Understanding the Significance of 'Square' in Quantum Mechanics Potentials
  • Context: Undergrad
  • Thread starter Thread starter spaghetti3451
    Square
The discussion revolves around the significance of the term 'square' in the context of quantum mechanics potentials, particularly focusing on square potential wells and barriers. Participants explore theoretical implications, mathematical reasoning, and conceptual clarifications related to the behavior of wavefunctions in these models.
  • Some participants suggest that 'square' refers to the appearance of the plot of potential (V) versus position (x), noting that it signifies a discontinuous jump in potential values.
  • Others argue that the term may not accurately represent the shape of the potential, as the finite square well does not form a perfect square.
  • Concerns are raised about the implications of infinite potential outside the well, questioning why a particle cannot exist in a region of infinite potential if it lacks infinite energy.
  • Some participants challenge the classical interpretation of quantum mechanics, particularly regarding energy conservation and tunneling phenomena.
  • There is a discussion about the relationship between potential energy (Vu) and kinetic energy in the Schrödinger equation, with questions about how these terms interact mathematically.
  • One participant mentions the Heisenberg uncertainty principle in relation to tunneling, suggesting that energy deviations can occur within certain time constraints.
  • Questions arise about the meaning of terms like 'steady state' and the mathematical processes involved in understanding limits and infinities in quantum mechanics.
Participants express multiple competing views regarding the interpretation of 'square' in potentials and the implications of infinite potential. The discussion remains unresolved, with no consensus on the significance of these concepts or the validity of classical principles in quantum contexts.
Limitations include unresolved assumptions about the nature of potential energy in quantum mechanics, the dependence on definitions of terms like 'steady state,' and the mathematical steps involved in discussing infinities and limits.
This discussion may be of interest to students and educators in quantum mechanics, as well as researchers exploring foundational concepts in quantum theory and its interpretations.
spaghetti3451
Square potentials (finite or infinte, well or barrier) are used in intro Quantum Mechanics courses. My question is:
What does the word 'square' signify?
My other question:
In the infinite square potential well model, the wavefunction outside the well is zero. Two reasons are usually put forward:
1. V is infinite. So Vu is infinite unless u = 0. (I don't understand what's still wrong with Vu being infinite.)
2. The particle can't be in a region of infinite potential if it lacks infinite energy. (Why not? Why should classical principles dictate quantum rules? Moreover, in the finite square well model, there is a finite probability of the particle being within the potential barrier? Isn't that a violation of the classical principle we are using in the above argument?) Therefore, u = 0.
Thanks for any help.
Square refers to the appearance of the plot of V versus x.
failexam said:
My other question:
Energy is conserved in both classical mechanics and quantum mechanics. Assuming that the particle inside the well has finite energy, and the potential outside the well is infinite, then when the particle is outside the well, it will have infinite energy, which will violate the conservation of energy. Vu represents the potential energy of a particle outside the well. The other term in the Schroedinger equation represents the kinetic energy. Assuming that the total energy is finite and positive, if Vu were infinite, the kinetic energy would have to be negative infinity (steady state), which is impossible.
There is nothing of the plot of V versus x that reminds me of a square, actually!
But isn't that exactly what happens in quantum tunneling? How does the particle get the extra energy to jump into a potential barrier. Isn't that in violation of the principle of conservation of energy?
Howcome Vu is potential energy? I thought V was?
How can the other term represent the kinetic energy?
How can positive and negative infinity add to give a finite positive number?
What does 'steady state mean'?
Thanks for all the help!
You're not using any classical principles. Since you've apparently solved the finite square well, why don't you just let [tex]V \rightarrow \infty[/tex] and see what happens?
You're thinking about it classically. How do you know its potential energy (i.e. the location) and the kinetic energy (i.e. the momentum) at the same time?
Square refers to the fact that the potential jumps discontinuously from one value to another, so that the graph of V(x) has a "square" corner. Compare to e.g. a harmonic potential well, whose graph is a parabola.
When the potential is finite, the "well" forms three corners of a rectangle. I wouldn't worry too much about the fact that it doesn't form a square. Its just a name.
I may be wrong here, but as I remember, the time that a particle spends outside the well (delta t) is such that the Heisenberg uncertainty principle is obeyed. In other words, the energy deviation times the time interval is less than Planck's constant/2.
A better way to say it is that they are the potential energy and kinetic energy terms in the Schroedinger equation.
Its a limiting process. For example, as n grows larger, (n+1)^2- (n^2+2n) equals 1. Each term on the left grows larger without bound.
It means no change in time.
Thanks for all the help![/QUOTE]
  • · Replies 22 ·
  • · Replies 16 ·
  • · Replies 18 ·
  • · Replies 26 ·
