What is causing the incorrect rendering of the Feigenbaum tree in C with OpenGL?
  • Thread starter Thread starter computerex
    Tree
The discussion revolves around the rendering of the bifurcation diagram of the logistic difference equation using C and OpenGL. Participants explore potential issues in the code that may lead to incorrect visual output of the Feigenbaum tree structure.
  • One participant suggests that only the last iteration's data point is being displayed, proposing that all iteration values should be plotted to create a complete graphic.
  • Another participant points out a potential issue in the calculation routine, indicating that the x-coordinate is always set to the current k value, which may not be the correct approach for rendering.
  • Concerns are raised about the definition of NUM_OF_ITT as a floating-point value, with participants questioning its necessity and clarity.
  • A participant mentions that the rendering procedure omits transient states, which could affect the visual representation of the bifurcation diagram.
  • One participant shares a link to an alternative explanation of the bifurcation graph, suggesting it may provide clearer insights into the calculations involved.
Participants express differing views on the rendering approach and the handling of iteration data. There is no consensus on the correct method for displaying the bifurcation diagram, and multiple competing ideas remain unresolved.
Some participants note that the implementation may depend on specific definitions and assumptions about the logistic map and its graphical representation. There are also unresolved questions regarding the handling of transient states and the choice of data points for rendering.
computerex
Hello. I am attempting to render the bifurcation diagram of the logistic difference equation in C with OpenGL. I think the math behind it is simple enough, but for some reason I am ending up with a structure that resembles the tree but doesn't look quite like it. I would really appreciate it if someone could point out where I am going wrong. Here is how it should look like:
http://brain.cc.kogakuin.ac.jp/~kanamaru/Chaos/e/BifArea/
http://planetmath.org/encyclopedia/FeigenbaumFractal.html
The following program produces the output attached to this post. As you can see, you can distinguish that the structure seems to be correct.
Code:
#include <stdio.h>
#include <stdlib.h>
#include <gl/glut.h>
#include <windows.h>
#include <math.h>
#define NUM_OF_ITT  100.0 // number of itterations
#define NUM_OF_SETS 1000  //  number of ks that will be tested
double xstart = 0.1;      // x0
double dataPoints[NUM_OF_SETS][(int)NUM_OF_ITT][2]; //
void calculatePlot(double k, unsigned int inx)
	double result = k*xstart*(1.0-xstart);
	dataPoints[inx][0][0]=k;
	dataPoints[inx][0][1]=result;
	for ( unsigned int i = 1; i < NUM_OF_ITT; i++ )
		result = k * result*(1.0-result);
		dataPoints[inx][i][0]=k;
		dataPoints[inx][i][1]=result;
void handleKeyPress(unsigned char key, int x, int y)
	switch (key)
	case 27:
		exit(0);
void initRendering()
	glEnable(GL_DEPTH_TEST);
	glLineWidth(1.0);
	double k = 1;
	double kstep = (4.0-k)/(double)NUM_OF_SETS;
	for ( unsigned int i = 0; i < NUM_OF_SETS; i++ )
		calculatePlot(k, i);
		k+=kstep;
void handleResize(int q, int z)
	glViewport(0, 0, q, z);
	glMatrixMode(GL_PROJECTION);
	glLoadIdentity();
	gluPerspective(45.0, (double)q / (double)z, 1.0, 200.0);
void drawScene()
	glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT);
	glMatrixMode(GL_MODELVIEW);
	glLoadIdentity();
	glTranslatef(-3, 0, -5);
	glColor3f(0.0, 1.0, 0.0);
	// not rendering the transient states
	glBegin(GL_LINE_STRIP);
	for ( unsigned int set = 0; set < NUM_OF_SETS; set++ )
		glVertex2f(dataPoints[set][0][0], dataPoints[set][0][1]);
	glEnd();
		glVertex2f(dataPoints[set][(int)NUM_OF_ITT-1][0], dataPoints[set][(int)NUM_OF_ITT-1][1]);
	glEnd();
	glutSwapBuffers();
void update(int value)
	glutTimerFunc(10, update, 0);
void idlefunc()
	glutPostRedisplay();
void mouse(int button, int state, int x, int y)
int main(int argc, char **argv)
	glutInit(&argc, argv);
	glutInitDisplayMode(GLUT_DOUBLE | GLUT_RGB |GLUT_DEPTH);
	glutInitWindowSize(400, 400);
	glutCreateWindow("Logistcs");
	initRendering();
	glutDisplayFunc(drawScene);
	glutIdleFunc(idlefunc);
	glutKeyboardFunc(handleKeyPress);
	glutReshapeFunc(handleResize);
	glutMouseFunc(mouse);
	glutTimerFunc(100, update, 0);
	glutMainLoop();
	return 0;
Technology news on Phys.org
I think you are only displaying the data point for the last iteration.
Print out say the last few iteration values in the datapoint array, in each call to calculateplot(). When k is below 3, you will find they are all the same. Then, they start to flip between 2 diffeent values. Then they go round a cycle of 4 different values, then 8, etc. Later on, they are chaotic. Later still they will repeat in cycles with other lengths, like 6 and 3.
You need to plot all the different values to make the complete graphic. One way is to calculate say 1000 iterations, to wash out the effect of your choice of a starting value, and then plot say the next 100 iterations. Many of the 100 plotted points will lie on top of each other, but that doesn't matter.
Hello. Thank you for the reply.
Take a look at this:
Code:
This multidimensional array contains the x-y coordinate data for each k that is going to be tested. The number of different k's tested will be NUM_OF_SETS k's. The difference of some k and the next k tested will be 3/NUM_OF_ITT. Here's the routine that precomputes the data for better rendering times. I think the problem may lie here:
Code:
0 <= inx < NUM_OF_SETS. Note how the x coordinate is always set to the k being tested. I am not sure whether this is the right way of doing it. Some implementations plot (g(x), x) where g(x) = X(n+1) = k*Xn*(Xn-1). Others simply have the k being tested as the x value. Other still use (x, g(x)).
This is the rendering procedure, which is relatively simple. Note, right now for each k being tested the x value for each point is k itself, and only y varies. And so you would expect to see a vertical line for each k, with the points between dataPoints[set][0] and dataPoints[set][NUM_OF_ITT-1] being transient states. Therefore those points are not rendered here. However, that data is still available and can be rendered. Indeed originally it was rendered, but I saw only vertical columns connecting the top outline and the bottom outline. So I simply decided to omit those points from rendering.
The mechanism of rendering is simple: We loop through all the sets (the data for all the k's tested) and render a line strip using the first point calculated. Then the same procedure is repeated, rendering the last data point in the array for each set.
Code:
glEnd();
	glVertex2f(dataPoints[set][(int)NUM_OF_ITT-1][0], dataPoints[set][(int)NUM_OF_ITT-][1]);
glEnd();
I don't know what I am doing wrong. I am sorry, but I really have no background education of dynamic systems (being a high school senior). I just love math/realtime computer graphics. Further help would be much appreciated.
Minor points
Why is NUM_OF_ITT defined as a floating point value?
Code:
This doesn't make sense, especially since you have to cast it to int when you declare your dataPoints array.
BTW, iteration doesn't have any double t's in it, which makes NUM_OF_ITT a bit more difficult to understand than it needs to be.
Mark44 said:
Minor points
Code:
I thought I'd have to do some arithmetic later that'd involve casting the constant to a floating point later on, and I was always bad at spelling ;)
In any case, you can be rest assured that neither of the aforementioned minor programming inconveniences are the cause of the issue. Do you have any other ideas :) ?
I wasn't able to open the first link you posted. I was able to open the planetmath.org link, however.
Another (and clearer, IMO) explanation that seems closer to what you're trying to do is here: http://mathforum.org/advanced/robertd/bifurcation.html
The bifurcation graph represents the results of repeated calculating [itex]\mu[/itex]x(1 - x) for values of [itex]\mu[/itex] and x. (You're using k for [itex]\mu[/itex] and y for x.)
It works by picking a value of [itex]\mu[/itex], and a starting value of x. The next value of x is obtained by substituting it into the expression [itex]\mu[/itex]x(1 - x). For some values of [itex]\mu[/itex] the iterated values converge to a specific number.
For example, if [itex]\mu[/itex] is 2 and we start with x = .25 and calculate 2*.25*.75, the next x value will be .375. Putting this value in for x, the next x value will be .46875. After a few steps you get values that keep repeating, .5, .5, .5. So one point on the graph you're trying to get will be (2, .5). Similarly, when [itex]\mu[/itex] is 2.5, the iterations settle down to .6, so another point on the graph is (2.5, .6).
For values of [itex]\mu[/itex] from 1 to about 3, iteration produces a single value. For larger values of [itex]\mu[/itex], iteration can produce two values, then four values, then eight values, and so on, and that's what gives you the bifurcations, or forks in the diagram. When [itex]\mu[/itex] is around 3.5, you start to get cycles of four different iterated values, so the bifurcation graph will show four different points for a while.
Now maybe you know this or maybe not. Your code doesn't contain may comments, so it's hard to tell what you're doing, particularly with your three dimensional array. It would be nice to have a comment saying what each index in that array represents.
I am sorry :( I know it can be a nightmare trying to interpreted undocumented code, so I will try to explain to the best of my abilities what I am doing in the code:
Code:
#define NUM_OF_IT  100       // number of iterations
double dataPoints[NUM_OF_SETS][(int)NUM_OF_IT][2]; //
The basic algorithm I am following is:
1) Pick some starting x value that is below 1.0. This is xstart in the program (0.1).
2) Pick some K <= 1 <= 4
3) Iterate using a for loop NUM_OF_IT times. In each iteration, use the logistics difference equation to calculate the y value, and store it. This y value will be used in the next iteration. For the first iteration, the y value is calculated as: y = K*xstart*(1-xstart). This is stored in the dataPoints array, which has this structure:
dataPoints[index for data for some unique K][coordinate pair calculated in the ith iteration] = [k value (constant for this index), y value]
4) Render to the screen
This will become clearer when taking a look at the following code:
Code:
// This is where the iteration takes place
// inx is the index for the dataPoints array where the data for this unique k will be stored
        // this is the base case
        // all subsequent values of y will be calculated using this
        // dataPoints[inx][i][0] will [i]always[/i] contain k
        for ( unsigned int i = 1; i < NUM_OF_IT; i++ )
                // the previous result is used to calculate the new value for y
		dataPoints[inx][i][1]=result; // y is stored in the 1st element of the 3rd
                                                      //  dimension of dataPoints array
Code:
        // standard OpenGl initialization.
	glLineWidth(1.0);
        // Here is where the dataPoints array is actually populated with data.
        // the first k we use is 1. Then we increase k by a constant quantity
        // so the final k is <= 4
	double k = 1;
                // The data for this particular k is stored in the ith element of the
                // first dimension of the dataPoints array
                // advance k by the constant quantity
		k+=kstep;
Code:
        // From what I have seen, some implementations only render the
        // x-y values of the first iteration and the final iteration. This is what I have
        // done here.
        // pseudocode: "for each value of K, render the point calculated in the first iteration"
	glEnd();
        // pseudocode: "for each value of K, render the point calculated in the last iteration"
		glVertex2f(dataPoints[set][(int)NUM_OF_IT-1][0], dataPoints[set
[(int)NUM_OF_IT-1][1]);
	glEnd();
I hope this was enlightening. I am experimenting locally, hopefully I'll come up with a working solution soon. In the meantime, and help will be very much appreciated.
I am the biggest idiot in the world. As opposed to drawing lines, I should have simply drawn points. The structure seemed correct because it was. There was simply extra information there. I hope I am making sense. Thanks for the help all. Attached picture + the working source below.
Code:
#include <stdio.h>
#include <stdlib.h>
#include <math.h>
#define NUM_OF_ITT  1000.0 // number of itterations
	switch (key)
	case 27:
		exit(0);
	glLineWidth(1.0);
	glPointSize(1.0);
	double k = 1;
		k+=kstep;
	glLoadIdentity();
void drawScene()
	glLoadIdentity();
		glBegin(GL_POINTS);
		for ( unsigned int i = 0; i < NUM_OF_ITT; i++ )
			glVertex2f(dataPoints[set][i][0], dataPoints[set][i][1]);
		glEnd();
	glutSwapBuffers();
void idlefunc()
	initRendering();
	glutMainLoop();
	return 0;
Well, it's not quite right yet, because you have those strange lines from the bottom left hand corner.
They are the points when you "start up" the iteration from x = 0.1, until it settles down.
If you change 0.1 to a differrent value (say 0.9) you will get a different pattern of those lines.
To get rid of them completely, change the line in drawscene() from
to something like
for ( unsigned int i = NUM_OF_ITT/2; i < NUM_OF_ITT; i++ )
to skip over the first points you calculate.
I thnk Japan is off-line right now :rolleyes:
I didn't look at the link that closely to notice that it was a site in Japan. They have other problems right now...
The strange thing is, the site was working perfectly when I made the first post. It stopped responding very soon after.
