6 Transistors: Why More is Better?
  • Thread starter Thread starter sandy.bridge
    Transistors
The discussion centers on the necessity of using six transistors in a circuit design, specifically addressing the limitations of using only four transistors. It is established that NMOS devices cannot effectively pull up the output voltage due to the body effect and threshold voltage limitations, resulting in inadequate voltage levels when both inputs are high. The circuit's failure to operate correctly is attributed to these constraints, which prevent the output from reaching the required voltage levels for proper functionality.
  • Understanding of NMOS and PMOS transistor operation
  • Knowledge of voltage thresholds and body effect in MOSFETs
  • Familiarity with digital logic design principles
  • Basic concepts of signal superposition and noise margins
  • Research the body effect in NMOS and PMOS transistors
  • Learn about voltage level shifting techniques in digital circuits
  • Explore advanced digital logic design using CMOS technology
  • Study the implications of noise margins in circuit design
Electrical engineers, circuit designers, and students studying digital electronics who seek to understand the complexities of transistor-level design and its impact on circuit performance.
sandy.bridge
Why is it required to have 6 transistors? Can it not have 4? Can the output not receive two LOW signals at once? Or does it have something to do with superposition such that upon adding the two signals it may enter the noise margin?
Here, I added a photo.
The circuit you've drawn in the bottom doesn't work. You can't use NMOS devices to pull up (and PMOS devices to pull down) in this way, because the devices will turn off before they pull up (or down) all of the way. Suppose your a and b are at Vdd. When those two NMOS devices try to pull up the output it will stop at <Vdd-2*Vt, because the NMOS devices turn off. In practice, what's called the body effect will make it even worse. If Vdd=5V, for example, the output probably won't pull up much past ~3V. Then if you feed this into the next gate of the system, the next NMOS devices have a lower voltage on their gates so the output pulls up less. Bottom line - it doesn't work this way.
  • · Replies 27 ·
