How Can We Determine the Inverse Image of Euler's Totient Function?
  • Context: Graduate
  • Thread starter Thread starter math_grl
    Image Inverse Phi
The discussion revolves around finding the inverse image of Euler's totient function, specifically exploring how to determine which natural numbers map to a given integer under the function. Participants examine theoretical aspects, potential methods, and conjectures related to the inverse image of the function.
  • Some participants note that \(\phi(1) = 1\) and \(\phi(2) = 1\) are the only natural numbers that map to 1, questioning if there is a general method to find the inverse image of numbers in the image of \(\phi\).
  • One participant suggests that there is no general way to determine if a number is a totient of another number, indicating that this can only be done manually.
  • Another participant clarifies that the function \(f: \mathbb{N} \rightarrow \phi(\mathbb{N})\) is onto but not injective, implying that an inverse cannot exist.
  • There is mention of a conjecture related to the problem, specifically referencing Carmichael's totient function conjecture.
  • One participant presents inequalities derived from the definition of the totient function, suggesting that for a given positive integer \(n\), the equation \(\phi(x) = n\) has finitely many solutions.
  • Another participant introduces the concept of "Inverse Totient Trees" and provides a method to calculate the maximal integer with a given totient, illustrating this with the example of \(\phi(N) = 24\) and discussing related number sequences.
Participants express differing views on the existence of a general method for finding the inverse image of the totient function, with some suggesting it is not currently possible while others propose specific approaches and conjectures. The discussion remains unresolved regarding the overall feasibility of determining the inverse image systematically.
Some limitations include the dependence on definitions of the totient function and the unresolved nature of certain mathematical conjectures related to the topic.
math_grl
So upon introduction to Euler's phi function, we can see that [tex]\phi (1) = 1[/tex] and [tex]\phi (2) = 1[/tex], where it turns out that these are in fact the only numbers in N that map to 1. Now what I'm wondering is if there is some general way to find the inverse image of numbers in the image of phi?
Also, how would one go about showing that once we find [tex]\phi^{-1}[/tex] that these are in fact the only numbers it could be?
what you mean by "inverse"? do you mean multiplicative inverse ab=1 such that b = a^-1?
I think you want to know if a given number is a phi of one or more numbers, and I think there is no general way to do it yet, only by hand
for instance, given 14, is it a phi of at least one number? no, and I think there is no known way to characterize such numbers yet
I don't think there should be any confusion in my terminology but in case a refresher is needed check out http://en.wikipedia.org/wiki/Image_(mathematics)#Inverse_image"
It might also help make it clear that [tex]f: \mathbb{N} \rightarrow \phi(\mathbb{N})[/tex] where [tex]f(n) = \phi(n)[/tex] cannot have an inverse as it's onto but not injective.
Other than that, yes, what I was asking if there was a way to find all those numbers that map to 14 (for example) under phi...
hi math-grl
so what you want is to find the n's such that
[tex]\varphi(n_1)=m_1[/tex]
[tex]\varphi(n_2)=m_2[/tex]
[tex]\varphi(n_3)=m_3[/tex]
[tex]\varphi(n_4)=m_4[/tex]
knowing only the m's, correct?
there is a conjecture related to it, although what you want is far more difficult than the conjecture
http://en.wikipedia.org/wiki/Carmichael's_totient_function_conjecture
Hi math_grl,
I think that your question does have an answer. The following inequalities can be proved directly from the definition of the totient function, or by using the product formula:
[tex]\frac{1}{2} \sqrt{x}\ \leq \ \phi(x) \ \leq \ x[/tex]
for any positive integer x. It then follows that the equation [itex]\phi(x) = n[/itex] has only finitely many solutions for a given positive integer n. In fact, given n, the inequalities imply that all solutions to the equation satisfy
[tex]n \ \leq x \ \leq \ 4n^2[/tex]
Hope that answers your question.
Hi math_grl,
Beyond Petek's reply, one can also calculate the maximal possible integer with a totient of n via recourse to the mathematics associated with "Inverse Totient Trees."
For instance, take the integers with a totient of 24. Then...
phi (N) = 24
phi (24) = 8
phi (8) = 4
phi (4) = 2
phi (2) = 1
There are 5 "links" (designate: L_x) in the totient chain so to speak, with 4 intervals. In general, the greatest integer that can have a totient of n is 2*3^(L-1), which means that 2*3^(5 - 1) = 162 is the upper bound of an integer with a totient of 24. In fact, via a not very exhausting proof by exhaustion, one can easily check a table and see that the greatest integer where phi(n) = 24 is 90.
phi (n) = 24 --> 35, 39, 45, 52, 56, 70, 72, 78, 84, 90
And a couple related number sequences.
A032447 Inverse function of phi( ).
http://oeis.org/A032447
A058811 Number of terms on the n-th level of the Inverse-Totient-Tree (ITT).
http://oeis.org/A058811
As for why the 2*3^(L-1) formula works, I am as curious as anyone and would be more than happy if anyone could provide some insight on that.
- RF
  • · Replies 33 ·
  • · Replies 34 ·
  • · Replies 0 ·
  • · Replies 20 ·
