Dale
Mentor
- 36,903
- 15,884
Perhaps it would help to talk a little about the curved geometry of this situation.
If we consider a spherical coordinate system centered on the sun then we can fix r to be the Earth orbital radius and we can fix the azimuthal angle to be in the orbital plane. That leaves only the orbital angle and time. So we have reduced the problem from 4 dimensions down to 2 dimensions and we can consider curved 2D surfaces embedded in a non-physical flat 3D embedding space which would accurately represent the geometry of the situation.
So, our space is essentially a cylinder, and if there were no spacetime curvature then the cylinder would be flat, meaning that you could cut it and lay it out on a table smoothly without any bumps. However, there is spacetime curvature, specifically, there is a little "dent" on the cylinder which goes around the cylinder in a helical pattern.
Now, suppose we draw a vertical line along the cylinder and we measure the length of the path around the cylinder down in the bottom of the helical dent and the length of the path up on the top edge of the helical dent from one intersection with the line to the next.
We will find that those lengths are slightly different. This is not because our measuring device is different from the top to the bottom of the dent, nor that the laws of physics are different, but simply because we are measuring the length of a different path. Due to the curvature of the space the lengths are different even though in the original 4D space the paths have the same radius.
This is why understanding the concept of curved spacetime is essential to understanding gravity and how it can be represented in a self-consistent, non-contradictory manner. It becomes very difficult to describe verbally, and that is why the math is important.
