Use of Nuclear power in space exploration.
The discussion revolves around the potential use of nuclear power for space exploration, particularly in propulsion systems. Participants explore various concepts related to nuclear thermal rockets, ion thrusters, and the feasibility of using nuclear energy to achieve higher speeds and longer distances in space travel.
  • Some participants note that while nuclear power is efficient for submarines and aircraft, the lack of a medium in space complicates its use for propulsion.
  • One participant suggests that nuclear power could create extremely high temperatures and pressures for thrust, potentially allowing for faster spacecraft.
  • Another participant mentions that nuclear thermal rockets could be more efficient than chemical rockets, using pure hydrogen as fuel.
  • There is a proposal to use a nuclear reactor to power a laser for a solar sail, with some arguing about the effectiveness of this method compared to traditional propulsion.
  • Concerns are raised about the practicality and safety of launching nuclear reactors into space, with political implications also discussed.
  • Participants debate the mechanics of light sails and laser propulsion, with differing views on the efficiency and feasibility of these concepts.
Participants express a range of opinions on the use of nuclear power in space exploration, with no consensus reached. Some support the idea of nuclear thermal rockets, while others question the practicality of using lasers and solar sails for propulsion.
Participants highlight various assumptions about propulsion methods, the efficiency of different energy sources, and the technical challenges of implementing nuclear power in space. There are unresolved questions regarding the effectiveness of proposed systems and the implications of using nuclear technology in space missions.
This discussion may be of interest to those studying aerospace engineering, nuclear physics, or anyone curious about advanced propulsion technologies and their applications in space exploration.
shashankac655
I read that nuclear power when used for propulsion of a vehicle can be very efficient for example nuclear powered submarines and aircraft carriers can run over twenty years without refueling and can travel enormously long distances with the fission of a few kilograms of uranium,but why is this source of power not used for space exploration,is not possible to use nuclear energy to send spacecraft s(maybe with human crew),at much greater speeds and to much far away destinations??
hi shashankac655! :smile:
the main problem is that submarines have water outside for the propellers to push against, and aircraft have air outside either for the for the propellers to push against, or for the jet engines to suck in and expel
but there's almost nothing in space, so no matter how powerful or efficient a spaceship's engine is, it needs to bring stuff with it to chuck out the back! :wink:
this stuff is not needed in nuclear-powered vessels on Earth, which is why they can be so efficient
(and fuel is preferred to household trash, builders rubble, etc, in rockets, because fuel can power itself)
How does a conventional spacecraft move in space ?? it also requires some stuff to be ejected out to move forward right??...the stuff that ejected out consists of superheated gases forced out of a tiny hole to create thrust right??..if this is the way spacecraft s move,we can use nuclear power to create extremely high temperatures and pressures of the gas that is to be forced out,can this make the spacecraft faster??
Since space doesn't have any medium to slow the craft down,single big push or impulse may be enough to travel certain a distance and if it slows down due some reason like gravitational force due to other planets or asteroids something else,another big push can set it in a high velocity again. This kind of a spacecraft may be very bulky,but can it be economical??
Sorry, I prefer a rocket that expels builder's rubble. Preferably over the neighbor's yard.
Thanks Borek, has NASA completely forgotten about NERVA is it completely dead?...
I am waiting for China to do something big (may be a manned lunar mission),big enough to make the US government to seriously consider a manned Mars mission,this will be the dawn of a new space race!
My guess would be because ion thrusters have a higher specific impulse (mass efficiency) for the tasks such things are needed right now. They can also be nuclear powered, though...
http://en.wikipedia.org/wiki/Ion_thruster
Also, politics no doubt played a role. NASA takes a lot of heat when they launch nuclear reactors into space.
What you're proposing is called a nuclear thermal rocket. It's much more efficient than chemical rockets because it can use pure hydrogen (more efficient) and it can get hotter than the combustion temp of hydrogen/oxygen. The downside is you need to launch a nuclear engine on top of 600,000 lbs of explosive material built by the lowest bidder.
Once in space you can use the nuclear reactor as a method of powering a hyper strong laser at a forward mounted solar sail. Even more effective once upto its opperating speed of abou 0.5c.
That doesn't really make sense. Why would you use a laser for a solar sail? A concentrated beam leaves most of the sail unused and requires a hyper-laser-proof patch where it's being hit.
But more imporatantly, conservation of momentum says you might as well fire the laser backwards and not have any solar sail. Same effect but easier.
Furthermore, photons aren't very "efficient" at providing thrust. Where did you get 0.5c from, and why does going faster make it more "effective"?
Or are you talking about a laser on Earth, shining on the spacecraft somewhere in space?
NO NO NO. Through realtavistic physics photons can exert a force when reflected but the force generated by fireing a laser in the oppisite direction is neal to non (i read some where its like 300 Mw for 1 Newton of thrust useing photon ejection out the rear of a vessel). Second off i under simplified useing beam divergence you can illuminate the intire sail, it just has to be far enough away, so optical systems to increase beam divergence could be used. And as fore effectiveness i used the wrong wording, my point was once upto 0.5c the craft can merely coast. As for the maxium speed a light sail can go faster it depends on how strong the light is and how long the light at that intensity is hsined on the sial. So i say 0.5c because its incredably fast and due to time dialtions radial curve upwards and 0.5c outside observence on the trips duration would only be about 3 Earth days to 1 of the ship traveling (i hope i don't have said dilation backwards so don't take that part to seriusly).
Hmm. I'm still deeply suspicious. If you look at the spaceship with sail as a black box, then it's simply another spaceship with photons coming out the back. Why does it matter if the sail looks like a conventional solar sail, or if it's just mirrors inside the laser device itself? The photons are still photons regardless of where they came from.
I missed the obvious idea of spreading the beam out. But if you do that, why do you need a laser? Why not any other light source?
It won't work, just like it is not possible to propel sailboat with a fan blowing into sail.
You really should start with basic physics before fantasizing about nuclear and high energies.
No. It would work. If the sail is a mirror (which is a good idea anyway) then the light ends up being reflected backward. But I don't see any advantage over just pointing the laser backwards in the first place.
You are correct about physics, but I doubt reflection is what OP had on mind.
Its not mirrors, mirrors don't reflect light the abosrb large quantities of it, these being the ones you would see youre reflection in. I am proposing highly reflective surface like milar, which reflet 97% + of the light that hits it. The idea of haveing a laser on bored the ship, is to sercumvent the issues of beam propulsion; because typical light sail propulsion becomes less effecient the further from its light source. And a laser would be better than most other lighting techniques because it would be a single very strong light source spread over the intire sial through amplified bem divergrence.
That's still a mirror. And it doesn't matter if you have 95% or 99.9% of the light reflected, an extra couple of percent efficiency isn't going to make or break such a different design.
I'm not sure if you're trying to say something but lacking suitable words, or just making it up. What you wrote has no meaning. Any light source can be made into a wide beam. What's the advantage of a single source if you then spread it out? You might as well have more/bigger sources and then you can get even more power without overheating them. What are the issues of beam propulsion? How does reflecting the beam circumvent them? Be aware that a laser can have mirrors internally anyway. Just about every directed light source has internal mirrors. How are they different from a solar sail? 95% vs 98% isn't a significant difference.
If you're talking about the double momentum imparted to a solar sail by having the light reflected vs just absorbed, then this doesn't take advantage of that because the forward-pointing laser will retard the craft's motion, the light needs to be reflected to compensate for that.
  • · Replies 21 ·
  • · Replies 0 ·
  • · Replies 32 ·
