Water, Ice, Steam Mixture - Final Temperature
The discussion focuses on calculating the final equilibrium temperature of a closed system containing 3.50 kg of dry saturated steam at 100°C, 2 kg of ice at 0°C, and 50 kg of water at 20°C. The key equations used include the heat transfer equation Q=MCΔT and the latent heat values for steam (2257 kJ/kg) and ice (335 kJ/kg). The user initially calculated the heat released by the steam and the heat absorbed by the ice but overlooked the correct unit conversion for latent heat. The correct approach involves balancing the heat exchanges to find the equilibrium temperature.
  • Understanding of thermodynamics principles, specifically heat transfer.
  • Familiarity with the concept of latent heat and its calculations.
  • Knowledge of the heat transfer equation Q=MCΔT.
  • Basic skills in unit conversion, particularly for energy measurements (kJ/kg).
  • Review the principles of latent heat and its application in phase changes.
  • Practice solving thermodynamic problems involving mixed-phase systems.
  • Learn about the concept of thermal equilibrium in closed systems.
  • Explore advanced topics in thermodynamics, such as the first law of thermodynamics.
This discussion is beneficial for power engineering students, thermodynamics learners, and anyone interested in understanding heat transfer in closed systems.
mrjester1989
Hi i am a brand new member to this forum i am studying to be a power engineer and thermodynamics is one of the courses I need to succeed. If i could get help with this problem it would be much appreciated.
A perfectly insulated box contains 3.50kg of dry saturated steam at 100C, 2kg of ice at 0C and 50kg of water at 20C. Assuming that all of the steam condenses and that all of the ice melts, calculate the equilibrium temperature by the closed system.
Q=MCdelta T
Ive tried this several times and i got close to the answer but i must be missing something.
Steam ---> Water
3.5kg(2257kj/kg) = 7899.5
Ice ----> Water
2kg(335kj/kg) = 670
IM just going to stop there cause I am not sure if I am on the right track.
0=mcdelta t + mc delta t + mc delta t
Thanks for the help in advance
Q=MCdelta T
Steam ---> Water
Ice ----> Water
2kg(335kj/kg) = 670
That is a good start, except for ignoring the kilo in latent heat 335kJ/kg that is [same for steam].
  • · Replies 17 ·
