Can Quantum Mechanics Explain True Randomness?
The discussion revolves around the concept of true randomness in the context of quantum mechanics, exploring the relationship between randomness, causality, and determinism. Participants examine whether quantum mechanics can provide a framework for understanding randomness and its implications in both theoretical and practical contexts.
  • One participant expresses skepticism about the existence of true randomness, comparing it to myths like Santa Claus and questioning its compatibility with causality.
  • Another participant argues that randomness and causality are not opposed, suggesting that random events can still have causal relationships.
  • A different viewpoint emphasizes that randomness may stem from a lack of information about underlying causes, proposing that this perspective is fundamental to scientific inquiry.
  • Participants discuss the role of random number generators (RNGs) as deterministic processes that can produce unpredictable outcomes due to insufficient information about their initial conditions.
  • One participant introduces the idea that quantum mechanics may be approached similarly, positing that the wave function could represent a blend of physical reality and our knowledge of it.
  • References to Quantum Information and Bell's theorem are made, indicating that quantum randomness cannot be replicated by classical systems, which may challenge existing perspectives on randomness.
  • There is a suggestion that quantum computing could lead to new insights into the nature of randomness, as it involves states of quantum systems.
Participants do not reach a consensus, as there are multiple competing views regarding the nature of randomness, causality, and the implications of quantum mechanics. The discussion remains unresolved with differing interpretations of these concepts.
Participants acknowledge limitations in understanding randomness, particularly in relation to information theory and the foundational aspects of quantum mechanics. The discussion highlights the complexity of defining causality and determinism in the context of randomness.
jadrian
not to be impolite, but i truly view randomness in reality as something you can trick your kids into accepting along with santa, the tooth fairy etc.
when compared to causality the idea of true randomness existing in reality seems incredibly weak to me.
is there any simple logic which can reconcile the two?
Are you calling the foundations of quantum theory incredibly weak?
Randomness and causality are not really opposed to each other. Perhaps randomness and determinacy are, but not really causality. Things can be random and still cause other things to happen. Can you explain in more detail what you mean?
i don't think you followed. random, is what we call something when we have no idea of its cause. so by your example that things can be random and still cause other things to happen, you will ultimately have to trace it back to its original cause which by randomness has no cause, so all following events will be random.
also i don't know how you can distinguish causality from determinism. determinism is a direct result of causality.
jadrian,
You could have some insight by some readings about "random number generators" (rng).
You have very likely used -knowinggly or not- a random number generator.
An rng follows a perfectly deterministic process.
However, you might not know what this process (algorithm) is.
Furthermore, if you knew the algorithm you might still not be able to predict the result of the rng, simply because you may lack information about the initial value or the key that was used, or anything else.
In summary, you will quickly realize that randomness can often be related to a lack of information. This lack of information should not be seen as a failure of science. Nor should it be seen as a cheap story to hide difficulties. Recognizing properly the lack of information and its role in our analysis of the world is, on the contrary, I believe, a pillar of science.
I would even not be surprised that the whole quantum mechanics could also be approached in this way. It has already be hypothesed that the "wave function" is not a "real" physical object, but instead a mix of physical reality and of the information we have on this reality.
Only kids may learn more on this, for they have less prejudices.
lalbatros said:
jadrian,
what you just said doesn't disagree with any of my beliefs. could you explain ur lastparagraph further tho, its interesting.
Quantum Information is a hot topic today, as you know.
There are hundreds of books and maybe millions of paper published on this topic.
You may easily find references on Amazon that could suit your mindset.
Do not forget to read about Bell's theorem and Alain Aspect experiment.
This might shake deeply your POV on randomness, as these imply that quantum randomness cannot be reproduced by a classic system (and therefore also not by a "classic' rng).
Quantum computing may look like a 'technical application' of quantum mechanics.
I think it is much more than that.
I strongly believe that this field will come with new deep insight in physics and into the understanding of "randomness". After all, states of a "quantum computer" are just states of a quantum system.
  • · Replies 55 ·
9K
  • · Replies 28 ·
  • · Replies 27 ·
  • · Replies 204 ·
14K
  • · Replies 25 ·
