Bohr-Einstein debate: why did Bohr not simply say
  • Context: Graduate
  • Thread starter Thread starter nonequilibrium
    Bohr
The discussion revolves around the Bohr-Einstein debates, specifically questioning why Niels Bohr did not directly counter Albert Einstein's reliance on classical reasoning, such as conservation laws, during their exchanges on the uncertainty principle. Participants explore the implications of classical concepts in the context of quantum mechanics and the philosophical underpinnings of their arguments.
  • Some participants suggest that Bohr could have simply pointed out Einstein's reliance on classical reasoning, which may have undermined Einstein's arguments regarding the uncertainty principle.
  • Others argue that the disagreement between Bohr and Einstein is more nuanced, involving deeper philosophical differences between realism and the Copenhagen interpretation, rather than just classical versus quantum reasoning.
  • A participant notes that Bohr's responses relied on the macroscopic object obeying quantum theory, indicating a complex interplay of classical and quantum ideas.
  • One participant expresses skepticism about the characterization of Einstein's understanding of quantum mechanics, suggesting that Einstein was not as ignorant as implied and that Bohr's acceptance of classical concepts used by Einstein is puzzling.
  • Another participant highlights that the debate was fundamentally about differing philosophical views rather than merely the use of classical concepts, indicating that addressing classical reasoning would not have resolved the underlying issues.
Participants do not reach a consensus on why Bohr did not directly challenge Einstein's classical reasoning. Multiple competing views remain regarding the nature of their debate and the implications of classical concepts in quantum mechanics.
Some participants mention the historical context of the debates and the philosophical positions of Bohr and Einstein, including realism and positivism, but these aspects remain unresolved and are subject to interpretation.
  • #31
I read this thread and get a tension vibe... just saying.
  • #32
mr. vodka said:
@ jambaugh: please read post 12! You're telling me nothing new and are mainly discussing things which I've explicitly told (by now) that this thread is not about.
IBYP, I'd missed your qualifications and edit as I was composing. I appreciate your desire to rein in the thread and prevent a devolution into debates of interpretation.
But you asked potential respondents to get into the head of Bohr (and by implication Einstein) with the form of your question and that does, absent your qualifiers, invite a broad range of speculation. Rereading I still am not clear what answers you are seeking.
It would be helpful if you further qualified what you understand as the alternative to "your using classical reasoning", though that again may open the interpretation can-o-worms.
One point w.r.t. conservation laws. Note that energy-momentum conservation is typically absolute in quantum interactions. One sees this in the mechanisms for producing entanglement, e.g. two quanta are entangled via anti-correlation of their momenta by exact measurement of their total momentum as zero. Typically this is done right before they interact in a way made uncertain by their imprecise positions (e.g. symmetric elastic scattering).
If one is invoking only statistical conservation then the entanglement doesn't occur and one only has classically statistical correlation of the subsequent measurements of the two components.
Uncertainties in the effect of an interaction arise (and this was the gist of Bohr's counter arguments to Einstein) due to (logically)a priori uncertainties in the constituents. To use Einstein's earlier thought experiments to violate UP he is, as Bohr points out, invoking a circular argument, you must first negate UP to disprove UP.
The EPR thought experiment, of course, moves beyond the issue of uncertainty in the state of the apparatus.
  • #33
One of Einstein's argument:
"Suppose two particles are set in motion towards each other with the same, very large, momentum, and that they interact with each other for a very short time when they pass at known positions.
Consider now an observer who gets hold of one of the particles, far away from the region of interaction, and measures its momentum; then, from the conditions of the experiment, he will obviously be able to deduce the momentum of the other particle. If, however, he chooses to measure the position of the first particle, he will be able to tell where the other particle is.
How can the final state of the second particle be influenced by a measurement performed on the first, after all physical interaction has ceased between them?"
He seems to make a lot of sense.
  • #34
Yes - but remember the hidden assumption - namely they actually have properties independent of measurement. If not you have strange correlations but influence is probably not the appropriate word.
Thanks
Bill
  • #35
Yes - but remember the hidden assumption - namely they actually have properties independent of measurement. If not you have strange correlations but influence is probably not the appropriate word. It is true QM probably has some sort of non locality inbuilt but it is rather a strange sort since it can not be used to send information.
Thanks
Bill
  • #36
mr. vodka said:
Hello,
We've all heard of the Bohr-Einstein debates to some degree (the essence of them being: Einstein tried to convince Bohr that the uncertainty principle is not true by claiming to have found concrete thought experiments that seemed to violate it). Bohr countered Einstein's arguments.
But what I don't understand is why Bohr not simply said "but you're using classical reasoning", since Einstein heavily depended on classical conservation laws, for example that of momentum. Okay conservation of momentum is still true for statistical averages in the QM formalism, but Einstein really used them classicaly: imagining one particle bouncing off a wall imparting momentum to the wall in such a way as to keep the total momentum fixed.
For example, if Bohr hadn't given the conclusive counter-arguments which he did (incidentally also using classical conservation laws), would others have accepted Einstein's reasoning? Or would they simply have countered with "yes but you're using a classical reasoning"? I think the latter. Hence I'm confused why Bohr didn't immediately answer with it.
NOTE: please don't reply with "the UP is merely a statistical statement that can be derived from the formalism and which talks about the standard deviations of the position and momentum distribution": I know this, but this is not in the least what the above question is about.
EDIT: some people apparently, for some reason, interpreted my OP as inviting general comments about Einstein's realistic view, which is not what this thread is about, every sentence I wrote down was supposed to be specific to the two thought-experiments Einstein brought forth in the Bohr-Einstein debates and are not with a greater generality than that. My question is simply why Bohr thought Einstein's reasoning using classical concepts such as conservation of momentum (not averaged) was a serious threat, saying things like "it would be the end of physics if Einstein were right" etc, although these concepts are not really part of quantum mechanics and so can hardly be used to derive a contradiction.
Well this is what Bohr thought: "Albert asked about a photon and a screen and a double slit screen, so my answer must contain a photon, a screen and a double slit screen. Now I just have to think what really happens to the photon, the screen and the double slit screen"
  • #37
Hello, I'm just replying to ask whether you've found out the answer for your question. I think even if Bohr had said "but you're using classical reasoning", it would not help his side of the argument very much. I'm not sure if you'll get this analogy but saying "but you're using classical reasoning" is like a laywer saying "but you're a thief" to a thief in a court. The lawyer and the thief both know that the thief if a thief but how will that help the lawyer prove that the lawyer is correct to the jury. In a similar sense, Bohr and Einstein both knew Einstein was using classical reasoning but how will that help Bohr prove that he is correct. I hope you get where I'm coming from but I'm not even in a University yet so I've probably said something wrong. If you have found a more reliable answer to your question as I am genuinely interested in finding out the answer.
  • #38
If I argue that A implies B. And you are arguing Not B then you need to point out that Not A is possible (since A implies B = B or Not A.)
"You're thinking classically" is saying that one is using implicit assumptions (A's) which should not be accepted a priori when "thinking quantum mechanically". Classical thinking is very difficult to unlearn as it is what we use in everyday experience (to good effect). It is analgous to the problem of thinking in terms of absolute time vs thinking (special) relativistically. It is counterintuitive until you systematically retrain your intuition. We have the advantage of being able to review Bohr's and Einstein's written thoughts while they had to struggle to understand a new paradigm.
[Edit, an additional comment.]
In your lawyer analogue, it is more like the prosecutor saying "your a convicted thief so your testimony is questionable" while the defense is pointing to evidence that the witness was in fact wrongly convicted and thus not a thief and so we should listen to what he has to say.
  • · Replies 52 ·
  • · Replies 204 ·
43K
  • · Replies 27 ·
  • · Replies 100 ·
12K
  • · Replies 82 ·
22K
  • · Replies 43 ·
10K
  • · Replies 18 ·
12K
