Mathematica - Label plot ticks using strings
The discussion focuses on labeling tick marks in a ListSurfacePlot3D graphic using strings in Mathematica. User Christina seeks to label ticks on the x, y, and z axes with specific strings corresponding to data points. The provided code snippet demonstrates an attempt to label the y-axis but fails to display labels on the x and z axes. A solution involves ensuring the data falls within the specified tick range and utilizing the PlotRange option for proper visibility.
  • Familiarity with Mathematica syntax and functions
  • Understanding of ListSurfacePlot3D graphics
  • Knowledge of tick mark customization in Mathematica
  • Basic grasp of data ranges and plotting parameters
  • Explore the use of PlotRange in Mathematica for effective data visualization
  • Learn about the Ticks option in Mathematica for custom tick labeling
  • Investigate the Generalizations & Extensions section of the Mathematica documentation
  • Research functions for generating dynamic tick labels based on data ranges
Mathematica users, data visualizers, and anyone looking to enhance their 3D plotting capabilities with custom tick labels.
ChristinaJ
All,
I have a ListSurfacePlot3D graphic and wish to label the tick marks using strings. For example if I have X={x1,x2,x3} I would like to label each tick mark at that point with a string, i.e. x1="a", x2="b" etc.
I would also like to know how to take a list of strings and distribute them evenly along the axis.
So far I have
ListSurfacePlot3D[ data , BoxRatios -> {1,1,1}, Ticks ->{{{1,"a"} , {2,"b"} , {3,"c"}} , {{1,"d"} , {2,"e"} , {3,"f"}} , {{1,"h"} , {2,"j"} , {3,"k"}}} ]
This gives the labels "d" , "e" ,"f" on the y-axiz but nothing on the x or z-axes.
Any help gratefully received.
Many thanks,
Christina
Your Ticks construction is fine -- it's probably that your data is outside the range you gave the ticks. Put in an explicit PlotRange to check.
Maybe you should look at writing a function that takes the min and max of the axis and generates the ticks you want. See the Generalizations & Extensions section of http://reference.wolfram.com/mathematica/ref/Ticks.html
