Hi,I hope someone can help me. Looking at a magnetic generator,
  • Context: Undergrad
  • Thread starter Thread starter barendfaber
    Generator Magnetic
The discussion revolves around the design and calculation of induced electromotive force (EMF) in a magnetic generator utilizing a rotating ring of magnets and static copper wire. Participants explore various factors that may influence the EMF output, including magnet size, coil windings, and spacing.
  • Homework-related
  • One participant seeks a formulation to calculate the expected EMF based on specific design parameters, including magnet size, number of coils, and spacing.
  • There is a suggestion that increasing the number of windings in a coil may enhance the magnetic field, potentially affecting the EMF.
  • Another participant expresses uncertainty about the effects of varying the number of magnets and coils on the EMF output.
  • Concerns are raised about the understanding of electromagnetic induction principles, with a participant acknowledging a lack of confidence in recalling relevant concepts.
Participants do not reach a consensus on the specific calculations or effects of design changes on EMF. Multiple viewpoints and uncertainties remain regarding the influence of various parameters.
Participants express limitations in their understanding of the symbols and formulations related to electromagnetic induction, indicating a need for clearer explanations and foundational knowledge.
Individuals interested in magnetic generator design, electromagnetic induction, and those seeking to understand the relationship between design parameters and EMF output may find this discussion relevant.
barendfaber
Hi,
I hope someone can help me. Looking at a magnetic generator, we will have a ring of magnets which will rotate, and then we have the copper wire static.
I understand that if I have a ring of alternating magnets, all placed right next to each other, thereby creating a solid magnet surface for the copper wire to rotate against, the formulation for calculating the induced EMF = 2 x length into paper x radius to wire x Radial Flux Density B from magnets x rotational speed.
Please see attached picture. The outer diameter is 300 mm and the height 50 mm. This design is different, as I have only 24 magnets, with a radial flux density of 1.4 Tesla. I think their size is approx length (29 mm) x width (14 mm) x height (50 mm). I then also have 18 copper wire coils.
Is there a formulation I can use to calculate the possible EMF I can expect from this design? Also, how do I calculate how many magnets
I need some help here, but I would like to be able to calculate how the EMF will change when I:
1) Increase or decrease the size of the magnets (I expect here that the surface area of the magnet that get in contact with copper will have an effect)
2) Increase or decrease the number of windings in one coil and thickness of the copper wire
3) Increase or decrease the amount of magnets
4) Increase or decrease the amount of coils
5) Increase or decrease the air space
Most of what I know by now I have learned on the internet or with other help, so please treat me kindly! I do not understand most of the symbols in formulations, so if you can help with a formulation with explanations of symbols, like with EMF above, that will be awesome!
I'd try the electrical engineering forums if you don't get any hits here. I'd help but I don't know enought to answer your questions!
Thanks, I will repost now.
2)increase the number of windings in one coil -- i think this will cause greater magnetic field
3) amount of magnets??
4)the same with #2
5) i don't know
read more about ELECTROMAGNETIC INDUCTION.. i think these are basics concepts under these topics but i forgot about it so, i might as well give wrong info if i would just recall. I really am not that sure.. hope you'll be patient reading :)
  • · Replies 27 ·
  • · Replies 22 ·
