Angular Velocity Of A Wheel
1. The problem statement, all variables and given/known data
A wad of sticky clay with mass 2.45 kg and velocity vi = 52.0 m/s is fired at a wheel of moment of inertia 1.2 kg m2 and radius R = 1.26 m. The wheel is initially at rest and is mounted on a fixed horizontal axle that runs through its center of mass. The line of motion of the projectile is perpendicular to the axle and at distance d = 0.842 m from the center.
Find the angular speed of the cylinder (in rad/s) just after the clay strikes and sticks to the surface of the wheel.
2. Relevant equations
T=rF=Iα.
3. The attempt at a solution
I don't have a text book with me so I am trying to work through this by searching the internet and my memory. I am thinking in order to solve this you would just take the angular force times the radius and you would have torque. Then from there you would find the angular speed from the torque but I don't see how you would find the torque if the problem only gives you the velocity of the clay projectile.
