Does Galactic Rotation Cause Frame Dragging?
  • Context: Graduate
  • Thread starter Thread starter H2Bro
    Frame Frame dragging
Galactic rotation does not produce significant frame dragging effects due to the vast scales involved. The effects of frame dragging are primarily felt near the event horizon of black holes, with negligible influence throughout galaxies like the Milky Way. The degree of frame dragging is determined by the mass and angular momentum of the rotating body, but in the case of galaxies, these effects are minimal and primarily occur at the edges of the galactic disk and between spiral arms. Calculations for frame dragging exist, but they are complex and often not necessary for understanding the negligible effects in galactic contexts.
  • Understanding of general relativity and its implications on gravitational fields
  • Familiarity with angular momentum and its measurement
  • Knowledge of black hole physics, particularly event horizons
  • Basic concepts of galactic structure and dynamics
  • Research the mathematical formulations of frame dragging in general relativity
  • Explore the effects of angular momentum on gravitational fields
  • Study the properties of black holes and their event horizons
  • Investigate the structure and dynamics of spiral galaxies
Astronomers, physicists, and students interested in the effects of rotation on gravitational fields, particularly in the context of galaxies and black holes.
H2Bro
Do galaxies produce measurable/significant frame dragging effects by their rotation?
I would think frame dragging depends on the mass and speed of rotation... Are such effects only felt at the boundary between rotating gravitational fields and flatter space, i.e. the edge of the milky way? Or would frame dragging produce effects throughout the milky way, i.e. in the gaps between spiral arms as well as between stars.
Astronomy news on Phys.org
These effects are completely negligible on the galactic scale. Frame dragging is only significant near the event horizon of a black hole. For comparison, if the entire mass of a galaxy were compressed to a point; its event horizon would be about a million times smaller than the radius of the galaxy, suggesting the effects will be completely negligible.
You're right that the degree of the effect depends only on the mass and speed of rotation (generally measured by the angular momentum). What (little) effects there are would be felt both at the edge of the disk, and between the spiral-arms.
Hi, one question.
Are there any calculations to figure out frame dragging, or the strength of frame dragging is purely "intuitively implied" (in case the math is prohibitively complex)?
Edit:
Never mind, I've read up on this one.
  • · Replies 21 ·
  • · Replies 29 ·
  • · Replies 86 ·
9K
