Need help with a circuit problem? (Picture attached)
  • Thread starter Thread starter ObviousManiac
    Circuit
The discussion revolves around a circuit problem involving multiple resistors, specifically focusing on determining the current through each resistor given the current in a 13.8-Ω resistor. The participants explore concepts related to series and parallel circuits.
  • Participants discuss the application of Ohm's law and the rules for series and parallel circuits. They attempt to calculate voltages and currents for various resistors based on the known current in the 13.8-Ω resistor. Questions arise regarding the combination of resistances and the implications of series versus parallel configurations.
The discussion has progressed with participants providing calculations and corrections to each other's reasoning. Some guidance has been offered regarding the treatment of series resistors, and there is an ongoing exploration of how to accurately determine the total current in the circuit.
Participants are working under the constraints of a homework assignment, which may limit the information they can use or the methods they can apply. There is an emphasis on understanding the relationships between the components of the circuit rather than simply arriving at a final answer.
ObviousManiac
**PICTURE ATTACHED AT BOTTOM**
The current in the 13.8-Ω resistor in the attached picture is .795 A. Find the current in the other resistors in the circuit.
V=RI
In a series circuit:
V of Circuit = V1 + V2 + V3 +...Vn
I of Circuit = I1 = I2 = I3 = ...In
R of Circuit = R1 + R2 + R3 +... Rn
In a parallel circuit:
V of Circuit = V1 = V2 = V3 = ... Vn
I of Circuit = I1 + I2 + I3 +... In
1/R of Circuit = 1/(R1) + 1/(R2) + 1/(R3) +... 1/(Rn)
For the 13.8-Ω resistor, I found that Voltage = 10.971 by using V=IR
- Because V of Circuit = (V1 = V2 = V3 = ... Vn), the Voltage for the 17.2-Ω resistor is also 10.971
--Based on this, the Current for the 17.2-Ω resistor is .638:
V=IR
I=V/R
I=(10.971)/(17.2)
I=.638
After this, I proceeded to find the equivalent resistance for the entire circuit.
To find this, I separated the circuits into groups.
Group 1= the 15-Ω and 12.5-Ω resistors (they are in series).
Group 2= the 13.8-Ω and 17.2-Ω resistors (they are parallel).
Group 3= the 8.45-Ω and 4.11-Ω resistors (they are in series).
When solved for, the equivalent resistance for each group is as follows:
Group 1= 27.5-Ω
Group 2= 7.66-Ω
Group 3= 12.56-Ω
Note that Groups 2 and 3 are now parallel. We will combine them into Group 4.
Group 4 Resistance = 4.75-Ω
Now we only have Groups 1 and 4 left in series. When combined, we will get the net resistance for the entire Circuit. This works out to be 32.56-Ω
...So that's everything I could find, which is decent, but doesn't come anywhere near answering the question. I know I must be missing something somewhere.
How do I figure out the individual currents for each resistor with the information I currently have?
V=RI
V=IR
I=V/R
I=(10.971)/(17.2)
I=.638
<snip!>
You're doing so well using the voltage across the 13.8Ω resistor, why not continue? The same voltage must be across the series connected 8.45Ω + 4.11Ω resistors. So what's the current through them?
What then is the total current for the subcircuit?
Ah, of course!
Okay, so based on that...
Current of the 8.45 Ω resistor should be (10.971)/(8.45) = 1.3 A
and the 4.11 Ω will be (10.971)/(4.11) = 2.67 A
So the total for the subcircuit will be
.795 A
+.638 A
+1.3 A
+2.67 A
= 5.403 A
Would that be correct?
ObviousManiac said:
Ah, of course!
.795 A
+.638 A
+1.3 A
+2.67 A
= 5.403 A
No, not quite. The 8.45 and 4.11 resistors are in series. How do you combine series resistances?
So would it be
(10.971)/(8.45+4.11) = .873 A
And then the subcircuit would work out as
.873 A
+ .795 A
+ .638 A
= 2.3 A
ObviousManiac said:
So would it be
.873 A
+ .795 A
+ .638 A
= 2.3 A
Yessir. That looks good. You should now be in a position to state the current through every resistor in the circuit.
Alrighty, here are my final results. Everything seems to check out:
13 Ω = .795 A
17.2 Ω = .638 A
8.41 Ω = .87 A
4.11 Ω = .87 A
15 Ω = 2.3 A
12.56 Ω = 2.3 A
13 Ω = .795 A
17.2 Ω = .638 A
8.41 Ω = .87 A
4.11 Ω = .87 A
15 Ω = 2.3 A
12.56 Ω = 2.3 A
Yup.
thanks for all the help.
  • · Replies 20 ·
