Find Sum of Series Using Power Series
The problem involves finding the sum of the series sigma (n=1 to infinity) (-1)^(n-1) * [n/(4^(n-1))] using the power series representation of 1/(1+x). The original poster expresses confusion about how to start the problem.
  • Participants discuss differentiating the power series and substituting values. There are questions about the implications of differentiating term by term and how it affects the series. Some participants explore the relationship between the series and the original power series.
Participants are actively engaging with the problem, offering guidance on differentiation and discussing the implications of changing the series' starting index. There is a recognition of the need to clarify the relationship between the original series and the differentiated series.
Some participants express uncertainty about the starting index for the series after differentiation and whether adjustments are needed for the original problem setup.
Rapier
Find the sum of sigma (n=1 to infinity) (-1)^(n-1) * [n/(4^(n-1))] using the power series 1/(1+x) = sigma (n=0 to infinity) (-1)^n * x^n.
1/(1+x) = 1 - x + x^2 - x^3 + x^4 + ... + (-1)^n * x^n
The problem suggested to differentiate both sides and then substitute 1/4 for x.
I am totally confused and don't even know where to begin.
You know how to differentiate right:
[tex] \frac{d}{dx}\frac{1}{1+x}=-\frac{1}{(1+x)^{2}}[/tex]
I am sure you know how to differentiate [itex]x^{n}[/itex], what do you get if you do this?
d/dx (x^n) = n * x^(n-1)
Right, so if you differentiate the series term by term (which you're allowed to do as long as you're within the radius of convergence), what do you get?
I'm not sure I understand the question.
Which series?
Maybe I'm just not understanding the original question.
1/(1+x) can be rewritten as sum (n=0 to infinity) of (-1)^n * x^n.
I believe the question is asking me to take the sum (n=1 to infinity) of (-1)^(n-1) * n/4^(n-1) and come up with a small simple equation to determine its sum using the pattern of 1/1+x as a template. Yes?
I know that if I take x^n and differentiate it I get n/x^n-1, which looks exactly like my n/4^(n-1). Does that mean that the sum of my series is nothing more than 1 - 1/4 + 1/16 - 1/64? Do I need to make an adjustment to my n values because my sum starts @1 and the original starts @0?
Differentiating the series:
[tex] \sum_{n=0}^{\infty}(-1)^{n}x^{n}[/tex]
is
[tex] \sum_{n=1}^{\infty}(-1)^{n}nx^{n-1}[/tex]
Now what is the above equal to? (hint, we have derived it before)
Do exactly what was suggested. What do you get if you differentiate the lefthand side? What do you get if you differentiate the righthand side? Then plug in x=1/4. What do you get? How is it related to the original question?
is
Since I differentiated the right side, I have to differentiate the left side, neh?
So that will equal -1/(1+x)^2?
I'm trying not to feel really stupid, and I'm just so frustrated. I greatly appreciate all your help.
EDIT: When you differentiate do you change the starting value for n? Since I'm not differentiating n (-1)^n stays (-1)^n, shouldn't it?
EDIT EDIT: Sum = - 16/25?
Correct, now following your suggestion, set x=1/4, what will the series look like?
This is my differentiation:
The series was listed as:
[tex] \sum_{n=1}^{\infty}(-1)^{n-1}nx^{n-1}[/tex]
Does the exponent on the (-1) change when differentiated?
But to answer your question, the series should be:
1 -1/2 + 3/16 - 1/16 + ...
The idea here us to note that [itex](-1)^{n-1}=(-1)^{n+1}[/itex] and you have a minus coming from the LHS.
OH! I see that! If I divide (-1)^n by -1, I get (-1)^n-1. DUH!
That is how it comes up with being 1/(1+x)^2.
That makes sense.
So, now you can tell us what the sum of the series is?
hunt_mat said:
so, now you can tell us what the sum of the series is?
16/25!
Well done!
hunt_mat said:
Well done!
Thank you SO much for your patience and help. Not only did I understand what I did I can do it on other problems!
  • · Replies 22 ·
