PeterDonis
Mentor
- 50,220
- 26,294
atyy said:Ok, but is there anything I can't do if I use 3-force, inertial mass and E and B fields in any particular inertial frame?
I don't think so, but you were talking about what different theories consider "fundamental". Standard SR does not consider anything that is frame-dependent to be "fundamental"; only frame-invariant objects are "fundamental". So, for example, the electromagnetic field tensor [itex]F_{ab}[/itex] would be fundamental, but any particular decomposition into E and B fields would not be, since that is frame-dependent.
Perhaps it's also worth noting that, just as you can calculate everything using a single inertial frame, you can calculate things without using a frame at all. Any number that you can actually measure in an experiment can be expressed as a scalar (PAllen made this point in a recent thread on a similar subject), meaning you can express it without ever having to commit yourself to any specific frame, just write the expression in terms of contractions of vectors and tensors (which you can do in abstract index notation, without ever specifying a particular set of components).
