Radioactive Dating Question, Half-Life.
In radioactive dating, scientists determine the initial quantity of isotopes like Carbon-14 and Potassium-40 by measuring the current ratio of these isotopes to stable isotopes in a sample. For instance, if a rock has undergone three half-lives of Carbon-14, equating to 17,190 years, the initial amount of Carbon-14 is calculated to be eight times the measured amount. Carbon-14 dating is effective for organic materials and has a maximum dating limit of approximately 57,000 years due to its half-life of about 5,700 years. For older samples, other methods such as Argon-39/Argon-40 dating are utilized, which rely on the cooling of molten rock to establish the starting point for decay measurements.
  • Understanding of radioactive decay and half-lives
  • Familiarity with isotopes, specifically Carbon-14 and Potassium-40
  • Knowledge of radiometric dating techniques
  • Basic principles of geology related to rock formation and cooling
  • Research the principles of Carbon-14 dating and its limitations
  • Learn about Argon-39/Argon-40 dating and its applications
  • Explore the concept of closure temperature in radiometric dating
  • Investigate other isotopes used in geological dating methods
Geologists, archaeologists, and researchers in the fields of paleontology and environmental science will benefit from this discussion, particularly those interested in the methods and limitations of radioactive dating techniques.
Wreak_Peace
I apologize for the simplicity of this question in relation to the others on this site.
But I've been curious, and haven't been able to find an answer.
In Radioactive Dating, how do scientists know how much of a certain isotope (ie. Carbon-14, Potassium-40) was there to start with in an object..
For example, if a rock was found to have gone through 3 half lifes of Carbon-14, being 17,190 years old, how would scientists know that the amount of Carbon-14 which was in the rock when it was formed is eight times what it was when they tested it?
Sorry if I'm being confusing and for looking idiotic for posting such a simple question.
Thanks!
Thanks!
Carbon dating is used for organic material, and the trick is that you assume that a living organism is constantly replenishing its supply of C-14, so the ratio of C-14 to the other carbon in the organism is equal to the naturally occurring ratio (about 1 atom in 1 trillion is C-14). However, once the organism dies, the C-14 is no longer replenished, and the ratio of C-14 to non-radioactive carbon begins to decrease as the C-14 decays. So, by measuring the ratio of C-14 to other carbon, you can tell how long ago something died. However C-14 dating can't go back very far, because the half-life of C-14 is only around 5700 years. I think the limit of C-14 dating is around 10 half-lives or so, so it can't be used to reliably date samples older than about 57000 years.
Samples of rock are typically dated using other radioisotope ratios (e.g. Ar-39/Ar-40 dating), but as far as I know, each one of those requires a similar assumption about when the "clock" for the decay started. With argon dating, it has to do with cooling of molten rock ... the red-hot liquid magma will exchange argon with the atmosphere, so while the rock is liquid, the ratio stays constant at the natural abundance. However, when the rock cools, it passes through something called the closure temperature. Below this temperature the exchange process stops, and that is the point where you start counting.
Ohh. So there are ratios. Thanks! that clears things up!
  • · Replies 20 ·
