How can I estimate the bending stress for a hollow tube under uniform load?
The discussion focuses on estimating the bending stress for a hollow tube with a diameter of 38 mm and a thickness of 4 mm subjected to a uniform distributed load (UDL) of 500 N/m². The material is mild steel with a Young's modulus (E) of 200 GPa and a Poisson's ratio of 0.3. Participants suggest using Castigliano's method for statically indeterminate structures and propose approximating the problem as a simply supported beam to obtain upper and lower bounds for the bending stress and deformation. Finite Element Analysis (FEA) in 3D is also recommended for validation.
  • Understanding of bending stress calculations in structural engineering
  • Familiarity with Castigliano's theorem for statically indeterminate structures
  • Knowledge of Finite Element Analysis (FEA) principles
  • Basic concepts of material properties, including Young's modulus and Poisson's ratio
  • Research the application of Castigliano's theorem in structural analysis
  • Learn how to perform Finite Element Analysis (FEA) for bending stress evaluation
  • Study the behavior of simply supported beams under uniform loads
  • Explore material property implications on bending stress in mild steel
Structural engineers, mechanical engineers, and students studying material mechanics who are involved in analyzing bending stress in hollow tubes and similar structures.
parch
Dear All,
Please see the picture. I need to find the bending stress for that profile.
Its hollow tube dia= 38 mm, 4 mm thick. its is acted with udl of 500 N/m2 on its outer surface.
How can I estimate the bending stress, deformation. Assume it as mild steel with E = 200 Gpa, poission ratio = 0.3.
I am trying to validate this with FEA in 3d.
Kindly share your ideas. Thank you in advance.
It's statically indeterminate so you can use a method for those types of problems. Maybe Castigliano's.
Or, you could get upper and lower bounds by treating the bends as rigid and pin-jointed. Then it's an easy simply supported beam problem.
16K
