What's Wrong With Black Hole Thermodynamics?
juanrga
An interesting review of usual claims done in black hole literature by an expert in thermodynamics.
Can you reference the abstract rather than the PDF.
I've seen some other critical reviews of this. If I can find them, and they are in similar spirit, I'll post them here.
[EDIT: Here is the abstract link: http://arxiv.org/abs/1110.5322
http://adsabs.harvard.edu/abs/1980PhLA...78..219L "Entropies need not to be concave"
seems to be in some disagreement about one of the major premises of the author. I stumbled over this while trying to see if the original paper was peer reviewed - I see other peer reviewed papers by the author, but I haven't found that the arxiv paper was ever published. Unfortunately the published papers mostly seem to require subscriptions to access.
yea, well Hawking thought Beckenstein was wrong as well...until Hawking arrived at Beckenstein's answer using a completely different approach.
Besides:
Although Hawking's calculations gave further thermodynamic evidence for black hole entropy, until 1995 no one was able to make a controlled calculation of black hole entropy based on statistical mechanics, which associates entropy with a large number of microstates. In fact, so called "no hair"[7] theorems appeared to suggest that black holes could have only a single microstate. The situation changed in 1995 when Andrew Strominger and Cumrun Vafa calculated the right Bekenstein-Hawking entropy of a supersymmetric black hole in string theory, using methods based on D-branes. Their calculation was followed by many similar computations of entropy of large classes of other extremal and near-extremal black holes, and the result always agreed with the Bekenstein-Hawking formula.
http://en.wikipedia.org/wiki/Black_hole_thermodynamics
It would be fun, though, if the cited paper above added new insights...Anything there??
I also noticed that only a few of the early paper by this author were peer reviewed, but not this one. "Expert on Thermodynamics" seems a little overblown relative to the published history. But I didn't want to bring this up until I had tried to digest the paper for its content.
The word «entropy» is used with different meanings by many people; very often those meanings are not compatible with the well-established concept of thermodynamic entropy.
Curious, instead reviewing the work cited, people here goes on reviewing the author.
Well, he is a well-known expert in thermodynamics, their works are cited by other thermodynamicians and his book in thermodynamics of irreversible processes is published by Dover classics.
He has received Galilei Gold Medal 2009
For his work on irreversible thermodynamics and contributions to many areas of physics including that of Brownian motion, and in the establishment of the statistical basis of thermodynamics, and his contributions in astrophysics/cosmology.
And with a simple search in google scholar I can find
The thermodynamics of endoreversible engines
BH Lavenda - American Journal of Physics, 2007 - link.aip.org
Mean entropies
BH Lavenda - Open Systems & Information Dynamics, 2005 - Springer
High temperature properties of the MIT bag model
BH Lavenda - Journal of Physics G: Nuclear and Particle …, 2007 - iopscience.iop.org
It is difficult to believe that are not peer reviewed...
The paper seems to be gooble-gook. C_p is a derivative and can be be negative or non-existent. He does a lot of equations based on the behavior of classical ideal monatomic gases, which I suppose merely shows that black holes are not made of classical ideal monatomic gasses.
And I've known extremely brilliant people in one field that were cranks when they were in another one. Roger Penrose is an example. One thing about the author is that he seems to have no experience dealing with objects in which the gravity field makes a considerable contribution to the system, which is not good when you are dealing with black holes. He seems to miss completely the point about polytropes.
He might be brilliant in thermodynamics in other fields, but the arguments that he is giving in that paper seems to be total non-sense.
I may not be an "expert in thermodynamics" but I do know a thing or two about collapsed systems. His arguments make absolutely no sense because in any sort of stellar object, you are moving energy back and forth between the material object and the gravity field, and you can't just take an object and consider only the themodynamic energy. If you want to do your bookkeepping right, you have to consider the energy that is in the gravity field, which he doesn't do.
Since he isn't including the energy in the gravity field, all of his other arguments fall apart. If you include gravity, you get the results in the first section, which he doesn't seem to understand.
I note in the paper he also invokes a strong form of the 3rd law, \lim_{T\to 0}S = 0. This form ignores residual entropy due to a degenerate ground state. He is here ignoring degeneracy.
His reasoning may be implicitly the "no hair" theorem but that doesn't apply. The very debate, whether BH's evaporate, is a question of observing "internal" degrees of freedom in the configurations of emitted thermal radiation (here "internal" to the surface configuration?).
Reading the short paper, he is invoking analogue physical systems (partitioned volumes, ideal gasses) without any direct thought experiments about a BH per se. I don't see the paper pointing out any physical contradictions, only the exceptional behavior of BH thermodynamics.
C_p is not a mere derivative, but a physical quantity with determined properties. Your 'argument' could be re-used to say that (4) "is a derivative and can be be negative or non-existent", but it is difficult to believe someone would accept negative or non-existent mass for a black hole or an imaginary speed of light or similar nonsense...
Effectively, nowhere he says or even suggests that black holes are made of "classical ideal mono-atomic gasses". He uses the simple case of an ideal gas for illustrating the difference between c and C.
It is evident that this kind or argument can be inverted. People as Hawking, experienced in black holes and general relativity, can say nonsense when entering in the field of thermodynamics.
Even if we ignore now that «the energy that is in the gravity field» is not well-defined in general relativity, what you say about thermodynamic energy and gravitation seems to be without any basis.
Already many ordinary textbooks explain how gravitational energy M\phi contributes to thermodynamic energy. Of course, in a BH the situation is more complex and M\phi is not enough, but thermodynamics in presence of gravitation continues to hold and I fail to see your point.
juanrga said:
C_p is not a mere derivative, but a physical quantity with determined properties. Your 'argument' could be re-used to say that (4) "is a derivative and can be be negative or non-existent", but it is difficult to believe someone would accept negative mass for a black hole or imaginary speed of light or nonsense as that...
In the context of black holes and stars, it isn't. You add energy, the gravitational field rearranges itself and you get a different temperature. C is a quantity that includes both the effects of gravity and the physical characteristics of the object.
Effectively, nowhere he says or even suggests that black holes are made of "classical ideal monoatomic gasses". He uses the simple case of an ideal gas for illustrating the difference between c and C.
And in the current situation "c" is irrelevant. What matters is C.
And in the case of black holes the physical material gets crushed to a singularity in a finite time leaving behind only the gravitational field whose thermodynamic properties are not constrained by the limits that constrain physical objects. Black holes are dominated by the gravitational field so if you add energy, the field will reconfigure itself, and that's what you are observe.
The problem is that the author is used to laboratory thermodynamics in which you don't have to worry about the energy of the gravitational field, which works very badly when you figure out the thermodynamics of objects which are dominated by gravity. So in doing the energy calculations, he is completely ignoring gravity, which results in conclusions that are ridiculous.
I was said in my thermo course that residual entropies are the result of ignoring some interaction that breaks the degeneracy. I.e. that those degeneracies are fictitious. In any case I cannot see how substituting the strong form by the weak form \lim_{T\to 0}S = S_0 changes anything for BH thermo.
How do you adjust the 'exceptional behaviour' of evaporating BHs with the thermodynamic properties of the supposedly emitted thermal radiation?
If you confound internal energy with rest energy or with some other kind of energy then C can contain everything you want, but then better calls it X.
But as the author emphasizes C is not c. The non-numbered equation before (6) implies dE=CdT, but that is different from (7). Many people believes that C is the heat capacity, but for an open system dE ≠ dQ.
Not only it seems that you have not studied enough thermo, but you did not even read #12, where such claims were corrected.
This gets into definitional issues, but when astrophysicists talk about black holes and stars or whatever, they are indeed talking about C.
When you dump energy into a black hole or star, some of that energy goes into the gravitational field that effects the thermodynamics of the object. You can define a "heat capacity" based the interaction of the system to additional energy.
Also, a non-radiating star or black hole is a closed system.
And that "correction" is wrong. The basic problem I have with the entire paper is that he is using energy balance arguments. When you use energy balance arguments in astrophysical objects, you have to take into account the interaction of the gravity field. If you don't, then none of your results make any sense. Essentially, he writes an entire paper about black holes, and not once does he mention the word "gravity", and nowhere does anything approaching gravity enter into any equations.
If you can come up with an argument in which you can argue that it's possible to talk about black holes while ignoring gravity, I'd like to hear it.
Exactly. That's why argument to authority fails. In this situation, I think Hawking is right.
It's pretty simple. Gravitational potential energy makes up a substantial amount of energy in astrophysical objects. Hence arguments based on energy conservation that ignore interactions of the gravity field just don't work. If you introduce the gravity field, the situation that Hawking finds is pretty standard.
My point is that adding gravitation introduces additional terms into the energy equation, and once you introduce those terms, the arguments in the paper break down. The paper makes arguments that ignores the impact of gravity on the thermodynamic equations, and you just can't do that.
Gravity changes everything. Once you have a gravitational field, then adding or removing energy from the system will cause interactions with the gravitational field, and *that's* what gives you heat capacities that you don't see in non-self gravitating objects.
Black holes are not monoatomic ideal gasses. Because of self-gravitation, black holes are different enough so that you can't even use monoatomic ideal gasses as an analogy.
Of interest to discussion of entropy of self gravitating systems is the following essay. Of particular interest is the discussion of gravothermal catastrophe - that self gravitating systems really have no equilibrium point short of a black hole.
This essay is not relevant to the core question of the validity of Bekenstein-Hawking entropy. It takes that as a given, and argues that this is exceptional and not some natural limit of ordinary gravitational collapse processes.
http://philsci-archive.pitt.edu/4744/1/gravent_archive.pdf
I've been trying to think of a "thought experiment" that illustrates what happens so that we can argue about actual science rather than personalities.
Here's an attempt...
You have a satellite that is in orbit around the Earth in a distant orbit. Because it is in a distant orbit, it orbits slowly. Now you take energy away from the satellite. What happens to it? Well, because the satellite has less energy, it's going to start falling into earth. Once it gets to a lower orbit, it's going to orbit faster.
Now imagine a cloud of atomic sized satellites in orbit around the earth. You take energy away from them. They'll drop to lower orbits. Once they drop to lower orbits, they will move faster. If you measure the temperature of the cloud, you'll find that it has increased because faster atoms = higher temperature.
So if you have a self-gravitating object, pumping energy into the object will boost things into higher orbits which slows things down and makes things cooler. Taking energy out will put things into lower orbits which speeds things up and make things hotter. In other words the object has negative heat capacity.
What's wrong with this picture? (My answer is that nothing is wrong with this picture and this is exactly what happens).
Right, I completely agree.
Reading again stuff that was corrected before is one thing, but your claim that a black hole is a closed system is too nonsensical to continue.
The entropy of gas ideal is function of its internal energy Eint.
Its equation 5 reads E=K+U, but the thermodynamic expression in presence of fields is E=U+K+Eint.
The problems with your "thought experiment" already start here. What energy? The total energy is E=K+V+U, where K is kinetic energy, V is potential energy due to gravitational field and U is internal energy.
If I take away internal energy dU<0 (example via cooling the satellite), but maintain constant its mechanical energy (K+V), satellite will continue to orbit exactly in the same orbit.
If I take away kinetic energy dK<0 (example via decelerating the satellite), but maintain constant its internal energy (U), satellite will start falling into Earth... but this have nothing to see with thermodynamics or with negative heat capacities (indeed in this case Q=0).
In the context of discussion in that section, internal energy is held constant and can be ignored. For that section the author is explicitly treating the gas particles has incapable of changes of state. Later sections broaden that to discuss fusion and other process that do change internal energy.
For example, just a few lines before the equation you criticize is:
"Consider an ideal, uniform gas of
total energy E and kinetic energy K, containing N particles whose internal
degrees of freedom I will assume to be either nonexistent or irrelevant at the
system’s current temperatures,"
The internal degrees of freedom he is referring are essentially atomic/molecular variables (an example is molecular dipole orientation). This has nothing to see with the concept of internal energy Eint. The internal energy of an ideal gas is computed assuming that atoms/molecules do not have internal degrees of freedom.
The entropy of an ideal gas is a function S=S(U,V,N)
http://en.wikipedia.org/wiki/Sackur_Tetrode
Notice that internal energy is usually denoted by U and potential energy by V so that total energy is
E=K+V+U
The author that you cite use U for potential energy (although in a latter section uses U supposedly for internal energy, which he calls "some energy") and confounds internal energy with total energy.
If composition is constant and V=V(R) this reduces to S=S(U,R). He confounds internal energy with total energy, among other mistakes, and writes S(E,R).
One does not need to appeal to fusion to change the internal energy U of an ideal gas (and would be ridiculous because if exists fusion then the gas is NOT ideal).
Why? You can treat stars and black holes are something very close to closed thermodynamic systems. The only thing that makes them non-closed is radiation and 1) you can include radiative transfer in the book keeping, and 2) it doesn't make a huge difference. The total energy that is radiated at a given point is much, much smaller than the total internal energy.
Considering stars and black holes as something close to closed thermodynamic system is standard basic astrophysics. If you want something to be taken seriously by astrophysicists, and you think that this is ridiculous, you are going to have to argue the point since it's a standard approximation and a very good one.
There's also the issue of professional courtesy. I think part of the issue is that astrophysicists may be using terminology in ways that are different and perhaps bizarre to people in other areas of physics, but there are usually reasons behind this. If you go in with the attitude "you idiot astrophysicists don't understand anything about stars or self-gravitating objects" it's not going to end well nor should it.
And yes this works both ways... If a condensed matter physicist nicely e-mailed me a copy of that paper asking for feedback, and we were talking over lunch, I'd explain the flaws in a very nice way. The context is a paper posted to LANL, and once someone does that, I'm expecting that he wants it to be peer reviewed, at which point I go into "sadistic attack dog" mode, and rip it to shreds with strong language if I think the arguments are weak.
I can say with very strong certainty, that I'm making the points that anyone with astrophysics background would make, and that if his goal is to get the paper published in Ap.J., A.A., MNRNAS or Physics Review, that the reviewers are doing to toss it out with perhaps even stronger language that I've been using. If it tries to publish in some journal that is not astrophysics, what is likely to happen is that the editor will send the paper to someone with astrophysics background, and then they'll say the same thing.
Now if the author goes back, takes some of the points I've made seriously and tries to rewrite the paper, and then comes up with the same result, *that* would be interesting.
It has *everything* to do with thermodynamics and negative heat capacities. Once you have enough satellites, it becomes a gas, and once you have a gas, you can do thermodynamics on it. The system of Earth and satellites is a closed thermodynamic system and you can define temperatures and heat capacities.
This is all pretty standard stuff in astrophysics. It's also pretty important. Stars lose energy, and the heat capacity tells you what happens to the temperature of the star as it radiates. As stars radiate, the core temperatures increase which eventually causes fusion reactions that don't occur at lower temperatures.
If internal energy U of the satellite is held constant and only the mechanical energy (K+V) is varied, then you do not need thermodynamics, but only mechanics. Indeed, the laws of mechanics alone explains, perfectly, why the satteliite modifies its orbit and falles when you take away kinetic energy.
It is evident that you do not need thermodynamics for this. Gibbs and heat capacities are not even mentioned.
Taking an enough collection of satellites does not magically convert a mechanical problem into a thermodynamic one. Moreover, even assuming that the system of satellites can be considered a thermodynamic system, still there is none need to confound internal energy U with total energy E (including potential energy due to Earth) as done in previous posts. Similar remarks about stars.
The equation
\frac{\partial u}{\partial t} = c_V \frac{\partial T}{\partial t} + u_k \frac{\partial n_k}{\partial t}
in presence of field with potential \psi changes to
\frac{\partial u}{\partial t} = c_V \frac{\partial T}{\partial t} + (u_k + \tau_k \psi) \frac{\partial n_k}{\partial t}
with \tau_k the coupling factor. The heat capacity c_V is the same, in presence or absence of field, this is well-know, at least for thermodynamicians.
Of course if you want to confound rest energy with internal energy U and with total energy E, if you pretend that a black hole is a closed thermodynamic system, etc. then you can obtain anything that you want, but that is 'astrophysics', not thermodynamics.
OK. Suppose the satellite is a hydrogen atom, and you are trying to calculate the properties of a large number of "satellites". At this point, the kinetic energy of the satellites *becomes* the internal energy of gas of satellites.
There are several other ways of calculating this. You can use the virial theorem or the equipartition theorem. See
http://en.wikipedia.org/wiki/Equipartition_theorem
http://en.wikipedia.org/wiki/Virial_theorem
The thing about self-gravitating objects is that you *can't* separate mechanics and thermodynamics. Every thermodynamic equation in astrophysics has to include mechanical interactions.
Yes it does. You change those satellites into atoms and then have several gazillion of them. At which point you have a gas.
Except that you don't. You have the internal energy of the gas which consists of the kinetic energy of the gas molecules (H), and then the potential energy of the gravitational field (U). The relationship between the two are defined by the equipartition theorem and the virial theorem. Because the sign of the potential energy is negative, what happens is that as you remove total energy from the system, the kinetic/internal energy of the gas increases. (It's annoying here, because we are running out of letters.)
The virial theorem says that the internal energy is going to be -1/2 the potential energy. You can get a similar relationship through the equipartition.
This poses an interesting problem. If you just use classical mechanics, then you could in principle collapse the star to zero radius, and extract infinite energy which then violates all sorts of thermodynamic principles. What keeps this from happening is that if you collapse the star enough, it becomes a black hole that that sets a bound for the amount of energy you can extract. With some rather simple arguments you can convert those bounds into entropy bounds, which is what Hawking and Berkenstein have done.
the heat capacity is the same, as is well-known.
You are missing a term. The problem is that the field is not an external field but the result of self-interactions. What that means is that you have an extra \partial (\tau_k) / \partial t term which includes how the gravitational potential changes in response to external interactions.
This is off the top of my head so don't shoot me if there is a problem (and I'm getting confused with all of the letters meaning different things), but if you add energy into a gravitationally bound system then the \partial (\tau_k) / \partial t is going to be strongly positive which means that once you add that term then c_V is going to turn negative.
I'm not surprised that someone that isn't familiar with stars would make that mistake, since in laboratory experiments interacting with the system doesn't change the potential, but in self-gravitating systems, it does.
One other wrinkle is that hydrodynamics beats thermodynamics. A star takes a few minutes to reach hydrodynamic equilibrium, but several thousand years to reach thermodynamic equilibrium. Because of these time scale differences, the hydrodynamics drives the thermodynamics. What that means is that if you add energy to the system, the hydro will cause the change to happen immediately that create temperature gradients that cause the system to go out of general thermodynamic equilibrium.
So you start with an isothermal gas, and add energy to it. Rather than staying in thermodynamic equilibrium, the energy will get distributed hydrodynamically, which will throw the system out of thermo equilibrium.
Of course if you want to confound rest energy with internal energy U and with total energy E, if you pretend that a black hole is a closed thermodynamic system, etc. then you can obtain anything that you want.
No confusion. You have total energy which consists of internal energy + potential energy. Internal energy consists of kinetic energy of the gas molecules + internal degrees of freedom. Equipartition and virial theorems give you very simple relationships between these quantities. So once you have figured out the total energy, the virial theorem gives you the relationship between that and the internal energy and the potential energies.
I don't get the problem with considering a static black hole (or star) a closed thermodynamic system. It's just sitting there in empty space. The only thermodynamic interaction it has with the rest of the universe is radiation and you can add that to the bookkeeping.
And it turns out that you can mostly ignore the radiation when calculating stellar structure. The amount of energy that a star radiates over a year is an insignificant amount of the total internal energy. If you look at nuclear energy, the star can shine for billions of years, and if you look at gravitational energy, you get enough energy to shine for tens of millions. So if you are looking at the dynamics of a star over a day, you can consider the system to be adiabatic.
And you can't get anything you want. People (Chandrasekar) worked out how all of these things interact years ago, and it's in every first year astrophysics graduate text.
Again it's a problem of tone. If someone asked "it's very odd that self-gravitating bodies have negative heat capacity, why is that?" that's one thing. If the implied message is "astrophysicists are being obvious idiots for ignoring something stupidly obvious" that's not going to provoke a friendly reaction. Also, uploading a paper to LANL implies that you want people to tear it to shreds.
To summarize the special thermodynamic properties of astrophysical self-gravitating systems:
1) you cannot separate the mechanics from the thermodynamics. If you have a hydrogen gas in orbit around the earth, you have to take into account orbit mechanics in looking at the behavior of said gas.
2) you cannot treat external potentials as a constant addition to the thermo equations. Adding and removing energy from the system will change the interaction of the system with the field and that needs to be taken into account. Even if the field is constant (i.e. hydrogen atoms surround the earth) the fact that the atoms will wind up in different orbits means that you have to add extra terms in the thermo equations.
3) unlike laboratory systems, the hydrodynamic timescales of astrophysical systems are much smaller than the global thermodynamic time scales. This means that arguments based on global thermodynamic equilibrium will not work. If you have a isothermal laboratory system and add energy to it, you can expect the system to quickly move to isothermal. This isn't true with astrophysical systems where the thermal time scales are huge in comparison to the hydro scales, and also long in comparison to the observational time scale (i.e. the thermal time scale of stars are in the thousands of years). There are in fact astrophysical objects (white dwarfs) whose thermal equilibrium time is longer than the age of the universe. For stars you can assume local thermal equilibrium, but for atmospheres, even LTE is not true.
This means that if you dump energy into an astrophysical system that's in thermo equilibrium, it will quickly reach hydro equilibrium but that will drive it out of thermal equilibrium, which means that arguments based on thermal equilibrium won't work.
  • #31
No. If I assume that atoms can be treated classically as point-like particles then the thermodynamic internal energy of the gas of atoms is not the kinetic energy of the gas. The thermodynamic internal energy of a gas is defined as the total energy minus the average macroscopic kinetic energy.
From the wikipedia link:
In mechanics, the virial theorem provides a general equation relating the average over time of the total kinetic energy, \left\langle T \right\rangle, of a stable system consisting of N particles, bound by potential forces, with that of the total potential energy, \left\langle V_\text{TOT} \right\rangle, where angle brackets represent the average over time of the enclosed quantity.
But thermodynamics --which is not mechanics-- deals with internal energy, which is neither total kinetic energy nor total potential energy.
A gas is not defined as a N-collection of particles with N large. If you were right then virtually every macroscopic piece of matter would be a gas and is not :rolleyes:.
Using standard notation (i.e. letters)
E = U + K + V
In mechanics kinetic energy is often denoted by T, but in thermodynamics T is temperature and K is standard symbol for kinetic energy.
If you insist on confound internal energy U with kinetic energy K or with potential energy V, then you can obtain virtually any result. The sum (K+V) is usually named mechanical energy. This mechanical energy is what mechanics is interested in. This mechanical energy verifies virial theorem. Read again the vikipedia link that you give. Pay attention to the first two words.
Thermodynamics is usually interested in U: internal energy. Indeed, thermodynamic textbooks contains a chapter introducing the concept of internal energy and its main properties.
First, \tau_k is the coupling constant, not the gravitational potential.
Second, as is well-known, the thermodynamic expression
can be also rewritten as
\frac{\partial \tilde{u}}{\partial t} = c_V \frac{\partial T}{\partial t} + (u_k + \tau_k \psi) \frac{\partial n_k}{\partial t} + \tau_k \frac{\partial \psi}{\partial t}
using \tilde{u} = u + \tau_k \psi.
Of course the value of the heat capacity c_V is the same, because in the first case one takes partial derivative of internal energy u at constant composition and, in the second case, one takes the partial derivative of \tilde{u} but maintaining also constant \psi evidently.
It seems you are confused about what thermodynamics really is and does. It is well-known that thermodynamics extends the balance laws of hydrodynamics in many ways. For instance, the balance law for internal energy contains the heat flux q and the term \pi:\nabla v, where \pi, is the dissipative pressure tensor. q and \pi are non-hydrodynamical quantity, unless you want to reinvent hydrodynamics also :rolleyes:.
The total energy E of a gas is E = K + V + U, with K the total kinetic energy, V the total potential energy and U the internal energy. The virial theorem of mechanics (read the wikipedia link that you give) applies to K and V (unsurprisingly K+V is named the mechanical energy). The virial theorem does not apply to U.
If you insist on confounding thermodynamic quantities with mechanical quantities then you can obtain any bizarre result that you want even dS<0.
  • #32
Except that the kinetic energy in this situation is microscopic. I have a hydrogen atom. It goes in orbit around the earth. All of the gravitational rules apply so that if I remove energy from the atom, it will drop to a lower orbit and gain microscopic KE.
I drop a bag of hydrogen gas in high orbit. The net KE is zero, but the atoms in the gas have a KE that is from microscopic motions. The gas molecules go into random orbit around the earth. I suck energy from the molecules. They go into lower orbits. They are now moving faster, but the net KE is still zero.
And in astrophysical gases without internal modes, the microscopic kinetic energy is the internal energy. We aren't talking about the bulk flows, but rather than microphysics. The point is that gravity will change the thermodynamic properties of a fluid. Gravity doesn't know whether it is working on an apple or a hydrogen atom so it has to couple with the kinetic energy. You drop a hydrogen atom, it will go into an elliptical orbit until something stops it.
You can't separate mechanics and thermodynamics when you have a gravitational field.
And you can't separate the kinetic properties of a gas from the internal energy when you are dealing with astrophysical fluids. You can ignore this in lab experiments, but you can't when you add gravity. This causes all of the formula to be slightly different.
And you can't do this with self-gravitating fluids. What happens is that the internal kinetic energy of the gas changes the potential via the virial theorem. You keep insisting that you can separate out the "internal energy" from the "kinetic energy" but you can't, since the virial theorem doesn't only apply to the *macroscopic kinetic energy* but rather also to the *microscopic kinetic energy* of the gas that comprises the internal energy of gases. (Again, solids are different.)
Gravity applies to all motions. It doesn't know whether the object that is dropping is an apple or a hydrogen atom. So the virial theorem includes not only the *macroscopic* kinetic energy, but also the *microscopic* kinetic energy.
I'm just telling you how things are done in astrophysics. In astrophysics, there isn't a strong boundary between the microscopic motions and the macroscopic ones, and hydrodynamics interacts with the thermodynamics.
This is all very standard stuff. In the laboratory, you can make the distinction between "kinetic energy" and "internal energy". In astrophysics the distinction is much less sharp.
Yes it does. Look at the derivation of the virial theorem. All it involves are self-gravitating particles. Those particles don't have to be macroscopic. Hydrogen atoms will do. Once you have hydrogen atom as the self-gravitating bits, then the virial theorem applies to the microscopic kinetic energy of the atoms and hence to the internal energy.
Here is another thought experiment. You have to clouds of gas. You say that the virial theorem applies to bulk motions, so you can calculate the gravitational potential. Now you collide the clouds to that the bulk kinetic energy energy goes to zero, and the bulk kinetic energy goes into heat, so the bulk motions disappear, so bulk kinetic energy is now zero.
If your interpretation was correct then the gravity would just disappear. But it doesn't. The reason it doesn't is that the virial theorem applies both to macroscopic KE and microscopic internal energy.
This is very basic astrophysics.
Blame God. I didn't make the rules. And it turns out that you can't obtain any bizarre result. Everything works out so that energy is conserved and entropy increases. Somehow the rules work out so that happens.
Once you have self-gravitating objects then mechanics changes the microphysics which changes the thermodynamics. Gravity works on individual hydrogen atoms, which means that the virial theorem must include the microscopic kinetic motions of atoms.
But somehow the bookkeepping works out so that dS > 0 in closed systems.
  • #33
Also one has to be careful about the bookkeepping. In the case of mono-atomic ideal gases, all of the internal energy is in the form of kinetic motions, and so it's subject to the virial theorem. This is less true for gases with internal degrees of freedom, and not true at all for condensed matter. So you not only have to include internal energy, but you have to look at the form of the internal energy.
  • #34
Also if you insist that the virial theorem doesn't apply to thermal internal energy, you not only have to argue with me, but also with...
http://web.njit.edu/~gary/321/Lecture8.html
http://www.astro.utoronto.ca/~mhvk/AST221/L6/L6_4.pdf
http://burro.astr.cwru.edu/Academics/Astr221/LifeCycle/jeans.html
http://www2.astro.psu.edu/users/rbc/a534/lec10.pdf
http://www.vikdhillon.staff.shef.ac.uk/teaching/phy213/phy213_virial.html
https://casper.berkeley.edu/astrobaki/index.php/Virial_Theorem
http://www.jb.man.ac.uk/~smao/starHtml/stellarEquation.pdf
http://www.astro.gla.ac.uk/users/lyndsay/TEACHING/STELLAR/SSE3_05b.pdf
http://jila.colorado.edu/~pja/astr3730/lecture15.pdf
http://www.astro.caltech.edu/~jrv/Ay20/ws/ws_stellarstructure.pdf
whew... That's only after about five minutes of searching on the web. If you want book citations, and I can get you several of those.
  • #35
You understood nothing.
  • #36
Sure that you can find a hundred of 'astrophysics' references claiming that dA>0 (often named second law of black hole mechanics) was a fundamental law of nature... except that was based in a flawed analogy with real thermodynamics.
If thermodynamics had been studied, and different kind of energies had not been confused, then those hundred of authors had understood that dA<0 was perfectly possible and that their so-named fundamental law (the black hole analogue of the second law of thermodynamics they said to us) was only smoke :rolleyes:.
Already taking a look to the first reference, one can find many basic mistakes. The author (astrophysicist?) does not even know what equilibrium is, or more correctly, he confounds the concept of mechanical equilibrium with the concept of thermodynamical equilibrium.
I repeat, by confounding well-understood thermodynamic stuff you can obtain anything that you want, negative or even imaginary heat capacities... all is possible.
  • #37
Is anyone else reading this? I don't think I can convince you, but if someone else is reading this, they might be learning some astrophysics, so it's useful. If no one else is following this thread, then it's a waste of my time.
No people aren't confusing mechanical equilibrium with thermodynamic equilibrium.
What happens is that in astrophysical situations, the time scales for hydrodynamic equilibrium are considerable smaller than the thermodynamic equilibrium timescales. Typically in a star, time it takes to reach hydro equilibrium is in minutes, whereas it takes several thousand of years to reach thermo equlibrium. Therefore in modelling stars, thermodynamic equilibrium *is an incorrect assumption*, and the dynamics is driven by hydro rather than by thermo. You can assume (at least in stars) assume *local* thermo equilibrium, which allows you to use equations of state, but that's it, and that's not even true when you are talking about stellar atmospheres which are wildly out of equilibrium.
Because of time scales, you can't take thermo equations and add potentials. You have to start with hydro equations, then add in local thermo equilibrium. Stars are wildly out of thermo equilibrium because gravity pushes them out of thermo equlibrium. If they were in thermo equilibrium, the sun wouldn't shine.
Because gravity affects the behavior of atoms, you often have to rederive the equations from the atomic level using statistical mechanics. Gravity fundamentally changes the thermo behavior of gasses, so that you have to think about things at the atomic level. Equations and relationships that work in the laboratory, just don't work in self-gravitating systems.
This is important for stars. If you dump energy into ordinary gas, it will just expand. Gravity changes the thermo properties of gases so that if you dump energy into them, they will contract. This means that the extra energy has to go somewhere, which is why stars shine. If gravity *didn't* change the thermo property of gases, then stars would not exist.
You keep saying that, but it's not true. You can derive the laws of thermodynamics from statistical mechanics, so once you have to rederive the equations from basic principles, those statistical rules still hold, so that you can't get anything. So when you rewrite all of the equations to take into account of gravity, you end up with different equations, but the statistical microphysics makes sure that energy is conserved, entropy increases, and entropy goes to zero as T->0.
You keep saying that people don't understand themodynamics, but personally I think people understand it a lot better than you do. You just can't take equations out of a book and assume they are universally true. You have to understand the *principles* behind those equations, and in stars, they are very different than what you see in the laboratory, and you can get weird stuff.
If you are not willing to learn, then there is no point in me teaching it to you, but if anyone else is interested, I'll keep talking.
  • #38
Pardon the long delay in replying I'm behind grading papers.
The assertion that there exists some ignored interaction is ad hoc and not part of the theory. It is most especially invalid in the BH case. Where it makes a difference is that with a BH the entropy is increasing with decreasing temperature. Not a violation of 3rd law if you allow it to increase to a "constant" (diverge to infinity) rather than require it be zero.
The zero value clearly ignores entropy of mixing. Yes you can resolve that by asserting the system has a boundary breaking spatial symmetry and so some mixtures have higher energy than others but that's just the thing about a black hole. Its interior has no spatial boundary. The event horizon and the singularity are null surfaces.
No adjustment is needed. You can have a BH in thermal equilibrium with its environment. [BIG box with black hole and thermal photon gas] Inject energy into the system and the system will reach a new higher entropy equilibrium with a larger black hole and a colder environment.
I spent some time this weekend seeing if I could integrate the exterior volume to replicate some quantitative figures but its a busy time in the semester and I have other pressing priorities. If I have time and come up with anything worth posting I will.
The most exceptional aspect of a BH is that it must reach infinite size to achieve zero temperature. This is not outside the practical meaning of the 3rd law which is that absolute zero is an asymptotic limit one cannot achieve via finite processes.
If the Bekenstein-Hawking formula is wrong then one should be able to generate a contradiction via some though experiment. I see nothing like this in the OP reference.
  • #39
The EH is null but the r = 0 singularity (for a Schwarzschild BH) is spacelike. It's true that neither of them are a "spatial boundary"; a spatial boundary would have to have a timelike component (more precisely, it would have to be a family of timelike worldlines, one for each point of the boundary).
  • #40
I've been following with interest, but for me you (Twofish-quant) don't need to add anything. I've reading through references you've already provided.
  • #41
His confusion has nothing to see with time scales.
  • #42
This does not make sense. Take your example with satellite. Take away energy and satellite goes into lower orbit (system contracts), put energy into the system and satellite goes into higher orbit (system expands).
It seems that your misunderstanding starts here:
Solution to this problem is simple. Energy that you can extract from gravitationally collapsing system is limited by mass of the system. As system is collapsing it develops bigger and bigger mass defect and this mass defect can not exceed initial mass.
So basically you can ignore gravity in thermodynamical treatment of selfgravitating object because the only thing it does is rearranges structure of energy inside object.
  • #43
String theorists need to invoke such tricks as a five-dimensional space to adjust the cubic T-dependence of entropy of radiation with the quadratic T-dependence of the BH entropy.
  • #44
As I recall, all the degeneracies are shown to vanish, when more realistic interaction models are considered. That is why Planck stated the third law in that precise form: \lim_{T\to 0}S = 0.
Moreover, I do not agree on that the BH model is not ignoring interactions. For instance, the GR model is clearly ignoring the self-interaction of the graviton field.
The real problem here is not that Planck third law of thermo is violated in BHs, but that no generalized third law as \lim_{T\to 0}S_{gen} = 0 exists for S_{gen} = S + S_{BH}.
Similarly, there is not generalized zeroth law in BH 'thermodynamics', because of the area law (as the OP article remarks).
The only generalized law in BH 'thermodynamics' is the GSL (Generalized Second Law) \Delta S_{gen} \geq 0. But even in this I have my doubts, because for an evaporating BH \Delta S_{BH} \leq 0, which means that evaporation cannot be considered a dissipative process at the BH level!
  • #45
Exactly, so if you take away energy from a gas, then the system contracts and gets hotter. Put in energy and the system expands and gets cooler. If you take away energy, you are adding to the internal energy, but this comes from the potential energy that you lose by contracting the system.
No. Mass doesn't change. System gets smaller and denser. Now if you could collapse a system to point, then you would have a big problem since you would be able to extract infinite energy from a gravitationally bound system.
But somehow nature creates these darn black holes that keep us from doing that.
So basically you can ignore gravity in thermodynamical treatment of self gravitating object because the only thing it does is rearranges structure of energy inside object.
But we are talking about the energy structure.
  • #46
Conversely if you assume that black holes are not thermodynamic objects, then it's trivially easy to generate contradictions.
If you assume that naked singularities can exist, then it's trivial to violate the first law of thermodynamics.
If you assume that black holes don't have entropy, then it's trivial to violate the second law of thermodynamics. You just use the black hole as a vacuum to dump waste heat, and it's not hard to make a perpetual motion machine.
  • #47
Sorry but it still does not make sense. Basically you are saying that "if you take away energy you are adding energy". That is contradictory statement.
Let's say it differently. System is loosing energy to environment (energy is crossing some closed surface around the body that we consider border between the system and environment). When this happens system gets hotter. Mechanism how it gets hotter is internal to system and is not related to anything additional crossing that border between system and environment. Do you agree so far?
How do you argument that mass doesn't change?
From my side argumentation for change of mass is that mass/energy of the system is conserved (E=mc^2) and so if some energy is crossing border between system and environment (closed arbitrary surface around the system) mass/energy of the system remaining inside the border gets smaller by the amount of energy that left the system.
That certainly works for microscopic systems and is experimentally confirmed (as I believe, I will check if you will doubt that) as mass defect.
  • #48
Energy is conserved. You have E = E_star + E_environment and then E_star = E_gravity + E_thermal
For our purposes E is constant. E_star goes down. E_thermal goes up but E_gravity goes down even more.
Well yes.
Rest mass is conserved and doesn't change.
  • #49
So it's E_gravity that should supply infinite energy, right?
Is it supposed to say something more than "Mass doesn't change"?
Here is what wikipedia says in binding energy:
"In bound systems, if the binding energy is removed from the system, it must be subtracted from the mass of the unbound system, simply because this energy has mass, and if subtracted from the system at the time it is bound, will result in removal of mass from the system.[5] System mass is not conserved in this process because the system is not closed during the binding process."
Reference 5 turns out to be hyperphysics page about nuclear binding energy.
But wikipedia page has reference to this (pay per view) article as well World Year of Physics: A direct test of E=mc2
