Integration of a pdf, expected value
The discussion focuses on proving that E[Y^4] = 3 for a standard normal random variable Y ~ N(0,1). Participants explore two main equations: E[(Y-mu)^4]/[E(Y-mu)^2]^2 = 3 and E(Y^4) = 1/sqrt(2pi) * integral(y^4 * e^(-y^2/2)). Users suggest using integration by parts and substitutions to simplify the integral, with one participant successfully applying these techniques to derive the correct result. The consensus indicates that the first equation is not necessary for solving the problem.
  • Understanding of expected values in probability theory
  • Familiarity with standard normal distribution properties
  • Proficiency in integration techniques, particularly integration by parts
  • Knowledge of gamma distribution and its relation to normal distribution
  • Learn advanced integration techniques, specifically integration by parts
  • Study the properties of the gamma distribution and its relationship to normal distributions
  • Explore the derivation of moments for normal distributions
  • Investigate the use of substitutions in integrals involving exponential functions
Students and professionals in statistics, mathematicians focusing on probability theory, and anyone interested in deriving moments of probability distributions.
alias
Show that E[Y^4] = 3, where Y~N(0,1)
E(Y^4) = 1/sprt(2pi)*intregral (y^4)*e^(-y^2/2)
I have expanded and simplified the first equation above and cannot get it to equal 3. I think it's possible to solve the second using integration by parts but I can't find what to use for
[u, du, dv, v] in order to integrate by parts. Any help would be appreciated. Thanks.
Sorry, it's a definite integral in from -inf to inf.
You might have to try several things until you get something that will work. What have you tried so far? Another approach that is often useful is to look at dI(a)/da or d^2I(a)/da^2, where I(a) = integral_{y=-inf..inf} exp(-a*y^2/2) dy.
RGV
I tried integration by parts but the integral I end up with makes no sense to me.
If you show your work we have the basis of a discussion.
RGV
Just spit-balling, is there a way to use some substitutions to make this look something like the pdf of a gamma distribution? Then use what you know about that?
I integrated the Gaussian distribution, it took a long time but I finally got the right answer. After making a substitution, integration by parts worked. I would like to know if the formula: E[(Y-mu)^4]/[E(Y-mu)^2]^2, is useless for answering this question though. Thanks guys.
