Dose E=hn means quantization of energy?
The discussion revolves around the equation E=nhf and its implications for the quantization of energy. Participants explore the relationship between energy, Planck's constant, and frequency, questioning the necessity of including frequency in the quantization equation.
  • Technical explanation, Conceptual clarification, Debate/contested
  • One participant questions why E=nhf is necessary, suggesting that E=nh alone should suffice.
  • Another participant explains that the units of the equation require a term with units of frequency to maintain dimensional consistency.
  • A third participant asserts that E=nh is incorrect due to unit discrepancies, reinforcing the need for frequency in the equation.
  • One participant notes that h represents energy per cycle and f represents cycles per unit time, implying that time quantization must be considered.
  • A later reply acknowledges the importance of units in the discussion.
  • Another participant introduces the idea that while energy is quantized within a single system, different systems can yield a continuous spectrum of energies, suggesting a broader context for the E=nh model.
Participants express differing views on the necessity of frequency in the quantization equation, with some agreeing on the importance of units while others maintain that E=nh could be sufficient. The discussion remains unresolved regarding the implications of these equations across different systems.
Participants highlight the importance of dimensional analysis in the equations discussed, indicating that assumptions about units and the nature of energy quantization may vary across different contexts.
athrun200
I have an example class yesterday, but one question troubled me.
In part (b), why does E=nhf?
For me, it seems E=nh is enough, why does the equation involve frequency f after quantization?
One answer might be: The unit of E (energy) is a Joule, the unit of h (Plank's constant) is Joule time a second. If you want the equation to be correct you need to multiply h with something that has units of 1 over a second.Roman.
What do you mean "E = nh is enough"? That equation is not correct, because as pointed out above, the units are not correct.
h = energy per cycle.
f = number of cycles per unit of time.
your quantization must include a quantization of time.
Thanks! I have forgotten to consider the unit.
Energy within a single system is quantized, but there are different energies that result from following the E=nh model in different systems, so if you consider every possible system energy is continuous, just like the light spectrum.
  • · Replies 78 ·
