Measuring Neutrino Oscillations in a Solar Neutrino Rest Frame
The discussion revolves around the measurement of neutrino oscillations from the perspective of a solar neutrino's rest frame. Participants explore the implications of moving into this rest frame and how it affects the observation of neutrino oscillations, touching on quantum mechanics and the nature of neutrino states.
  • One participant questions whether neutrino oscillations would still be measurable in the rest frame of a solar neutrino.
  • Another participant explains that neutrino oscillations are a quantum effect that cannot be observed for a single neutrino, emphasizing the need for statistical measurements across many neutrinos.
  • A different participant proposes a thought experiment involving a source and detector at a distance, speculating on the wave function in a moving reference frame and the implications for flavor changes and coherence over distance.
  • One participant challenges the premise by stating that a neutrino must be in a mass eigenstate to have a rest frame, arguing that in such a state, the overlap with flavor eigenstates does not oscillate.
  • Another participant reiterates the necessity of being in a mass eigenstate for a neutrino to have a rest frame, while also contemplating the evaluation of wave functions in different frames and their relation to momentum.
  • A participant raises the question of whether a particle can exist without a rest frame and invariant rest mass, distinguishing between mass eigenstates and flavor eigenstates in terms of their particle status and experimental observability.
  • Discussion includes the idea that neutrino mass eigenstates may have different group velocities, leading to spatial separation of wave packets and potential quantum entanglement considerations.
Participants express differing views on the nature of neutrino oscillations in relation to rest frames, with some arguing that a rest frame is necessary for oscillation observation while others challenge this notion. The discussion remains unresolved with multiple competing perspectives presented.
Limitations include assumptions about the definitions of mass and flavor eigenstates, the implications of coherence over distance, and the conditions under which neutrinos can be said to have a rest frame.
Spinnor
If I moved in the rest frame of a solar neutrino would I still measure neutrino oscillations?
Thank you for any help!
Neutrino oscillations are a quantum effect. You can't observe them happening for a single neutrino any more than you can watch Schrödinger's cat oscillate between live and dead. The neutrino state created by a weak decay in the sun is a well-defined neutrino flavor, but not an energy eigenstate. The oscillation takes place because, as the eigenstates that make up the state evolve, the flavor slowly evolves. The only way to observe the flavor of the neutrino is to absorb it with another weak interaction, and of course you can only do this once. Observing the oscillations requires statistics on many neutrinos.
Bill_K said:
Neutrino oscillations are a quantum effect...The neutrino state created by a weak decay in the sun is a well-defined neutrino flavor, but not an energy eigenstate. The oscillation takes place because, as the eigenstates that make up the state evolve, the flavor slowly evolves...
Thank you! Here was my thinking going to bed. We have a source and a detector a large distance away. I want to know the wave function in a frame of reference that moves from source towards the detector with the average velocity of the neutrinos. In such a reference frame the momentum is minimized (at certain locations) but we are still left with a function that changes in time because of the rest masses? So in such a frame the mass states still interfere in time, flavor changes, we get the same outcomes in different frames? At some distance from the source interference stops because coherence stops? Are we then to think of these mass states being combinations of the flavor states?
Thanks for any help!
Stop...stop...stop...we're all getting off the track here. Go back to elementary QM.
For a neutrino to even have a rest frame, it must be in a mass eigenstate. If it's in a mass eigenstate, the overlap with the flavor eigenstates is a fixed number - it doesn't oscillate.
I'm trying to think in terms of wave functions. They can be evaluated in different frames. The wave function has information about momentum? Go to a point in such a frame where momentum is minimized. Can we do this?
Can a particle be a particle if it does not have a rest frame and invariant rest mass?
Neutrino mass eigenstates can properly be called particles with a rest frame and invariant rest mass, and flavor eigenstates are not particles in this sense. Yet neutrino flavor eigenstates are what we can experimentally observe through space-time events and so we commonly think of them as particles.
Consider beta decay. Neutrino mass eigenstates will have slightly different group velocities, and eventually the wave packets will be spatially separate. Quantum entanglement between the three mass eigenstate wave packets would seem to apply.
  • · Replies 33 ·
  • · Replies 221 ·
14K
  • · Replies 23 ·
  • · Replies 87 ·
23K
