Dynamical Qualities and the Informational Paradigm
  • Context: Graduate
  • Thread starter Thread starter ZachHerbert
The discussion centers around the concept of dynamical qualities, particularly "fundamental charges," and their viability as primitive concepts in physics as the field transitions towards an informational paradigm. Participants explore the implications of this shift, referencing philosophical perspectives and contemporary theories such as black hole thermodynamics and the holographic principle.
  • One participant questions whether dynamical qualities can remain primitive concepts in light of the shift to an informational paradigm, citing Max Jammer's work on mass and its implications for understanding charge.
  • Another participant seeks clarification on the definition of dynamics, discussing its historical context and its relationship to motion and forces.
  • A later reply affirms the broad use of the term dynamics, suggesting that a unified theory should integrate both kinematics and dynamics, treating particles and their qualities as emergent phenomena.
  • One participant proposes that if particles are not fundamental, waves might be considered fundamental, prompting a discussion on the fundamental properties of wave propagation across different media.
  • Another participant expresses skepticism about the initial premise, questioning the credibility of Max Jammer's arguments.
Participants express a range of views, with some agreeing on the emergent nature of particles and their dynamical qualities, while others challenge the foundational premises of the discussion. The conversation remains unresolved with multiple competing perspectives presented.
The discussion involves complex philosophical and theoretical considerations, with references to various interpretations of dynamics and the implications of treating particles as emergent. There are unresolved assumptions regarding the definitions and implications of fundamental concepts in physics.
  • #31
Some of this has to be a language problem, because Jammer’s point is so simple as to not even be worth arguing over. So let me define some terms as I am using them. (And if someone wants to tell me an alternate, more appropriate term, I’m happy to use it.)
When I say Primitive, I mean a “fundamental unit of measure” - like “centimeter” and “second.” Or, more specifically, I mean class of unit. (So “centimeter” and “mile” are equally fundamental and are really just faces of the same underlying primitive: “space.”)
Now, if I ask everyone to rebuild the Standard Model without any other units at all, I’m assuming that it can’t be done. That means you get to have distance and duration, and that’s it. No charge. No spin. No color. No energy. No electron mass. No nothing. Just distance and duration. The request isn’t just impossible, it’s nonsensical.
Even if we adopted a dualistic ontology, and said that particles were little point-like lumps of "stuff" floating through a void, all we could do with units of space and time is to describe the motions of the particles. We would have kinematics, but that’s it.
If it turned out that some of the particle trajectories looked different than others after intersecting one another, we would then look for a way to explain the difference. To do that we might introduce a new categorical property, with a new primitive unit of measure – a primitive dynamical quality. (Primitive because the units cannot be reduced to seconds and centimeters. Dynamical because the units will ultimately be used to explain the behavior of the objects that "carry" the unit.) But introducing the unit itself is not enough. We also need a set of rules that govern the behavior of objects that carry the units. The two are intrinsically linked. The units don’t mean anything without the rules, and the rules don’t mean anything without the units. We can’t explain the relation between the two, because they come together by definition. We simply have to accept them as-is. And when we ask “why” a particle does this or that, all we can do to "provide an answer" is plug some numbers into that loop, and see what the rules tell us. And this in itself is plenty good enough to take a utilitarian approach to physics!
Jammer’s point is that the only way to truly integrate kinematics and dynamics is to use a mechanism that doesn’t follow this self-referential loop. And that means taking a completely different approach to the problem. Because if we try to explain one dynamical quality by invoking another, we’ll need a new set of rules, and the loop continues at a lower level. That isn’t to say that there may not be a valid reason for doing this. But it doesn’t solve the loop. It just relocates it.
Now, the reason that I brought up the information topic is that it forces us to think in a different way anyway. In an informational paradigm, the value of any dynamical qualities must be distributed over a region of spacetime – and not simply ascribed to a point. We can still treat them as categorical properties. But these properties cannot be assigned to individual events - or even drawn as an interval between two events - and so can't be considered fundamental. The relationships are more complicated than that.
Finally, the reason I suggested introducing a new non-dynamical primitive concept - a new unit of measure - is because it gives us an alternative path: a free variable that doesn't follow the same rules as the units that are intrinsically meant to "explain." Space and time can give us kinematics, but once they do, they're all used up. The units of the new dimension would provide a point of contrast to the units of space and time, and allow us to carry the model beyond simple kinematics. Now, when it comes time to re-introduced dynamics to the system - which we must if we want to "explain" anything - we can define the dynamical qualities (axiomatically) so that they break down into conglomerations of the three non-dynamical units. We get dynamics back. But the "charges" aren't fundamental.
Now, is what I’ve just suggested a viable theory of physics? Absolutely not. Without defining the details of the relations, it can’t be used in practice at all. That's why I'm in the philosophy forum. Is it an original philosophical premise that could be further developed into a potentially viable theory of physics? You bet.
  • #32
Hi ZachHerbert. I'm still not sure what the problem is and exactly how you propose to solve it. Isn't everything (that's physically meaningful) in modern physics ultimately reducible to distance and duration observations (ie., communicable in units thereof)? Isn't this what the term information ultimately refers to?
It does seem that, as yet, mainstream physics has proceeded without specifying a unifying fundamental dynamical principle. If the goal is to attempt to proceed along that line, then wouldn't it have to begin as some kinematical abstraction regarding either particle or wave, or both, behavior?
  • #33
Naively, yes. But only if we take both observation and https://www.physicsforums.com/showthread.php?t=467357" (which is what we’ve always done). If we begin by assuming a dualistic ontology – where particles are fundamentally distinct from spacetime – then yes, all measurements are ultimately kinematic in nature. But if we adopt a unified ontology, then we need a way to individuate a particle from the background before we can talk about location or motion. (Basically, assuming individuation through duality gives us kinematics for free.)
A wave ontology helps on the surface, but if the wave is background dependent and inherits its location and motion in a parasitic way from an independent spacetime metric, then we’re back in essentially the same situation. The wave is somehow distinct from the spacetime.
But that isn't the main problem.
No, I don’t think so. Ultimately, those things are needed. But the process needs to begin from a lower level. The idea is to acknowledge the associations that are implicitly assumed in the very concept of “information” and build that into the model. Entanglement provides a stark example.
Without arguing whether entanglement rises to that standard of “causation” or “transmission” we can at least acknowledge that at a bare minimum it involves the “association” of information distributed over space-like intervals. But if the information that embodies even a single particle and its properties is spread out over a region of spacetime, then we have essentially the same issue. It may not appear as spectacular as an entangled two-particle system that is spatially discontiguous, but we’re still in the same situation. Events at space-like intervals must somehow be associated with one another.
Now, we can of course just accept “nonlocality” and run with it. And that’s fine for utilitarian purposes. But that avoids the real mystery. Everyone has gone crazy asking "what is wave collapse?" and "what is it exactly that relativity forbids?" But the real question is, what is “association?” We can classify the intervals between events as “space-like” or “time-like.” But how does a space-like interval between “associated” events differ from a space-like interval between “non-associated” events? There is a demonstrably different relation at work. But the relation has never been formally classified. We can’t “explain” it using the charge/force dynamic (in whatever clothes we choose to dress it in). And we can't account for it using space and time alone. We've run out of variables.
My argument is that by classifying the relation axiomatically, and relating this "new primitive” to space and time, we can stop taking this omnipresent phenomenon for granted - and, ultimately, kill a whole flock of birds with one stone.
  • #34
I am sure he will answer for himself(i don't understand his points, as i have no idea what information really is), but i wish to point out that the MAIN problem he seems interested in is the rift that emerged after the abolishment of the old paradigm based on obvious and self-evident truths(that were later found to be blatantly wrong). Fundamental dynamics is a very very deep problem even for the most knowledgeable physicists working on QG today and talking about it here may be a waste of time. Solving the problem of fundamental dynamics will involve nothing short of solving the deepest problems of our best theories of physics - the infinities of QFT, the singularities of GR and the measurement problem of QM. Unfortunately nobody on this forum is up to the task, so proposing even a vague idea about a how a successful unification might work is empty talk, IMO.
  • #35
A spacetime-like interval is a worldline, so we can classify them as spacetime-like.
Associated in what way? By causality? What is an interval between non-associated events? It would be helpful if you give examples as your way of reasoning seems hard to follow.
I wish to comment but might err in interpreting what you mean, so i'd like to see what you mean by "associated events" and which events are not associated and why.
  • #36
ZachHerbert said:
I know that they aren't fundamental in the same way, but it seems that Jammer's critique still applies. If "quark color" can't be meaningfully isolated from "the symmetry of rotations in SU(3)" - and it seems that it can't - then doesn't that fall into the same circular mess as force/mass? The strong force wasn't invented arbitrarily. It was introduced to explain the behavior of physical systems - just like force/mass was used to explain why some things "weigh more" than others (I know, oversimplified again). I agree that the symmetry route is much cleaner. But it still doesn't make it through the field of play unscathed.
Well, yes, I noticed that you meant charge/mass in general, which is why I thought the other paper was relevant (speaking about structure on the sub-planck scale).
I actually agree with ZapperZ that it's not so circular really. For me, it's merely a matter of infinite regress. If you keep breaking matter up into smaller and smaller parts, how can you ever be confident that you've reached the "bottom"?
We seem to have found a bottom limit with quantum systems, and dispersive quantum systems (that can exchange with their environment) are still an open problem; this leaves open an informational approach. For many, the 2nd law of thermodynamics and quantum chaos seem like good ways to approach the system. (i.e. you trace the phase state of a classical system back to it's original state with such high precision that you must suddenly now consider the Heisenberg Uncertainty. But since it's a classical system, it's potentially chaotic (so small changes to the initial condition will evolve into large changes), but since we can't define the systems original state with infinite precision, it puts a significant weight on the importance of the inherent loss of information in the universe: or entropy.
My point is that if the value must demonstrate variation initially (to individuate it from the environment), and then change (to be considered dynamic) - and do both from a relative context (and not from a static absolute) - then even the initial value requires information to model. And if that value never changes, then by what criteria do we claim that time has passed? (Unless, like Newton, we assign time to a static, absolute point of reference. But then we're back to unobservable metaphysics.)
I'm not sure what difference you assign between "demonstrating variation" and "changing".
So then, you would say we can't individuate c or G from the environment, since they don't change?
This is where I depart a bit. I don't believe there is "definiteness" outside of a metaphysical (unobservable) ideal. Merely citing "macroscopic objects" is not sufficient. The observing system (as frame of reference, means of interaction, and consciousness interpreting the result) can not be ignored in any philosophically viable description of reality. (We don't experience true "definiteness," we experience "information" that has been pre-molded by unseen cognitive structures.) And I don't see that we have any established mechanism to adequately integrate an "observer" into a "system" without succumbing to Jammer's trap and preserving the gap between kinematics and dynamics - and thus (at least to my mind) failing to establish a truly adequate model of unification. (Yes, Jammer was partly a ruse to initiate the conversation, but the reference is still both valid and applicable to the topic of discussion. In case anyone forgot, it was to talk about the role of dynamical qualities in a potentially unified, informational model of reality. :-p)
I don't see how this is a departure; this seemed to be precisely the point to me. I can see how you might take the one sentence you quoted out of context if you didn't read the rest of what I provided...
  • #37
Or thirdly, as lightcone-like. People trying to develop more fundamental notions of co-ordinates post-GR, like Penrose with his twistors, would talk about integrated spacetime rather than separated space + time. So the gaps between events would be spacetime-like, that is lightcone-like.
There are other things going on, like QM non-locality (which implies a limited or local form of retrocausality a la Cramer IMHO). And then the thermodynamic arrow of time (which is the bigger, fatter, global arow of causality pointing the other way).
To break this complexity down into metaphysical primitives is indeed an interesting challenge. But so far I am not getting any sense that you are going the right way about it (even though it is always useful to try to see things from other people's POV).
As an aside, if you want the hierarchy theory persperctive on this, it might be worth reading Stan Salthe's Evolving Hierarchical Systems, especially the bits on "cogent moments". It is a far more rigourous approach than Wilber's holons and integral theory.
  • #38
Unless infinite regress hits bottom at the Planckian limits of scale and "beyond" is "indefinite". ie: ontically indeterminate. ie: vague.
It is an interesting line of thought, but I think probably fallacious as if the initial conditions are traced back to a QM level, then we would be trying to make measurements in a place where all is indefinite/indeterminate/vague. We could not actually make any kind of exact measurement in such a place.
Chaos theory says if you could describe exact initial conditions, then you could have exact deterministic predictability. And QM then says well you can't when it comes to measuring the actual world. You can only start from a coarser grain of semi-classical measurements. So this gives you statistical predictions, not fully-deterministic ones.
  • #39
No difference other than how we label them. (eg. variation over space, change over time.) My point was simply that any value robust enough to serve as an explanation to some physical phenomenon couldn't be self-contained within a single event. (The same with the values for c and G. You don't need the values to change, but you do need a collection of events before the values are meaningful.)
Sorry, I should have quoted more than that. I only meant that I differed in whether the program of decoherence actually met the full requirement quoted below...
D’Espagnat said:
In fact, scientists most righly claim that the purpose of science is to describe human experience, not to describe “what really is”; and as long as we only want to describe human experience, that is, as long as we are content with being able to predict what will be observed in all possible circumstances (. . . )
I don't think that demonstrating the existence of macroscopic objects and their spatiotemporal relations is sufficient to describe human experience. The most omnipresent aspect of human experience is our ability to associate multiple, distinct bits of information in our cognitive awareness simultaneously. Per my post above, defining the nature of this "association" is far more fundamental to describing human experience than just explaining why macroscopic objects demonstrate classical rather than quantum behavior or predicting the outcome of an experiment.
Sorry, I've been leaving out "light-like" intervals for simplicity. I've been assuming an integrated spacetime, but didn't say so explicitly. (The idea of decomposing spacetime back down into space+time seems very kludgy to me, so I tend to forget to clarify.)
Thanks, I'll check that out.
  • #40
I think we're actually in agreement because that's the whole point of the discipline: quantum chaos. Here, I am presenting the problem, not a solution. Quantum Chaos, as a field, is essentially the search for a solution: it's not hinging on any currently proposed solution.
That's not the claim though, is it? The claim is that macroscopic observations are insufficient to completely describe reality because they are limited by our perception of reality. That we have a fundamentally flawed notion of what reality actually is, and it's a notion that's not explicitly measured/observed/stated (as you pointed out in your first reply to this idea). So we don't really know where our flaw is: it's either a collection of assumptions we're not conscious of or a very fundamental flaw in the whole way we're able to perceive (the former being recoverable information, the latter being irrecoverable information).
Thermodynamics (properly described by quantum mechanics) implies it's the latter; for example, particles don't have a definite position or momentum. The notion of "being" that humans experience is being projected on to particles to which it does not apply, and this (the general uncertainty principle) is a result of a particle indistinguishability (there is fundamentally no difference between this electron and that electron).
  • #41
That maybe true, but it doesn't excuse the omission. If physics is comfortable with taking the concepts of space and time seriously - both of which have origins in phenomenal human perception - then this third relation should be taken just as seriously. Embracing variation and change, while simultaneously ignoring the integrated perspectives which give us the ability to define those concepts in the first place seems like dashing out of the restaurant before paying for the meal.
  • #42
It's taken seriously... that's the obvious direction of development (which is why Zurek ends on a note of information theory).
But why would you expect it in a physics paper? You're talking about neuroscience, psychology, and information theory now... not just physics. From a physics point of view, the paper is already suggestive enough as it is.
Also, recognize that utilizing space and time is not the same as studying the nature of it. All physicists don't study the nature of space and time, some just use it. And that is sufficient enough for physics yes, as long as the behavior they're describing is predicted reliably with the assumptions (which it is: i.e. planetary motion, cannon ball trajectories).
Your ideal version of scientist would agree with you, of course; he would want to know everything about everything and how it all ties together (this is called a first year physics undergraduate) but your ideal is not the reality by the time the student has a PhD. At least, not if they want to remain sane and working in physics.
  • #43
Well that's the part that is new in what I'm proposing. I agree that the complex structures that form human cognitive states are emergent. But what I'm suggesting is that the bare, fundamental relation that is at work in the observer/information dynamic should be treated as primitive.
Since physics is deeply rooted in the idea that spatiotemporal relations play some objective role in describing the universe - and aren't just first-person phantoms of human experience - I'm simply proposing that "perspective" be treated the same way. The mere introduction of a third class of relation at that level has a powerful impact on several long standing debates (both inside and outside of physics). Basically, the purpose of http://dl.dropbox.com/u/8804875/Primitives%2BIntro.pdf" is to show how even a simple toy model of the idea changes the fundamental nature of some deeply rooted paradoxes. And, in my opinion, a different way to look at a problem is always valuable.
  • #44
My guess would be that the spacelike intervals between associated and nonassociated events aren't different in any important way.
However, the relationships that allow us to distinguish associated (eg., entangled) events are embodied in, ie., ultimately traceable to, the preparation procedures (ie., emission by the same atom during the same transition process, direct interaction, the common application of an identical torque, etc.). This is how entanglement is understood and reliably and repeatedly produced. So, I don't think there's any great mystery as to what the relationships are due to.
ZachHerbert said:
My argument is that by classifying the relation axiomatically, and relating this "new primitive” to space and time ...
The exact physical nature of the relationship(s) can be different. But the relationships are also nonvariable from trial to trial and run to run wrt a given preparation. (Hence their resistance to being modeled as hidden variables.) So, how would you classify these relationships axiomatically in the form of a single new primitive?
My guess is that things will continue pretty much as they have been. For experimental preparation and measurement (ie., at the level of our sensory perception), individuation can continue to be taken for granted and the more or less de facto operational interpretation and practice of standard qm would remain the preferred formalism (as a set of rules) for calculating outcome probabilities wrt certain experimental procedures -- while less practical but entirely deterministic foundational formalisms, possibly incorporating a fundamental dynamical principle to tie together the apparent behavioral connections between the various particulate media in the emergent hierarchy, might be developed in addition to that.
ZachHerbert said:
... what I'm suggesting is that the bare, fundamental relation that is at work in the observer/information dynamic should be treated as primitive.
This seems the same as taking individuation and suitably collected and processed observational data at the level of our sensory perception for granted and using it to evaluate competing statements about the world. If so (and even if not), then how is what you're proposing going to change anything about the way scientists do science or one's worldview that isn't already possible without it? How might what you're proposing clarify anything?
  • #45
But this isn't correct. If all of the relevant information could be found at time-like or light-like intervals to the result, then the terms "entanglement" and "nonlocality" would never have been invented in the first place.
This isn't the whole picture though. Just because hidden variables can't preserve locality doesn't mean that locality can be preserved without them. From "Quantum Non-Locality and Relativity" by Tim Maudlin...
Maudlin said:
Bell himself derived the result as part of an examination of so-called local hidden-variables theories. Such theories attempt to eliminate the stochastic element of orthodox quantum theory by adding extra parameters to the usual quantum formalism, parameters whose values determine the results of the experiments. Bells’ results are therefore sometimes portrayed as a proof that local deterministic hidden-variables theories are not possible.
This is a misleading claim. It suggests that the violation of the inequalities may be recovered if one just gives up determinism or hidden variables. But as we have seen, the only assumption needed to derive the inequalities is that the result of observing one particle is unaffected by the experiment carried out on the other. Subject to this restraint, no deterministic or stochastic theory can give the right predictions, no matter how many or how few variables are invoked.
Since a natural method of attempting to ensure the isolation of the two particles from one another is to carry out the relevant observations in distantly separated places, the isolation condition is generally called “locality”. The assumption involved is that observations made on one photon can in no way alter the dispositions of the other photon to pass or be absorbed by its polarizer. Adopting this terminology uncritically for a moment, we have shown that Bell’s inequality must be obeyed by any local theory of any sort. Adding stochastic elements does not help the situation at all, as noted above. So experiments verifying the violation of Bell’s inequality would doom locality tout court.
  • #46
All the relevant information is in the preparation procedures, and is represented in the qm formalism.
The term entanglement was used by Schroedinger to refer to the relationship between particles that had interacted. The interesting thing about it was that after an interaction then more was known about the biparticle system, from the assumed relationship, than could be inferred from maximum knowledge of the individual subsystems without the relationship.
The term nonlocality, wrt its usual or historical meaning, is simply a misnomer when applied to this stuff. Conservation laws allow precise values wrt, say, entangled pair observables (ie., correlations, or coincidence stats), while individual stats remain totally random. This is what's being referred to when entangled biparticle states are called nonlocal.
Qm completely describes the correlations of spacelike separated, entangled, subsystems, while at the same time offering only an incomplete description of the physical reality of the subsystems. This is what's being referred to when the qm description of entanglement is called nonlocal.
Of course not. There isn't any "whole picture". But it does point to why the qm account is sufficient and hidden variable accounts aren't.
The principle of local causality is a fundamental working hypothesis of modern physics. There is, to date, absolutely no physical evidence to the contrary. Hence, preserving locality isn't a problem -- while demonstrating that nature is nonlocal is a problem.
Anyway, the important question posed to you had to do with how you think your approach might clarify anything. I don't think that it does. I think that at best it's just superfluous, and at worst confusing. But I invite you to convince me otherwise.
  • #47
I think ZapperZ's comments would begin to apply once you formalize these thoughts it in a paper like this. You have an interesting perspective, but you really need to ground it in the established physics and spend more time developing your ideas.
Here's a good lecture series from a very well-spoken instructor. He touches on many of our points just in this first lecture (plus I always love India's intros to their lecture videos):
Though, I think the best thing you can do is enroll in academia and get a degree in physics.
  • #48
The qm account may be sufficient to describe the behavior, but it certainly is not local. I recommend reading Maudlin’s “https://www.amazon.com/dp/0631232214/?tag=pfamazon01-20” which I quoted above. It gives a thorough presentation of Bell’s theorem and the Aspect experiment, and then examines whether the observed phenomena meet the standards of superluminal causation, energy transfer, information transfer and/or signaling. It follows with several alternative ways of interpreting special relativity, and how each of these fits with the earlier analysis (and then proceeds to how the ideas of general relativity muddy the waters even more).
Another fascinating book is “https://www.amazon.com/dp/0226041824/?tag=pfamazon01-20” by Mara Beller. Beller essentially gives a “political commentary” on the various arguments and tactics employed by the two primary camps involved in the early quantum theory debates (Einstein, Schroedinger, et al vs. the Copenhagen physicists). It is interesting to see how the arguments that gave rise to the currently established positions (including the one you present above) weren’t exactly above board and employed many of the same tactics used in political debate. (For example, avoiding the critical attacks on implicit nonlocality by redirecting the response to the weaker attack on hidden variables and complementarity.)
Certainly I can see how my ideas would appear superfluous without a familiarity with the problems they are meant to address. But if you truly believe that quantum theory conforms to the idea of local causal determinism, then I’m having a hard time imagining what you must think of the last 85 years of debate over how to interpret the model? Or even the importance of the Aspect experiment (since the whole point was to randomly determine the alignment of the detectors outside of the future light cone of the photon emission from the source)? Unless, I suppose, you take the position that all events were strictly determined at the moment of the big bang?
Thank you for the feedback (and for participating in the discussion with an “outsider” in the first place. :) Obviously my focus is more on the underlying philosophy than on the physics itself. But it’s been fascinating to see which points have been more readily accepted, and which points resulted in pushback – particularly since the points of contention were not at all where I expected! It’s been a real help!
  • #49
Congrats to Zach for not getting riled here. And can Pythagorean please stop nicking my best lines. :smile:
But anyway, I'd like to hear more about how Zach generalises from consciousness to perspective. His model of consciousness so far is sketchy and unconvincing. And I'm am left with no clear impression of what "perspective" is actually a measure of. It could be complexity, or integration, or locality, or a lot of things. So it would be interesting to refine the definition.
As I said earlier, it would also be a help, and more scholarly, to put his own definition in the context of other such efforts.
For instance, there is the semiotic approach based on CS Peirce's metaphysics. There must be 30 or 40 academics currently working on bio-semiosis and pan-semiosis as a way to generalise the notion of meaningful relationships (between observers and what is observed). You also have second-order cybernetics, relational biology, autopoietic systems - a lot of approaches that could be felt to have something to say here.
Reading Zach's paper, I don't think he gets how brains actually interact with the world. That does not necessarily matter as consciousness might be just the "analogy that inspires" here. He could be defining a metaphysical primitive that is useful and only very loosely like subjective awareness. Or he could instead be relying on his sketchy understanding to be exact, the primary motivation of his argument. In which case I would say he is in trouble. :smile:
  • · Replies 23 ·
  • · Replies 47 ·
  • · Replies 48 ·
  • · Replies 20 ·
  • · Replies 163 ·
30K
