Electric Field of extended mass
The discussion revolves around calculating the electric field at the origin due to a semicircular wire composed of two quarter-circle segments with opposite charges, +Q and -Q. Participants explore the integration process and the vector nature of the electric field, addressing potential errors in the calculations.
  • One participant outlines their approach to finding the electric field, using integration and charge density, but believes their solution is incorrect.
  • Another participant suggests that the integration limits should be from 0 to π/2 instead of 0 to π.
  • A later reply confirms that the electric field is a vector and emphasizes the need to consider both components in the calculation.
  • One participant expresses confusion about the mathematical expressions used and seeks clarification on the final equation.
  • Another participant provides a parametrization of the line charge and presents a formula for calculating the electric field, indicating a method to integrate over the two regions of charge.
  • Some participants acknowledge that their earlier calculations were incorrect due to errors in computation rather than the methodology.
There is no consensus on the correct approach to the problem, as participants express differing views on integration limits and the vector nature of the electric field. Some participants believe their results are correct, while others question the calculations.
Participants mention potential errors in integration limits and calculations, indicating that assumptions about charge distribution and vector components may not be fully resolved.
Redoctober
So here is the scenario (see attachment) - I have a semicircle wire (radius R=15.9cm) which is made of insulator material , the semicircle consist of two combined quartercircle wires parts where one has equally distributed charge +Q and the other has -Q . Required is find the Electric field in direction of x at the origin . Q=5.33nC
My approach was as follows
Let E = 1/(4*pi*e)∫1/(R^2).dQ r
dQ=λ*ds and ds=R*dθ and i also know that unit vector r = cosθ*i+sinθ*j
therefore for the E in x direction i get this expression
E = 1/(4*pi*e)*1/(R^2)*λ*R∫cosθ.dθ
Integrating from 0 to pi ( thus taking only half of the semicircle ) and using λ as 2/(pi*r)
I get Q/(2*pi^2*e*R^2) .
Because the other half has opposite charge i can say that the Etot = Eneg +Epos
Therefore i multiply the equation by two to finaly get
Q/(pi^2*e*R^2)
If i put the values given i get as absolute value 2413 N/C for Electric field at origin of circel in the direction of x
Unfortunately it is a wrong solution :( ! What is the mistake i hv done ?? Can anyone spot it ? Thanks in advance
Hi Redoctober! :smile:
Redoctober said:
Integrating from 0 to pi ( thus taking only half of the semicircle ) …
noooo :cry:
0 to π/2 :redface:
noooo :cry:
0 to π/2 :redface:
Oh ! srrry typo error :S :S , i integrated from 0 to pi/2 .
The answer 2413 N/C is wrong :/ !
Anyone has a solution ?? :/ !
The E field for the right part of your semi circle is given by
[tex]E = \int_0^{\frac{\pi}{2}} \frac{-Q}{4\pi\epsilon_0r^2} d\theta[/tex]
While the E field for the left part is the same but with +Q charge and integrated from [itex]\frac{\pi}{2}[/itex] to [itex]\pi[/itex]. Just add these two together to get the total field.
Are you sure? An electric field is a vector, and the correct formula is
[tex]\vec{E}(\vec{x})=\frac{1}{4 \pi \epsilon_0} \int_{\mathbb{R}^3} \rho(\vec{x}') \frac{\vec{x}-\vec{x}'}{|\vec{x}-\vec{x}'|^3}.[/tex]
Of course, in the here considered case, you have to integrate along the semicircle and use the charge per length instead of the bulk-charge density. However, you should check, whether you have all the geometrical factors for you vector component right.
Vanhees is right , Electric field is a vector .
So regarding the E will be in radial direction .
For the Y axis we need to consider the j component .
Vanhees , your mathematical expression is a bit high beyond my math skill xD !
My question is why the final expression for the problem is wrong :/
i considered the +Q and -Q E vector addition
I reached to the conclusion of
|E| = Q/(4*pi^2*e*r^2) (In the direction of J
Btw : how do u write the math expressions in that style xD . my way of typing the math is silly :/ !
The final equation i got was actually correct
i made an error with the calculation that's why my answer was wrong :)
Yes, I've checked your result too. It's correct. I parametrized the line charge with help of the charge per angle:
[tex]\lambda(\varphi)=\begin{cases}<br /> -\frac{2 Q}{\pi} & \text{for} \quad 0 \leq \varphi \leq \pi/2 \\<br /> +\frac{2Q}{\pi} & \text{for} \quad \pi/2<\varphi\leq \pi \\<br /> 0 & \text{elsewhere}.<br /> \end{cases}[/tex]
Then you can use my formula for [itex]\vec{x}=0[/itex] to get
[tex]\vec{E}=\frac{1}{4 \pi \epsilon_0 r^2} \int_0^{2 \pi} \mathrm{d} \varphi' \lambda(\varphi') \begin{pmatrix} -\cos \varphi' \\ -\sin \varphi' \\0 \end{pmatrix}.[/tex]
Integrating over the two regions gives finally
[tex]\vec{E}=\frac{Q}{\pi^2 \epsilon_0 r^2} \vec{e}_x.[/tex]
  • · Replies 29 ·
9K
