Thought experiment regarding artificial gravity (Newton's third law in space)
The discussion centers on the generation of artificial gravity in space using centripetal force, specifically through the concepts of Stanford Tori and Bernal sphere. It concludes that if a rod rotates the tori, angular momentum conservation dictates that the rod and torus will rotate in opposite directions, with the rod spinning faster due to its smaller mass. The behavior of this system remains consistent with Earth-based physics, provided the structure can rotate freely. Additionally, thrust engines contribute to the system's dynamics by accelerating in the opposite direction of mass ejection, akin to gear mechanics.
  • Understanding of centripetal force and its application in artificial gravity
  • Familiarity with angular momentum conservation principles
  • Knowledge of the Stanford Tori and Bernal sphere concepts
  • Basic principles of thrust mechanics in rotational systems
  • Research the mechanics of Stanford Tori and Bernal sphere designs for artificial gravity
  • Explore advanced concepts in angular momentum conservation in rotating systems
  • Investigate the engineering challenges of creating "perfect" bearings for free rotation in a vacuum
  • Learn about thrust vectoring and its applications in spacecraft maneuverability
Aerospace engineers, physicists, and students interested in the practical applications of artificial gravity and rotational dynamics in space environments.
psyhprog
I was recently reading about artificial gravity and generating it in space, especially by centripetal force using Stanford Tori and Bernal sphere (only Wikipedia and these to articles, but if anyone has any more resources, I would be glad to read them, I couldn't find anything else in my search). If an electrical engine would be in a rod (well, the shape, not actually a rod) and would rotate the tori around the rod (the 0G and 1G parts of the space shuttle), since the rod has smaller mass, what would happen? Would the rod spin counter-clockwise, the tori clockwise, or both in different senses of rotation? Is this any different from how they would behave on Earth (under gravity). And would it change the situation, if the initial push was generated by thrusters on the circumference of the torus/sphere ?
Science news on Phys.org
Angular momentum will be conserved. This means that rod and torus will rotate in opposite directions, and that since the rod has smaller mass than the torus, it will rotate faster than the torus.
This will work the same way at the surface of the Earth, assuming that we can find a way to let the structure rotate freely (mounted on "perfect" bearings in a vacuum, for instance).
The thrust engines will also work by conserving angular momentum: the engines throw out mass in one direction of rotation, causing the structure to accelerate in the other direction of rotation.
So they would behave kind of like gears?
and since what you said is true, the rod (hollow) will also experience a much weaker artificial gravity, right?
  • · Replies 38 ·
