Calculating inductance using a RL circuit and a frequency generator
The discussion revolves around calculating the inductance and impedance of an unknown air-cored inductor using a series RL circuit and a frequency generator. Participants are exploring methods to obtain accurate measurements over a frequency range of 1600 Hz to 2700 Hz.
  • One participant describes their experimental setup, including the use of a frequency generator, amplifier, and a 1-ohm resistor, and seeks guidance on calculating inductance.
  • Another participant notes that the inductance appears to decrease with increasing frequency, suggesting a potential error in the measurements or calculations.
  • A suggestion is made to use a capacitor in series to improve excitation and detect resonance, although one participant clarifies they are not seeking resonance measurements.
  • Concerns are raised about the use of a 100-watt resistor, which may introduce inductance that could affect results, and a recommendation is made to use a non-inductive resistor instead.
  • Calculations for inductance and impedance are presented, with one participant providing a formula and example calculation based on measured voltages and currents.
  • Discrepancies in the calculated values of reactance (XL) are highlighted, with one participant questioning the accuracy of a provided table and suggesting that the values do not align with their own calculations.
  • Another participant emphasizes the importance of measuring the resistance of the coil itself, as it could significantly impact the results.
  • Clarifications are made regarding the measurement of voltage across the inductor versus the resistor, indicating potential confusion in the setup description.
Participants express various viewpoints on the accuracy of measurements and calculations, with some agreeing on the need for non-inductive resistors while others question the validity of the provided data. There is no consensus on the correct approach or the accuracy of the inductance values derived from the measurements.
Participants note potential limitations in their measurements, including the internal impedance of the frequency generator and the inductive properties of the resistors used. There is also uncertainty regarding the resistance of the coil itself and its impact on the overall calculations.
yoda2026
any help would be much appreciated
i am trying to calculate the inductance and impedance of a unknown air cored inductor. over a set frequency range (1600hz - 2700hz in 100hz increments) using a series RL circuit
tools
scope
multimeter
frequence generator
Amplifier
1ohm 100W metal clad resistor(1.07ohms under test)
what i have done so far is
frequency generator is set at 1600hz
the output of a frequency generator is connected to the input of the amplifier
the output of the amplifier is used as the power-source
the positive terminal of the amplifier goes to side a of the inductor, side b of the inductor is connected to side a of the resistor, then side b of the resistor is connected to the negative terminal of the amplifier (if this is unclear please see the attached photo)
as a table of data i have (for this i am using the 1600hz information)
frequency = 1600hz
resistor = 1.07Ohms
voltage across the resistor = 0.84V
voltage across the inductor (voltage from the negative terminal of the amplifier to the inductor terminal) = V1-V2 = 0.19V
using this information how do i calculate the inductance
http://img839.imageshack.us/img839/9320/20120105163452.png please not i did not calculate the table above and i am led to believe that it is incorrect
as the inductance decreases as the frequency increases.
i am trying to replicate this test using two unknown inductors to compare the results to see if one is a suitable replacement for the other
The signal generator's internal impedance (typically 50 ohms) can make it difficult to get good excitation. This why I typically use a capacitor in series and sweep the frequency until I get a strong resonance.
Resonance can be detected by high voltage across across either the L or C. You can also place a small resistor in series with the ground lead and see the current peak at resonance. Then, find Xc from:
Xc=1/(2*pi*f*C)
At resonance, Xl = Xc
Xl = 2*pi*f*L
L=1/(4*pi^2*f^2*C)
yes the frequency generator has an internal impedance of 50 ohms but then its is fed into an amplifier which i was hoping would counter the impedance
i am more than happy to add a capacitor if that will make the calculations eaiser. but i am not trying to find the inductance/impedance at resonance... i am trying to find the inductance at a set frequency ie 1600hz
sorry if i have missed something
Don't use 100 watt resistor. Some 100 watt resistors are incredibly inductive.
The Q of the inductor probbly won't change with any reasonable power, so test with signal generator and 1% metal film resistor.
I=Eresistor/Rresistor=0.84/1.07=0.785 amp
Inductor Impedance = 2*pi*f*Linductor= Einductor/I Solve for Linductor
Linductor= Einductor/(2*pi*f*I)= 0.19/(2*3.14*1600*0.785) = 24.08 microhenry
Didn't check voltages before posting preceding.
You may have to use an amplifier to get reasonable voltages.
However it is probably best to use ten 10 ohm 1% metal film resistors in parallel for 1 ohm resistor. 100 watt resistors are likely to give you incorrect results.
I agree with Carl Pugh and I got the same value using your figures.
The voltages you have measured are across the 2 components... R and L and therefore what goes on inside the power supply is irrelevant.
As the frequency increases the REACTANCE increases (2pifL) I can't think of any reason why the inductance (L) should increase
One other thing occurs to me... have you measured the resistance of the coil itself? We have assumed it has zero resistance.
The actual resistor in the circuit is only 1 ohm so any resistance in the coil would be significant.
hmmm ill try changing to a non inductive resistor and see if my values change
thanks for the heads up
i have changed resistor and i am getting a much more sensible answer
thank youusing XL=2PI*F*L on the table i have supplied i get
2PI*1600*2.41*10^-5 = 0.2422
where there table gives 5.826615 :s which doesn't make any sense
something's not right with the rightmost, XsubL, column in that table.
look at 1600 hz row
volts across inductor = 0.19
amps through inductor = 0.78
XsubL = 5.826615
ohms = volts/amps = 0.19/0.78 = 0.2420238+(use all the digits) , that should be XsubL not 5.something.
intuitively if you have way less than a volt at amost an amp you have less than an ohm.
With .8 amp through something and only 0.2 volt across it it's way less than an ohm.
now what's curious is if i divide their XsubL number by my XsubL number
i get the number that's in their L column.
5.826615 / 0.242038 = 24.0745
i think somebody did something that's not intuitive when making that spreadsheet.
and from the description of your hookup
it seems that voltage across the inductor would be from POSITIVE terminal of amplifier to side b of coil...
instead of
which sounds more like voltage across resistor.
