Infinity corrected lens - expanding before tube lens?
The discussion revolves around the optical setup for a project combining Raman microscopy and optical tweezers. Participants are addressing issues related to light divergence from an infinity corrected lens and its implications for capturing light effectively in the setup.
  • Experimental/applied
  • One participant describes their setup involving a NIKON infinity corrected 100x objective and a tube lens, noting that while the back reflected laser beam is collimated, the white light diverges significantly, capturing only 25% of the light.
  • Another participant inquires about the use of white light and whether a condenser lens is being utilized to focus the light onto the sample.
  • A participant mentions using a 10x condenser objective and previously a 1.25 NA condenser, indicating that the setup is not using Kohler illumination.
  • One contributor suggests that the divergence of the white light is expected to allow imaging of off-center objects and mentions the possibility of spurious light being rejected by the tube lens due to the objective's limited field of view.
  • Another participant proposes moving the tube lens closer or using a larger diameter tube lens as potential solutions to the divergence issue.
  • A participant expresses confusion about the rapid expansion of light from the infinity objective and questions how to ensure the trapping beam is centered and perpendicular to the back aperture of the objective.
Participants do not appear to reach a consensus on the cause of the white light divergence or the best approach to address it. Multiple viewpoints and suggestions are presented, indicating ongoing uncertainty and exploration of the issue.
Participants mention various optical components and configurations, but there are unresolved aspects regarding the control over divergence angles and the specific effects of different condenser objectives.
donroy81
Hello folks, I am on a project that involves combining Raman microscopy + optical tweezers, and I made a setup over the past year. All of this is home built on minimal funds so its not the neatest of all setups. It involves an upright microscope (coupled to trapping laser) and collecting the back reflected Raman signal at 180o and also the optical image along the same axis.
To make things easy i converted to a NIKON infinity corrected 100x objective and added a tube lens. While the back reflected laser beam from the laser seems to be collimated when the sample is at focus, the white light (illuminated from the bottom) diverges very fast so I catch only 25% of l the light on my tube lens (which needs to be 200 mm away anyway). Should not the white light collected be the same size as the back aperture of the objective (8mm) : I need to catch all the light on 25mm dichroic filters (which eliminate the laser).
Why is the white light expanding out of the objective - Is something wrong? We are a spectroscopy group and not a microscopy one, so all this is pretty new to me and my research group. Any help is appreciated.
Science news on Phys.org
How are you using the white light? Is there a condenser (a lens that focuses the light onto the sample)?
Hi Andy, thanks for replying. I have a 10x (.25NA)objective as a condenser, I was using a 1.25 NA condenser before with the same effect.
I know its not Kohler illumination (since the objective is 1.25 oil) but this is also what Thorlabs uses in their "optical trapping kit".
I'm not surprised that the white light is diverging- it has to, in order for the objective to image objects that are off-center. Some of the diverging light may be 'spurious', in that it would normally be rejected by the tube lens- objectives have a limited field of view. Have you (without the trapping beam) simply looked at the image your setup produces?
I'm not sure how much control you have over the divergence angle (does it change between using the 0.25 NA and 1.25 NA condensers? Can you ring up a field stop?), so one solution may simply be to move the tube lens closer (or use a larger diameter tube lens). AFAIK, the tube lens on my Leica is about 100mm off the back aperture of the objective.
Andy, sorry for the delay, I wanted to review everything once. I also went over your conversation with Kubikat. I would need to show you some pictures to explain. Slide1 is a closeup of the problem region.I have 1" optics, the filter and the mirrors before the tube lens. DSC09636 gives you another take on it. Everything was fine when I was using a 160mm objective and a complete Nachet, we decided that the infinity will help with the raman and hence this. 2" dichroics run too many $$. In anycase, I don't see why a parallel flux of light from an infinity objective with a back aperture would expand so fast to 2".
Additionally, if I may, I would like to know a few more things, for starters : how do you check that the trapping beam is on center of the back aperture of the objective and perfectly perpendicular to it?
  • · Replies 16 ·
