How Many Homomorphisms Can Be Calculated Between Different Fields?
  • Context: Graduate
  • Thread starter Thread starter wattsup03
    Homomorphisms
This discussion focuses on calculating homomorphisms between various fields, specifically F2 to F3, Q[X]/(X7 - 3) to Q[X]/(X8 + 4X5 - 6X + 2), F7[X]/(X2 + X - 1) to F7[X]/(X2 + 1), and Q(21/4) to C. The consensus is that there are no homomorphisms between F2 and F3 due to the properties of field elements. For the second case, the number of homomorphisms is determined by the roots of the polynomial X7 - 3 in the context of Q[X]/(X8 + 4X5 - 6X + 2), yielding one homomorphism. The third case mirrors this reasoning, while the fourth case suggests four K-homomorphisms based on the roots of the minimal polynomial of 21/4 in C.
  • Understanding of field theory and homomorphisms
  • Familiarity with polynomial rings, specifically Q[X] and F7[X]
  • Knowledge of minimal polynomials and their roots
  • Basic concepts of bijections in algebra
  • Study the properties of field homomorphisms in abstract algebra
  • Learn about the structure of polynomial rings, particularly Q[X] and F7[X]
  • Investigate the relationship between roots of polynomials and homomorphisms
  • Explore K-homomorphisms and their applications in field theory
Mathematicians, students of abstract algebra, and anyone interested in the study of field homomorphisms and polynomial rings.
wattsup03
Hi,
I am trying to calculate the number of homomorphisms from one field to another:
a) F2 ---> F3
b) Q[X]/(X7 - 3) ---> Q[X]/(X8 + 4X5 - 6X + 2)
c) F7 [X] / (X2 + X - 1) ---> F7[X] / (X2 + 1)
d) Q( 21/4 ) ---> C
Attempt at a solution
a) I'm pretty sure there are no homomorphisms between F2 and F3 because if there was a homomorphism f, then f(1+1) = f(0) which does not equal f(1) +f(1) = 2
b) I think I need to see how many roots there are of X7 - 3 in Q[X]/(X8 + 4X5 - 6X + 2) since there is a bijection between that and the number of homomorphisms?
c) Similarly here
d) For this one I think the answer is four (I'm really not sure) because there is a bijection between K-Homomorphisms and the roots of the minimal polynomial of 21/4 in C, which would be 4. And over fields K-homomorphisms are ring homomorphisms?
In all honesty I am pretty stuck, and if anyone could give me any advice that would be fantastic.
Thanks in advance.
a) I agree
b) I am thinking that a homomorphism f will be uniquely defined by f(x)
Prove it.
But 0 = f(0) = f(x^7 - 3) = f(x)^7 - f(3) = f(x)^7 - 3
and how many solutions does this have?
But I suppose we have to bear in mind that this zero is k(x^8 + 4x^5 - 6x + 2) for any k
c) similar
d) Using this same method would seem to imply the identity is the only homomorphism, but there are 4 K-Homomorphisms as you said, so we are in trouble here
This is still a work in progress for me but I hope it helps
Thanks meandonlyme ,
for b) could I put x7 - 3 into Q[X]/(X8 + 4X5 - 6X + 2)
(which is x7 - 3 still) and then calculate the number of roots in there: 1 since it is over Q.
So there is one root and hence one homomorphism.
Similarly for c) and d)
  • · Replies 52 ·
14K
  • · Replies 24 ·
