Why do maximum L/D and max. lift not occur at the same angle of attack?
The discussion revolves around the relationship between maximum lift and maximum lift-to-drag (L/D) ratio for a NACA 0012 airfoil, particularly why these two maxima occur at different angles of attack. Participants explore the implications of their wind tunnel test results and seek clarification on the underlying principles of aerodynamics.
  • One participant reports that their wind tunnel tests show maximum L/D at 12 degrees and maximum lift at 15 degrees, expressing confusion about the discrepancy.
  • Another participant references a Wikipedia entry, explaining that the peak L/D ratio does not occur at the point of least total drag due to the balance between lift and drag at different speeds.
  • A different participant discusses the importance of knowing maximum lift and how increasing the angle of attack beyond a certain point leads to increased drag and potential stall.
  • One participant attempts to clarify that the optimum L/D ratio is where the most lift is achieved with minimal drag, noting that exceeding this point results in higher drag, thus making the angle of attack less efficient.
Participants express varying levels of understanding regarding the relationship between maximum lift and maximum L/D ratio, with no consensus reached on a definitive explanation for why these maxima occur at different angles of attack.
Some assumptions about aerodynamic principles and the specific conditions of the wind tunnel tests are not fully explored, leaving room for further clarification on the factors influencing lift and drag at different angles of attack.
v_arsha
Hello,
I did a wind tunnel test with a NACA 0012 airfoil. And my results showed that the highest lift-to-drag ratio occurred at an angle of 12degrees where as my maximum lift is at 15degrees. I even read somewhere that these values do differ but there was no such explanation as in why is that so..
Can someone please help me out..
Thanks
Can't really word it better than the wiki entry so here it is:
The peak L/D ratio doesn't necessarily occur at the point of least total drag, as the lift produced at that speed is not high, hence a bad L/D ratio. Similarly, the speed at which the highest lift occurs does not have a good L/D ratio, as the drag produced at that speed is too high. The best L/D ratio occurs at a speed somewhere in between (usually slightly above the point of lowest drag). Designers will typically select a wing design which produces an L/D peak at the chosen cruising speed for a powered fixed-wing aircraft, thereby maximizing economy. Like all things in aeronautical engineering, the lift-to-drag ratio is not the only consideration for wing design. Performance at high angle of attack and a gentle stall are also important.
http://en.wikipedia.org/wiki/Lift-to-drag_ratio
That is a very good question,
We actually try to calculate maximum lift of the aircraft or aerofoil to know the maximum lift is how far and the next point of the increase in the Angle of attack (AOA) causes downfall of the lift and increase in drag and tends to stall.
And when coming to L/D ratio or gliding ratio we take into account of the lift how many times greater than and this ratio is important for a stable flight and ideal performance. For example: in emergency landing the aircraft has to land quickly and we have a problem of insufficient fuel if L/D ratio is 12 at for ‘X’ AOA then the pilot tries to get the aircraft to that point or at particular AOA so that he can save some fuel for emergency landing and he knows that lift is 12 times greater than drag and pilot knows what to do.
OK, but that doesn't answer why the highest L/D ratio isn't necessarily the maximum lift point. Again, for that I refer you to the wikipedia entry for the best description.Here goes for my attempt at an explanation:
The optimum L/D ratio is the point where you get the most lift possible with as little drag as possible.
Above this point, you may get more lift but you get significantly more drag.
Below this point, you may have significantly less drag but you don't have much lift.
In your example, your optimum L/D ratio may be 10 (Lift=20/Drag=2) but your maximum lift L/D ratio could be 5 (Lift=25/Drag=5)*. Although in the latter case you are getting more lift than the previous, you are also getting significantly more drag. Making the AoA less efficient to use.
* Numbers purely for demonstration.
Thanks, it really helped :)
  • · Replies 34 ·
10K
  • · Replies 30 ·
22K
