What is the best Unix like OS for mathematical computation?
The best Unix-like operating systems for mathematical computation include Ubuntu and Scientific Linux, with the latter being a joint project of FermiLab and CERN. Ubuntu is recommended for its ease of setup and user-friendliness, while Scientific Linux is noted for its robust capabilities in numerical analysis. Both systems can efficiently run MATLAB and support programming in C, C++, and Fortran. Users can also convert their existing PCs into servers using various software solutions.
  • Basic understanding of command-line interfaces
  • Familiarity with MATLAB for numerical analysis
  • Knowledge of C/C++/Fortran programming languages
  • Understanding of remote access setup techniques
  • Research how to set up MATLAB on Ubuntu
  • Explore remote access tools for Linux, such as SSH
  • Learn about server software options for converting a PC into a server
  • Investigate the features of Scientific Linux for scientific computing
This discussion is beneficial for scientists, researchers, and developers focused on numerical analysis and scientific computation who prefer a Unix-like environment.
only_huce
I want to basically have a dedicated machine for running scientific computation programs and be able to access it remotely anywhere using a laptop/netbook. That means I don’t care much about GUIs. I’m used to using Unix and am perfectly fine with doing everything through a command window. At the same time however, I’m not a skilled programmer and want whichever is easiest to set-up and run things on. I also, need the OS to be able to run MATLAB.
So basically I want to find out which is the best OS for creating numerical analysis programs in C/C++/Fortran/MATLAB which leads me to these questions:
  • Which one would be the most powerful in regard to numerical analysis and solving complex equations
  • Which would be best/run most efficiently on PC hardware?
  • Which is the easiest to set-up remote access to?
Also on a slightly related topic, can I just build my own home server for cheap? By cheap I mean a budget under $2,500
Computer science news on Phys.org
I think the better unix OS is debian, but it's something complicated for using because need knowledge of shell script , so I recommend you to use Ubuntu.
And the server... you can turn your computer in server, there is a lot of software to can do this.
I haven't used it myself, but Scientific Linux, which is a joint project of FermiLab and CERN, might fit your needs. It's based on RHEL.
http://www.scientificlinux.org/
Any of the Linuxes should work, though. Not sure about BSDs, with ports it might work.
11K
  • · Replies 20 ·
  • · Replies 44 ·
