Momentum and Collisions: Solving for Post-Collision Velocities
  • Thread starter Thread starter Giggling
    Momentum
The discussion focuses on solving post-collision velocities and forces in various physics scenarios. The first problem involves calculating the combined velocity of Joe, Mike, and the sled after their collision, with guidance to treat them as a single system. The second problem confirms the calculated velocity of the 3 kg cart before collision as 6.7 m/s. For the third problem, participants are advised to apply Newton's second law to find the force exerted on the football. The conversation emphasizes using momentum principles and encourages applying consistent methods across different collision scenarios.
Giggling
1. Joe is sledding down a snow hill when he collides with Mike half way down the hill. Joe and the sled have a mass of 65 kg and their velocity before the collision was 12 m/s. If Mike has a mass of 55 kg, what velocity would Joe, Mike, and the sled have after the collision?
2. A 3 kg cart is moving along when it strikes a 2 kg cart (initially at rest). The velocity of the two-cart combination after the collision is 4 m/s. Calculate the velocity of the 3 kg cart before the collision.
3. Tyler is standing at the 10-yard line waiting to catch the initial kick-off. The .75 kg football experiences a change in velocity of 12 m/s in .17 s when caught by Tyler. What force does Tyler apply on the football?
P = mv
I = F * (change in time) = m(final velocity)- m(initial velocity)
1. I know that.. mass 1 = 65 kg, mass 2 = 55 kg, velocity 1 = 12 m/s
But I don't know what equation to use.. Or what needs to be found.
2. I got 6.7 m/s, I am not sure if it's correct
(3kg * velocity 1) + (2kg * 0 m/s) = (3kg * 4m/s) + (2kg * 4m/s)
3. No idea.. But I did find that the change in time is .17 s and the mass is .75 kg and I think the final velocity is 12m/s. But I don't know what equation must be used.
Welcome to PF!
Hi Giggling! Welcome to PF! :wink:
Your 2. is correct. :smile:
Now do 1. exactly the same way … you can assume that the two sleds carry on together just like the two carts.
For 3., you need to apply the full version of good ol' Newton's second law … force = rate of change of momentum :wink:
for 1) don't worry about the fact that then are moving on an incline ... you can always take your X axis as you need!
