Faster than Light Neutrinos at CERN
CERN has reported measurements indicating that neutrinos may travel faster than the speed of light. The experiment involved two clocks located in Switzerland and Italy, raising concerns about their synchronization due to gravitational variations. Factors such as the Earth's crust instability and gravitational field intensity fluctuations could affect clock rates, making precise velocity measurements of neutrinos potentially unreliable. The discussion emphasizes the challenges of conducting such measurements in non-inertial frames influenced by Earth's gravitational curvature.
  • Understanding of special relativity and the speed of light
  • Familiarity with clock synchronization techniques in physics
  • Knowledge of gravitational effects on time measurement
  • Basic concepts of neutrino physics and particle detection
  • Research the implications of special relativity on particle physics
  • Study clock synchronization methods in varying gravitational fields
  • Explore the effects of Earth's gravitational field on time measurement
  • Investigate previous experiments measuring neutrino speeds, such as OPERA
Physicists, researchers in particle physics, and students studying relativity and gravitational effects on time measurement will benefit from this discussion.
e2m2a
Cern has reported they have measured neutrinos going faster than the speed of light. Did they send a light beam as a test case to see any variance in c of the light beam?
Also, were two clocks involved in the measurement? One in Switzerland and one in Italy? If so, wouldn’t it be impossible for these two clocks to tick at exactly the same rate or to be consistently synchronized at the nano second level? That is, this experiment was not conducted in pure, inertial space but within the gravitational curvature of space due to the Earth at the surface of the earth.
And the gravitational field intensity at the surface in Switzerland could not be precisely the same at the detector location in Italy. Hence, the two clocks could never tick at the same rate.
Because of instabilities of the earth’s crust- plate movements, changes in density of the Earth's crust, seismic dynamics, the changing distance between the center of mass of the Earth and a given point on the earth- all of these factors would fluctuate the gravitational field intensity at the earth’s surface for any given point on the earth’s surface.
And thus the difference in clock rates at the two points in the experiment would never be consistent.
Wouldn't these factors render it impossible to make a precise velocity measurement of the neutrinos or am I missing something?
  • · Replies 42 ·
  • · Replies 24 ·
  • · Replies 0 ·
  • · Replies 21 ·
