Can I Apply for Robotics Grad Degrees with a Dual ECE Degree?
Students pursuing a Dual Electrical and Computer Engineering (ECE) degree can effectively apply for graduate programs in robotics without needing a Computer Science (CS) degree. The discussion highlights that a combination of Electrical Engineering (EE) and Computer Engineering (CE) provides sufficient foundational knowledge for robotics, particularly in programming and artificial intelligence. Additionally, the overlap between CE and CS courses allows for self-learning of necessary computer science concepts post-graduation, making the dual degree a practical choice without extending the time in university.
  • Understanding of Electrical and Computer Engineering principles
  • Familiarity with programming concepts relevant to robotics
  • Knowledge of artificial intelligence fundamentals
  • Awareness of the differences between Electrical Engineering and Computer Science curricula
  • Research graduate programs in robotics that accept Electrical and Computer Engineering degrees
  • Explore self-learning resources for computer science topics relevant to robotics
  • Investigate the curriculum of Mechatronics degrees for additional insights
  • Learn about the overlap between Computer Engineering and Computer Science courses
Undergraduate engineering students, prospective robotics graduate applicants, and anyone considering a dual degree in Electrical and Computer Engineering with an interest in robotics and artificial intelligence.
Nookular
I have decided to major my engineering degree in Electrical and Computer Engineering, however I only start this year.
I am interested in the field of robotics, specifically the side of the programming, developing intelligent machines and artificial intelligence etc.
My question is, would I still be able to apply for the same graduate degrees with a Dual Electrical/Computer engineering degrees as I would be able to with a Computer Science and Electrical Engineering degree?
It doesn't matter to much which I take at this point, as change to Computer Science at my university basically just adds and extra year to the degree, so technically I could do both. I don't want to add Computer Science however if it will have no additional bearing.
Thanks in advance.
For robotics Dual Electrical Engineering and Mechanical Engineering or maybe a good Mechatronics degree. But out of the two I would take Electrical and Computer Science.
A bare electrical engineering degree would be very sufficient if you want to get into robotics.
I see no reason to spend an additional year at the university.
Also, if you need any computer science courses once you graduate, you can learn them on your own. Don't forget that there is some overlap between CE and CS courses.
Another factor to consider, is that as you progress in your study, you may want to graduate sooner if you're fed up or something.
Hence, I do find EE+CE a reasonable option.
  • · Replies 16 ·
