Calculating Pump Motor Output: Where Did I Go Wrong?
  • Thread starter Thread starter strugglin-physics
    Joules Watts
The discussion focuses on calculating the required output rating for a pump motor lifting 16.0 kg of water through a height of 3.38 m. The initial calculations incorrectly included kinetic energy, resulting in a negative output of -439 W. The correct approach emphasizes potential energy, requiring the formula mgy to determine the energy expended, which must then be divided by 60 seconds to convert to watts. The correct output rating for the pump motor is derived from the potential energy change alone.
  • Understanding of potential energy and its calculation (mgy)
  • Basic knowledge of power and its relation to energy (watts = joules/second)
  • Familiarity with unit conversions, particularly from joules to watts
  • Concept of gravitational force (g = 9.8 m/s²)
  • Calculate the power output required for different weights and heights using the formula mgy
  • Explore the relationship between energy, power, and time in mechanical systems
  • Learn about pump efficiency and how it affects motor output requirements
  • Investigate common mistakes in energy calculations in fluid dynamics
Engineers, physics students, and anyone involved in mechanical design or fluid dynamics who needs to accurately calculate motor outputs for pumps.
strugglin-physics
A pump is to lift 16.0 kg of water per minute through a height of 3.38 m. What output rating (watts) should the pump motor have?
Potential Energy Initial = O
Kenetic Energy Final = 0
So,
KE-PE = W
1/2mv^2 - mgh = Work
1/2(16.0)(3.38)^2 - (16.0)(9.8)(3.38) = -439 W
The fact that my answer is negative automatically tells me that I did something wrong as the pump wouldn't have a negative output. Does anyone see where I went wrong?
There is no kinetic energy involved in this problem at all, so that's your first trouble spot. The only thing that matters is the change in potential energy of the water when lifted 3.38 meters.
The pump has to lift 16 kg 3.38 m every minute. It has to expend energy to do this. It requires [itex]m g y[/itex] joules to lift a mass of any substance y meters:
http://www.google.com/search?hl=en&q=16+kg+*+9.8+m/s/s+*+3.38+m&btnG=Google+Search
This energy is expended over the course of a minute; the pump thus has to expend a sixtienth of this energy per second. Power, in watts, is equivalent to one joule per second:
http://www.google.com/search?hl=en&lr=&q=(16+kg+*+9.8+m/s/s+*+3.38+m)+/+60+seconds&btnG=Search
- Warren
Wow, I was way off. Thanks for your help, it helped me with another problem I was stuck on to.
