What does the probabilistic interpretation of QM claim?
  • Context: Graduate
  • Thread starter Thread starter A. Neumaier
    Interpretation Qm
The discussion centers around the probabilistic interpretation of quantum mechanics (QM), particularly regarding the measurement of observables and the implications of quantum uncertainty. Participants explore the nature of probability densities associated with wave functions, the role of operators, and the relationship between theoretical constructs and experimental practices.
  • Some participants assert that the probability interpretation of QM specifies that the probability of observing a particular eigenvalue is given by the expression psi^* P_k psi, where P_k is the projector onto the k-th eigenspace, but does not define which operators are observable.
  • Others argue that the assumption that |psi(x_1,...,x_n|^2 represents the probability density for simultaneous particle positions is often idealized and not used in practical measurements.
  • There is a claim that Wigner's theorem indicates that only quantities commuting with all additive conserved quantities can be precisely measured, suggesting limitations on the observability of certain operators.
  • Some participants note that particle detectors primarily measure momentum rather than position, leading to a discussion about the interpretation of scattering experiments in the momentum picture.
  • One participant points to the double-slit experiment as an example where the wave-mechanics interpretation is employed, while another challenges the applicability of this interpretation in real experimental contexts.
  • There is a discussion about the role of ionization in particle detection, with one participant suggesting that the interaction causes a collapse of the wavefunction, complicating the correlation between the initial state and the measurement outcome.
  • Some participants express agreement that |\psi(p)|^2 can be interpreted as the probability density for finding a particle with momentum p, while others emphasize the importance of distinguishing between different representations of the wave function.
The discussion reveals multiple competing views regarding the interpretation of probability in quantum mechanics, the nature of observables, and the implications of experimental techniques. There is no consensus on the validity of certain interpretations or the implications of quantum uncertainty.
Participants highlight limitations in the assumptions made about observables and measurements, particularly regarding the idealized nature of certain interpretations and the practical challenges of measuring position versus momentum in experiments.
A. Neumaier
Insights Author
I collect here info from another thread, to have a more focussed discussion.
A. Neumaier said:
The probability interpretation says that _if_ you can set up an experiment that measures a self-adjoint operator for a system in state psi then the probability of observing the k-th eigenvalue is psi^* P_k psi, where P_k is the projector to the k-th eigenspace. It says _nothing_ at all about which particular operators are observable in this sense.
Everything beyond that is interpretation, and hence (at the current state of affairs) a matter of philosophy. In particular, which operators can be measured is not part of the probability interpretation but a matter of theoretical and experimental developments.
Regarding what is arbitrarily _precisely_ measurable, there is a no go theorem by Wigner (I can give references if you want to check that) that states that _only_ quantities commuting with all additive conserved quantities are precisely measurable. The position operator is not among these.
Nobody comparing QM with experiments is making use of this particular assumption.
''this particular assumption'' refers to the assumption that |psi(x_1,...,x_n|^2 is the probability density of observing simultaneously particle k at position x_k (k=1:N).
A. Neumaier said:
It is stated in the beginning as an interpretation aid without proof, and never taken up again in the context of real measurements where the claim would have to be justified. It is very common to make this sort of idealized assumption to get started; but once the formalism is established, this assumption is never used again.
For example, Landau & Lifgarbagez begin in Section 2 of their Vol. 3 with such a statement, but immediately replace it in (2.1) and (3.10) by the more correct version about the interpretation of the expectation value <K> = Psi^* K Psi, where K is an arbitrary observable (linear integral operator) depending on the form and values of the measurement. From then on, only the latter interpretation is used; never the fictitious, idealized introductory remark.
And it cannot be different, since quantum mechanics is used in many situations where the state vectors used in the formalism have no interpretation as a function of position - the whole of quantum information theory and the whole of quantum optics belonging to this category.
Avodyne said:
For nonrelativistic particles, absolutely everyone comparing QM with experiments does make use of the wave-mechanics interpretation of [itex]|\psi(x)|^2[/itex] as a probability density.
Please show me a comparison with experiment that does this.
Nonrelativistic particles have no different interpretation than relativistic ones.
Particle detectors respond to the momentum of a particle, not to its position.
Scattering experiments are interpreted in the momentum picture. Nobody is interested in the position of particle tracks, only in their momentum (which tells about masses).
meopemuk said:
Yes, this is true. QM does not talk about the specifics of observations and measuring devices. For example, P_k can be a projection on the k-th eigenvalue of the position operator.
It could be this _only_ if you can prepare an experiment that realizes such a P_k. But this is a matter of experimental technique and not one about the interpretation of quantum mechanics. But there are no such operators since the spectrum of position is continuous.
meopemuk said:
Yes, this is true. QM does not talk about the specifics of observations and measuring devices. For example, P_k can be a projection on the k-th eigenvalue of the position operator. Then psi^* P_k psi is the probability (density) for measuring position k in the state described by psi. QM tacitly assumes that some ideal precise measuring device can be constructed, which does exactly that
No. This unrealistic assumption is needed _only_when one wants to insists on a probability density interpretation of |psi(x)|^2. And for the position representation of an N-particle state, one would need an even more ideal precise measuring device that can measure the simultaneous presence of N particles in N different, arbitrarily small regions
covering the size of an uranium atom (N=92), say.
This is ridiculous - such measurement devices are impossible!
Whereas the form in which I stated the probability interpretation assumes nothing. it makes claims only for those projectors that are actually realizable. it is therefore much more realistic.
Quantum uncertaqinty rules out continuity in position.
_PJ_ said:
Quantum uncertainty rules out continuity in position.
Wigner's theorem (p.298 in: Wheeler & Zurek, Quantum theory and measurement, Princeton 1983) even rules out projective measurements of a particle being in a given region, since the corresponding projector does not commute with all additive conserved quantities.
Would you then agree that [tex]|\psi(p)|^2[/tex] is the probability (density) of finding the particle with momentum p? Of course, [tex]\psi(p)[/tex] is the wave function in the momentum representation.
Eugene.
Avodyne said:
For nonrelativistic particles, absolutely everyone comparing QM with experiments does make use of the wave-mechanics interpretation of as a probability density.
The double-slit experiment is a good example. See Feynman's Lectures on physics.
Eugene.
I also reproduce what I wrote on this point in the other thread:
Experimenters have been recording particle tracks in position space with cloud chambers, bubble chambers, spark chambers, and drift chambers for many decades. The experiments are typically done in a strong magnetic field, which allows for measuring the momentum of charged particles by measuring the curvature of a track in position space. Modern experiments also have calorimeters at the boundaries of detectors that measure energy deposited; this does give a direct measurement of a particle's energy, but not its momentum.
For some recent pictures of particle tracks in position space from the LHC see
http://public.web.cern.ch/press/pressreleases/Releases2010/PR15.10E.html
I certainly believe that the superposition principle even applies when you can consider a quantum object in a definite state (Quantum Enigma, pg. 191; Entanglement, pg. 79; Absolutely Small, 371-372). So if it is in a definite state (this is obviously determined through what you see) then you can also consider all the other states it COULD be in as potentials (as you cannot see those other states). Of course, we can only talk about what we see. Perhaps those potentials ARE really real too, we just can't see them? But such questions are pointless as what we work with is from what we see.
The Mental Universe -> http://henry.pha.jhu.edu/The.mental.universe.pdf
When the particles in these chambers pass the medium, they ionise their surroundings. This interaction itself causes a collapse of the wafefunction.
The resultant ionised particles of media are what is detected, the momentum can be calculated as can the energy of the particle, but since there is delay between the initial ionisation and the detectoin of the ionised media particles, the initial particle is no longer in that state and cannot be correlated with the measurement of its energy (velocity).
Definitely yes! Momentum is measurable, and (in direction, often also in magnitude) measured in every scattering experiment. And this doesn't contradict Wigner's theorem since momentum is one of the additively conserved quantities.
It cannot, since photons (usually used in the double slit experiment) have no Schroedinger position picture.
If it doesn't in the most important case, there is no reason to believe it should in other cases.
Yes; one measures the momentum by finding the curvature of the track. Nobody is interested in the position of the particle. Just as the photon in a double slit experiment is a spherical wave which leaves a detector click at a random detector position, so
the particle is a spherical wave which leaves a track in the detector (according to Mott's famous analysis) in a random initial direction - the scattering direction and the particle energy (which together give the momentum) form the observables, not the position.
I don't think its really correct to say that no one is interested in particle tracks. Although I'm not a particle experimentalist, I certainly think they're interesting to look at!
More seriously, detailed reconstruction of particle tracks is important for determining interaction vertices. For example, interesting unstable particles may decay after traveling some macroscopic distance, thus leading to an offset in the positions of the decay products. Deciding whether certain decay products came from a "primary vertex" or from some "secondary vertex" is critical for determining the nature of the unstable particles. For example, it helps in deciding what invariant mass to compute. At least that's my understanding from chatting with my experimentalist friends.
See here: http://lhcb-public.web.cern.ch/lhcb-public/ for an example. The April 21, 2010 entry.
Whether or not anyone is interested in the position of the particle is irrelevant. The point is that position of the particle has been measured. You had claimed that "Particle detectors respond to the momentum of a particle, not to its position." This is wrong. Particle detectors at the LHC respond to, and record, the position of a particle at a sequence of times, and then infer the momentum from the path of that the particle took.
So, you are not against probabilistic interpretation per se. You are against probabilistic interpretation of position measurements.
But experimentalists do measure particle positions all the time. They use rulers, photographic plates, bubble chambers and other not-so-sophisticated devices to do so. Then they can specify a certain volume in space and count how many times particle passed through that volume (e.g., using a Geiger counter). So, experimentalists can calculate the probability of the particle being in that volume. Probabilistic interpretation of position measurements exists experimentally. However, for some reason, you do not allow us to do the same in theory.
I would appreciate if you give an original reference to the "Wigner theorem", which, as you say, does not allow us to measure position and interpret it probabilistically. This claim sounds unbelievable to me.
Eugene.
When a photon hits the photographic plate or a CCD detector it leaves a clear trace, whose position is well-defined (at least in our macroscopic world). So, it seems that there is no problem in measuring photon position with the precision of few micrometers, or so. We must have a theory, which would explain these kinds of measurements. Quantum mechanics is exactly this kind of theory, and the probabilistic interpretation of measurements of position (and all other obervables) is the cornerstone of quantum mechanics. If you deny that, then you invite a major revision of the entire foundation of quantum mechanics.
I don't know what would happen if we tried to determine photon's position with the precision of, say, less than 1 Angstrom. Perhaps, in this case we would meet some difficulties that you are referring to. However, there are no experimental devices, which can measure photon's position so precisely. So, the issue of the absence of a photon's position operator is an academic issue, in my opinion.
You do not deny the existence of photon's momentum eigenstates. And I can always form linear combinations of these eigenstates (with factors like exp(ipx)) which would behave *almost* like position eigenstates. For example, the linear combinations with different x and x' will be (almost) orthogonal. A space translation of an x-combination will move it to the x+a-combination. So, all properties characteristic to position will be approximately satisfied.
This should be sufficient for defining position measurements and related probabilities at least in our macroscopic world with micrometer-or-so-precision measurements.
All these problems are absent for massive particles, like electrons. So, to keep our discussion simple, let us focus on the double-slit experiment with electrons.
Eugene.
Yes. particle tracks _are_ important; but because they allow one to measure the momentum of a particle. But particle position is irrelevant, and doesn't exist on the quantum field level.
No. The position of a particle has been ''measured'' only in the same sense as the position of a photon has been ''measured'' when a photodetector clicks. But neither of them exists at the quantum field theory level.
For photons one not even has a Schroedinger picture in which photon position would be well-defined, hence clicks cannot be said to measure a photon position. Instead, the analysis in the book by Mandel & Wold shows that the clicks in the photodetector are produced by the photodetector already for a classical external e/m radiation field, showing that photodetection is a random measurement of the intensity of the incident radiation field, and nothing else. See the thread https://www.physicsforums.com/showthread.php?t=474537
For alpha particles, the corresponding analysi analysis is given in Mott's 1929 paper (reprinted in pp.129-134 in: Wheeler & Zurek, Quantum theory and measurement, Princeton 1983). He shows that the tracks formed in a cloud chamber are already produced by the cloud chamber in a classical external radial charged field - in which case the quantum system considered does not contain an alpha-particle at all. Thus the tracks cannot be said to measure a particle position. Instead they form a random measurement of the intensity and direction of the incident charged field, and nothing else.
Yes. In quantum field theory and hence in multiparticle quantum mechanics where particles are indistinguishable, position is a mere parameter, like time, that cannot be measured. Only for a single massive particle it seems to be different - but even here it causes the typical qauntum weirdness of propertyless particles suddenly materializing when measured.
How do you measure a particle position by a rule? Rules only serve to measure local discontinuities or maxima of a macroscopic color field.
These never measure particles, but macroscopic distributions of silver atoms or bubbles.
The most accessible reference (in English translation) is the one I gave already; the book is a very useful reprint volume. The original is in German: Z. Phys. 133, 101-108.
I deny that a photodetector measures the position of photons, or that a bubble chamber measures the position of charged quantum particles. (The trace is a trace of particle excitations as the result of the external charged field and a constant magnetic field in case of curved traces.) They measure the incident fields, nothing else.
In my lecture http://arnold-neumaier.at/ms/optslides.pdf , I call this revision the thermal interpretation of quantum mechanics. It does not require the slightest alteration of quantum mechanics or quantum field theory. I only changed the currently accepted weird way of talking about quantum system (a long tradition introduced by many years of brainwashing) into one which matches common sense much better. So it is not a change in the foundations but only a change in the interpretation - one that is more consistent with the mathematics (such as the nonexistent of a photon position operator, and Wigner's theorem).
Indeed, photon momenta are measurable if they are large enough. (Only soft photons cannot be measured, because of the infrared problem.)
Do you deny that the position of an electron can be measured by letting it fall on a photographic plate?
According to the quantum field theoretic view, position is only a field label, not an observable.
The plate responds to the field strength of the beam containing the electrons: Random atoms are ionized, with a rate proportional to the field strength. This effect that is subsequently magnified and becomes visible.
What is measured is therefore the field strength, although because of the randomness involved, the measurement becomes reliable only if the exposure is sufficiently long.
Mr Neumaier,
I'm also suprised to read such a statement! (That the tracks in a bubble chamber are not a position measurement). I don't deny this immediately, i just want to understand what you're saying.
Let me say first how i would define a position measurement. If the incident field/particle has a state |Ψ>, and expand this state on the basis of position eigenstates, then i would call a position measurement something that would make the wavefunction of the particle in the position representation "gather" around a point. So that, we will be able to say that it was here, in that box, and not in the andromeda galaxy. Knowing that the field/particle is located in a subregion of space, i think defines a position measurement.
When charged fields/particles interact with the bubble chamber we see a trajectory. This trajectory has dimension, for example 0.5x0.5 mm^2 and that defines a subregion of space. I agree that what we see is the effect of the interaction of the particle with the atoms of the liquid, but there can be an interaction only if the paticle's wavefunction is nonzero at the point of the interaction with an atom. The fact that we see only a small trajectory -to my mind- means that the wavefunction of the particle is non-zero only in that subregion of space. It doesn't interact with the rest of the chamber, and its not in my house either.
So, that fits my definition of position measurement, the wavefunction is 'gathered' in a subregion of space.
Am i wrong?
John
On Wigner's no-go theorem for exact measurement:
The paper J. Math. Phys. 25 (1984), 79 -87 by Ozawa might also be of interest.
The position is of course a field label, since the quantum field is essentially the position version of momentum mode creation operators. But why does that imply that the position of an electron cannot be measured? As far as I know, the fact that momentum is a label of the creation operators for momentum modes does not imply that the momentum of an electron cannot be measured, so what's the difference?
In my opinion, we should first define what we mean by a 'position measurement' and then see if the tracks in a bubble chamber, for example, qualify.
The difference is that momenta (like other conserved additive quantities) are asymptotic quantities, and quantum particles have meaning in an asymptotic sense only.
Things start to get semiclassical (where the particle concept begins to be applicable) only when field concentrations are so large that their density peaks at reasonably well-defined locations in phase space. At this point, these peaks behave like particles, and position and momentum of the peak behaves approximately classically.
Why don't you start with a proposal for a definition what _you_ mean by a 'position measurement'?
I've done it at post #22.
Could you expand on this part a bit. What's an asymptotic quantity?
An observable still visible at times t-->inf or t-->-inf, so that scattering theory says something interesting about it. This is relevant since quantum dynamics is very fast but measurements take time. Measuring times are already very well approximated by infinity, on the time scale of typical quantum processes. Thus only asymptotic quantities have a reasonably well-defined response.
That's why information about microsystems is always collected via scattering experiments described by the S-matrix, which connects asymptotic preparation at time t=-inf with asymptotic measurement at time t=+inf.
  • · Replies 17 ·
  • · Replies 309 ·
18K
  • · Replies 35 ·
  • · Replies 41 ·
  • · Replies 76 ·
  • · Replies 109 ·
11K
  • · Replies 35 ·
  • · Replies 21 ·
  • · Replies 147 ·
12K
