rcgldr
Homework Helper
- 8,947
- 687
The profile of a tire reduces the camber thrust affect. Because of the circular shape, when leaned over at a certain angle, there's virtually no camber thrust, because the inside (higher up on the tire profile, smaller radius) is moving slightly slower than the outside (lower down on the tire profile, with a larger radius). For a range of specific speeds, there is an lean angle where no camber thrust effect occurs at all.more on camber thrust
Dunlop made some high dome tires (K81, K181) with steeply sloped almost flat sides on the tire profile. The goal was to provide a larger contact patch when cornering, and a skinnier one when going straight. This is a profile that reduces camber thrust (it may be negative camber thrust at some lean angles).
Dunlop also makes tires with the opposite profile for most of it's street tires, a bit more contact patch while going straight to reduce tire wear. Bridgestones and most racing tires are near circular arcs. For racing bikes tire size is used to adjust contact patch area. The soft compounds flex enough to increase contact patch area and also reduce camber thrust, but the camber thrust reduction wasn't a goal, just a consequence of a stickier, softer tire that flexes more.
