How stirring a liquid affects temperature measurements.
Stirring a hot liquid while measuring its temperature with a thermometer significantly enhances measurement accuracy. This is due to the disruption of the thermal boundary layer created by natural convection, which can lead to artificially low readings. By promoting forced convection, stirring allows the thermometer's sensor to better interact with the bulk fluid, resulting in a more reliable temperature reading. Understanding the principles of heat transfer, particularly the differences between natural and forced convection, is essential for accurate temperature measurement.
  • Understanding of heat transfer principles, specifically natural and forced convection.
  • Familiarity with thermodynamic concepts related to temperature measurement.
  • Knowledge of thermal boundary layers and their effects on measurement accuracy.
  • Basic physics principles related to kinetic energy and fluid dynamics.
  • Research the principles of natural convection and forced convection in fluid dynamics.
  • Study the effects of thermal boundary layers on temperature measurements.
  • Explore methods for calculating film coefficients of heat transfer.
  • Learn about the design and calibration of thermometers for accurate temperature readings.
This discussion is beneficial for physics students, engineers, and laboratory technicians involved in temperature measurement and heat transfer analysis.
dJordiB
"Some people say stirring a hot liquid with a thermometer gives a better measurement and some say it yields a worse measurement. Explain with physics how one is actually better"
None that I know of.
I know that stirring a liquid generally cools it, but I was also thinking that the increased kinetic energy due to the stirring may cause an increase in temperature. Also, stirring would evenly distribute the liquid so that the average temperature would be more measurable, but if it changes the temperature through the previously stated ways, then wouldn't it be worse?
Gee, my immediate reaction is that stirring gives you a more accurate measurement, but that's because I've had a couple of heat transfer courses. If you don't stir, the heat transfer is limited by natural convection, that is, a film of cool liquid forms around the end of the thermometer and gives an artificially low reading. Stirring disrupts the film and provides much better "forced convection" heat transfer. It exposes the tip of the thermometer more directly to the bulk fluid. I'm not sure what principles of physics you could quote for that, although I have some textbooks with a number of methods for calculating film coefficients of heat transfer under natural and forced convection...
BBB
That's great thank you so much! I was leaning toward that answer but didn't have much of a justification.
  • · Replies 83 ·
9K
