Density vs Mass: Does Lower Density Mean Lighter?
  • Thread starter Thread starter Notwen7
    Density Mass
The discussion centers around the relationship between density and mass, specifically whether lower density implies a lighter object. Participants explore concepts related to density, mass, and weight, with a focus on how these properties interact in different materials and contexts.
  • Exploratory, Technical explanation, Conceptual clarification, Debate/contested
  • One participant questions the assumption that lower density means an object is lighter, suggesting that a larger density indicates a heavier material due to a more compact lattice structure.
  • Another participant presents a comparative example of a penny and a tank truck full of water, noting that mass is determined by both density and volume.
  • A participant clarifies that when comparing two different chemicals of the same volume, the one with the higher density will be heavier.
  • Further clarification is provided that mass and weight are proportional, indicating that in a consistent gravitational field, the object with greater mass will also have greater weight.
Participants express varying views on the relationship between density, mass, and weight, with some agreeing on the proportionality of mass and weight while others explore different scenarios that complicate the relationship. No consensus is reached on the initial question regarding density and lightness.
Some assumptions regarding the context of density comparisons and the specific conditions under which mass and weight are evaluated remain unresolved.
Notwen7
Does lower density usually mean the material is lighter? I went through high school believing that an object with a larger molar mass is a larger object. However, doesn't a larger density mean that material in use is heavier since it have a more compact lattice structure?
Chemistry news on Phys.org
Which is heavier, a penny (density = 9 g/cm^3) or a tank truck full of water (density = 1 g/cm^3)? Mass = density * volume, so the mass depends on the density and the size.
Sorry I should have been more clear. If you have two different chemicals in the same volume with different densities then the one with the highest density will be heavier.
Thank you for your help.
Yes. Mass and weight are proportional to one another. If two objects are in basically the same location ie on earth, then whichever has the larger mass has a higher weight.
  • · Replies 17 ·
  • · Replies 16 ·
  • · Replies 21 ·
  • · Replies 27 ·
  • · Replies 25 ·
