90% done with this evenly dstrbtd chrg on infinite line problem. PLEASE help 10%
  • Thread starter Thread starter twisted079
    Infinite Line
The problem involves calculating the electric field at the origin due to a continuous line of charge extending from a point on the x-axis to positive infinity, with a uniform linear charge density.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the setup of the integral for the electric field, questioning the roles of variables such as L and x, and whether to express everything in terms of x. There are inquiries about which constants can be factored out during integration and the limits of integration.
Some participants have offered guidance on using the correct charge density and adjusting the limits of integration. There is ongoing clarification regarding the interpretation of variables and the setup of the integral, with no explicit consensus reached.
Participants are navigating potential confusion regarding the definitions of charge density and the implications of integrating to infinity. The original poster expresses uncertainty about the integration process and the behavior of the integral at its limits.
twisted079
90% done with this "evenly dstrbtd chrg on infinite line" problem. PLEASE help 10%
A continuous line of charge lies along the x-axis, extending from x=+x0 to positive infinity. The line carries positive charge with a uniform linear charge density λ0.
What is the magnitude of the electric field at the origin? (Use λ0, x0 and ke as necessary.)
1) dE = (kedq) / r2
2) dq = λdx = (Q/L)dx
I used the prior equations to set up: dE = (keQ / L) * dx/x2
Now time to integrate, but first a few questions. I understand "L" is the length of the entire rod? But so is x? Am I using L and x the right way or should I put everything in terms of x? Second, what are the constants that I pull out of the integral? Since its to infinity, doesn't "L" (or x?) change, meaning I can't pull out the L? I understand ke and Q are constant so I pull them out, is that all? Also I am integrating from 0 to infinity correct? Depending on what the set integral is, I understand that there is a possibility that when I integrate, infinity might be a denominator, making that part go to 0? I am kind of confused, any help would be GREATLY appreciated!
x is not the length. It's just a general position along the x-axis.
You don't need L. The answer should have λ0 in it dq = λ0 dx .
You're about 50% done, at best.
But λ = Q/L, or in this case would it be Q/x?
Edit: What about the constants that I could pull out of the integral?
Ok, so this is my idea of what the solution would look like:
(keQ) / L 0infinity dx/x2
---> 1/x2 dx becomes -(1/x) which puzzles me because this leads to no solution except keQ/L (L or x) ... Please help!
Maybe I wasn't clear. Wherever you have Q/L, use λ0 instead.
If you had such a line of charge, then if you cut a length, L, of that line and measured the amount of charge, Q, for that length, L, you would find the ratio of charge to length to be λ0 .
In other words, Q/L = λ0 , anywhere on the line.
Here is what I have come up with so far:
dq = λdx
dE = keλdx / x2
E = keλ 0 dx/x2
E = keλ(-1/x) from 0 to ∞
Now, when I plus 0 in, I run into a problem
The integral should go from x0 to ∞ .
So I would have
E = keλ(-1/x0 - 0) --> -(keλ / x0) ?
Yes, Except you're finding the magnitude. Drop the "-" sign .
I edited this post, but you must have seen it before I made the changes.
Ah okay, and the direction would be in the negative x-axis. Thank you so much for your help!
Yes. Your previous answer is almost correct.
10K
  • · Replies 16 ·
