Which Form of Radiation is Most Damaging to Human Cells: Alpha, Beta, or Gamma?
The discussion revolves around the comparative dangers of alpha, beta, and gamma radiation to human cells, focusing on their ionizing and penetrating powers. Participants explore the implications of these properties in different exposure scenarios, including external and internal radiation sources.
  • Some participants note that while ionizing power decreases from alpha to gamma, penetrating power increases, raising questions about which factor is more critical in assessing damage to human cells.
  • It is suggested that for a given dose, gamma and beta radiation may have similar biological responses, while alpha radiation tends to be more damaging, particularly when ingested or inhaled.
  • Concerns are raised about the need for specifics regarding how doses are received, as alpha and beta radiation striking the skin are considered relatively harmless.
  • Alpha radiation is highlighted as particularly dangerous when inhaled or ingested, with some participants emphasizing its high ionization potential and associated risks, such as lung cancer from radon gas.
  • Some participants challenge the assertion that alpha radiation is dangerous from external sources, noting that it does not penetrate the skin effectively.
  • There is a discussion about the energy levels of alpha particles, with some participants arguing that higher energy alphas can penetrate more deeply, while others question the relevance of such high-energy scenarios to typical exposures.
  • Participants discuss the weighting factors for different types of radiation, with alpha particles assigned a higher factor due to their potential for causing biological damage, despite their limited penetration from external sources.
Participants express differing views on the relative dangers of alpha, beta, and gamma radiation, particularly regarding external versus internal exposure. There is no consensus on which form of radiation is definitively the most damaging, as the discussion remains unresolved with multiple competing perspectives.
The discussion highlights the complexity of assessing radiation damage, including the importance of exposure context, energy levels, and biological responses. Limitations in assumptions about typical exposure scenarios and the relevance of high-energy particles are noted.
joeyjo100
Just been revising radiation for an upcoming exam, and was wondering which form of radiation, [tex]\alpha[/tex], [tex]\beta[/tex] or [tex]\gamma[/tex] is the worst to be exposed to?
Ionising power decreases from alpha to gamma, but penetrating power increases from alpha to gamma. Which is more important when considering how much damage each form can do to human cells?
Biology news on Phys.org
What is exactly being held constant here? Typically, for a given dose (energy deposited per unit mass) the gammas and electrons will have the approximately the same biological response, while the alpha will tend to be more damaging.
Your question is too open. You need to have some specifics about how the doses were recieved. If you have alpha or beta radiation striking your skin, its pretty much harmless.
Shalis said:
It is short but good efforts that you mention the effect of the Radiation on human body.
But the recent study realize that If you touch your head with Earth These Radiation transfer to earth, just like Muslims do in prayer.
References please. See PF rules.
Hi there,
As Drakktih said, the harmfulness of radiation on the human body depends if you are talking about external or internal radiation.
If you are standing next to a radioactive sources, the only real danger comes from the gamma radiation. The alpha and the beta are stopped pretty much by the first layers of skin.
If you inhale or ingest some radioactive materials, then the alpha can start causing serious damage. Although, never neglecting the effects of beta and gamma, the alpha radiation will probably be the most harmful for the body.
Cheers
The weighting factors for x-rays, gamma rays, electrons, positrons and muons is 1.
Neutrons range from 2 to 20 depending on their energy.
Alpha particles are 20!
Consequently, alpha radiation is far more dangerous to human health.
X-rays, gamma rays and electrons generally form diffused ions when they strike human cells. Normal healthy cells are well equipped to easily repair such ions.
Alpha radiation on the other hand is between 10 to 1000 times more concentrated and likely to cause chromosome damage; especially if injected or inhaled.
Radon gas (alpha radiation) is the 2nd leading cause of lung cancer while electrons and x-rays can be used to cure a wide variety of cancers.
This statement is very misleading. The rest of your post is fine.Alphas can also be used in radiation therapy. It is exactly the higher ionization that makes it effective.
Hi there,
Alpha radiation from an external source does not penetrate the first layers of the body. How can it be dangerous if it does not penetrate, even with a weighing factor of 20?
Cheers
fatra2 said:
Hi there,
Cheers
I believe everyone here is assuming that by "alpha radiation" one means the alpha particle emitted during radioactive decay. The energy typical of these alphas is about 5 MeV. At 5 MeV, an alpha only travels about .004 cm in water (a proxy for tissue).
The difference is that, at higher energies, the alphas can penetrate much more deeply. For instance, a 1 GeV alpha has a CSDA (continuous slowing down approximation) range of approximately 38 cm.
fatra2 said:
Hi there,
Cheers
Remember that the wieght factor of 20 is for damage to biological tissue. If it isn't in your body, then it doesn't even count as exposing yourself to it.
Hi there,
1GEV! Naturally occurring decays rarely decay with that much energy, firstly. Secondly, try to imagine the penetrating power and damage done by a 1GeV photon.
Why not talk about TeV or PeV as a matter of talking. Of course, if you are expose to radiation with this type of energy, it is hard to talk about radiation protection. Their penetrating power is so great that the only was to protect against, is to run a galaxy far, far away.
Cheers
fatra2 said:
Hi there,
Cheers
Photons are low LET, that is what makes them so penetrating. But that means at high energies they do not lose as much of their energy per unit track length. So a 1 GeV photon will lose less energy (lower dose) passing through a person than a 1 GeV alpha particle. So the photon penetrates farther, but dose less damage.
A 1 GeV photon still has a weighting factor of 1 compared to 20 for an alpha. So for a given dose, the alpha is much more damaging.
You wanted to know why we would even consider an Alpha having a weighting factor of 20. It can penetrate at high energies. LBNL ran a radiotherapy beam of alphas for 30 years or so. They treated over 2000 patients here. Need weighting factors for radiotherapy. Radiotherapy uses typically uses higher energies than 5 MeV for protons and heavier ions.
In addition, there is a high energy background of heavy ions permeating the solar system called galactic cosmic rays (energies from MeV to TeV are typically considered). This radiation environment interacts with the space station and the shuttles. It contributes to the total dose received by astronauts.
  • · Replies 33 ·
  • · Replies 16 ·
  • · Replies 20 ·
