  • Understanding of probability theory and random variables
  • Familiarity with probability density functions (PDFs)
  • Knowledge of integration and its properties
  • Concept of uniform distribution and its limitations
  • Research the properties of probability density functions (PDFs)
  • Study the implications of the Central Limit Theorem on distributions
  • Learn about Lebesgue integration and its application in probability
  • Explore different types of distributions, including normal and exponential distributions
Mathematicians, statisticians, data scientists, and anyone interested in understanding the complexities of probability distributions and their applications in real-world scenarios.
HyperbolicMan
Question: What is the probability that a random variable X with domain all real numbers will take a value in the closed interval [a,b]?
It seems to me that in order to answer this question you have to know how the real numbers are distributed. Given the appropriate distribution function, you can integrate it from a to b to find the probability.
Common sense says that the real numbers should have a constant distribution (e.g. P(x)=c for all x). However, the integral of any constant function from -[tex]\infty[/tex] to [tex]\infty[/tex] is not 1.
So how exactly are the real numbers distributed?
I am pretty sure that for any finite numbers a and b, the chance that x is in [a,b] is zero.
For any finite number a, the chance that x is in [a,infinity) is 50%. The same with (-infinity,a]
They are distributed how you want them to be. A set does not have an intrinsic distribution. For instance you may define a probability density function p(t) by p(t) = 1/2 for t in [1,3] and p(t)=0 otherwise.
If what you want is a uniform distribution, then no such thing can exist on the real numbers for the reason you mentioned (that if p(x) =c for all x, then [itex]\int_{-\infty}^\infty p(x) dx[/itex] is 0 or [itex]\infty[/itex] depending on whether c =0 or c>0, but never 1).
  • · Replies 31 ·
