Dale
Mentor
- 36,893
- 15,868
Your comment here does not make sense. Do you understand that a light pulse travels a distance of [itex]\Delta d = c \Delta t[/itex] therefore the distance is proportional to the time and vice versa.sisoev said:I cannot find any reason of why the delay will be proportional to the distance.
It makes more sense to say that it is proportional to the light shift, because the light shift represents the distance.
A failure of imagination on your part does not change the facts. The light from an object moving in a circle, or tangentially to you, is red shifted. Did you not read the link I posted?sisoev said:I cannot also imagine that the light from a moving in circle object will be red shifted.
Again, you are under the misapprehension that SR is about visual appearances. The light delay is accounted for. SR is about what happens after accounting for the delay due to the finite speed of light.sisoev said:The red shift claim for circular moving object is very much like the explanation of the http://en.wikipedia.org/wiki/Ladder_paradox" ; it says that although both doors open simultaneously the ladder will see that the closer door opens first.
That's wrong, because the ladder sees the doors as light reflection and since the back door opens simultaneously with the front door, there will not be door at the back, to reflect a ligh which will travel to the lader and show a presence of a door.
What do you mean by this? The wave lengths are different in different frames of reference, but I am not sure what you mean by the qualifier "measured on the same distance".sisoev said:we will end up with two different wave lengths for same light, measured on same distance in two frames of reference.
