 Quote by PAllen
So, to be clear, you would call the following a mis-calibrated mearurement:
A rocket with rest length of 100 meters is moving by at relativistic speed. I have a pair of super fast barriers I can raise and lower simultaneously (as I see it). I can momentarily contain the rest length 100 meter rocket between my barriers set 10 meters apart. My conclusion that the length is less than 10 meters is mis-calibrated, and inferior in some way to the rocket's own perception that what happened is that a barrier went up and down in front of the rocket, then both barriers moved, then the other barrier went up and down behind the rocket.
PAllen,
I really love the way you described the old "pole in the barn" example.
