MSc particle physics revision question - angle of muon from pion decay
The discussion focuses on calculating the angle of a muon resulting from the decay of a pion, specifically the equation tanθ = (1 - mμ2 / mπ2) / (2βγ2). The user explores energy and momentum conservation principles using four-vectors, leading to the conclusion that the decay products' momenta must be analyzed to determine the muon's angle. The methodology emphasizes the importance of rearranging equations to simplify calculations, particularly leveraging the orthogonality of the neutrino and pion momenta.
  • Understanding of particle physics, specifically pion and muon decay processes.
  • Familiarity with four-vector notation and its application in relativistic physics.
  • Knowledge of energy and momentum conservation laws in particle interactions.
  • Proficiency in algebraic manipulation of physical equations.
  • Study the derivation of four-momentum conservation in particle decay scenarios.
  • Learn about the implications of massless particles, specifically neutrinos, in decay processes.
  • Research advanced techniques in relativistic kinematics, focusing on decay angle calculations.
  • Explore practical applications of these principles in experimental particle physics.
Graduate students in physics, researchers in particle physics, and anyone studying the dynamics of particle decay processes will benefit from this discussion.
BJD
I am trying to revise for PhD, going over MSc work. Could anyone help me with this question?
A pion traveling at speed β(=v/c) decays into a muon and a neutrino, π→μ + [itex]\nu[/itex]. If the neutrino emerges at 90° to the original pion direction at what angle does the muon come off?
[ Answer: tanθ = ( 1 - m[itex]_{\mu}[/itex][itex]^{2}[/itex] / m[itex]_{\pi}[/itex][itex]^{2}[/itex] ) / ( 2βγ[itex]^{2}[/itex] ) ]
→ using particle physics (pp) units:
E[itex]_{\pi}[/itex] = E[itex]_{\mu}[/itex] + E[itex]_{\nu}[/itex] → energy conservation.
[itex]\bar{p_{\pi}}[/itex] = [itex]\bar{p_{\mu}}[/itex] + [itex]\bar{p_{\nu}}[/itex] → momentum conservation. (3 vector)
βγm[itex]_{\pi}[/itex] = |[itex]\bar{p_{\pi}}[/itex]| (speed of light c not included as pp units)
invariant mass squared from decay of the moving pion: m[itex]_{\pi}[/itex][itex]^{2}[/itex] = ( E[itex]_{\mu}[/itex] + E[itex]_{\nu}[/itex] )[itex]^{2}[/itex] - ( [itex]\bar{p_{\mu}}[/itex] + [itex]\bar{p_{\nu}}[/itex] )[itex]^{2}[/itex]
→m[itex]_{\pi}[/itex][itex]^{2}[/itex] = E[itex]_{\mu}[/itex][itex]^{2}[/itex] + E[itex]_{\nu}[/itex][itex]^{2}[/itex] + 2E[itex]_{\mu}[/itex]E[itex]_{\nu}[/itex] - { [itex]\bar{p_{\mu}}[/itex][itex]^{2}[/itex] + [itex]\bar{p_{\nu}}[/itex][itex]^{2}[/itex] + 2[itex]\bar{p_{\mu}}[/itex][itex]\cdot[/itex][itex]\bar{p_{\nu}}[/itex]}
substituting ( m[itex]^{2}[/itex] = E[itex]^{2}[/itex] - p[itex]^{2}[/itex] ) into:
→m[itex]_{\pi}[/itex][itex]^{2}[/itex] = E[itex]_{\mu}[/itex][itex]^{2}[/itex] - p[itex]_{\mu}[/itex][itex]^{2}[/itex] + E[itex]_{\nu}[/itex][itex]^{2}[/itex] - p[itex]_{\nu}[/itex][itex]^{2}[/itex] + 2E[itex]_{\mu}[/itex]E[itex]_{\nu}[/itex] - 2|[itex]\bar{p_{\mu}}[/itex]||[itex]\bar{p_{\nu}}[/itex]|cos ( 90°+θ )
gives:
→m[itex]_{\pi}[/itex][itex]^{2}[/itex] = m[itex]_{\mu}[/itex][itex]^{2}[/itex] + ( m[itex]_{\nu}[/itex][itex]^{2}[/itex] = 0 ) + 2E[itex]_{\mu}[/itex]E[itex]_{\nu}[/itex] - 2|[itex]\bar{p_{\mu}}[/itex]||[itex]\bar{p_{\nu}}[/itex]|( - sin (θ) ) (the mass of the neutrino is taken as zero here)
also as: cos (90+θ) = cos(90) cos(θ) - sin(90)sin(θ) = - sin (θ)
I got stuck a few lines after this, can anyone who understands this help? Am I on the right track with the methodology?
You'll find it more convenient to work with four-vectors. Let ##p_\pi^\alpha = (E_\pi, \vec{p}_\pi)##, ##p_\mu^\alpha = (E_\mu, \vec{p}_\mu)##, and ##p_\nu^\alpha = (E_\nu, \vec{p}_\nu)## be the four-momentum of the pion, muon, and antineutrino respectively, where ##\vec{p}## denotes three-momentum. Conservation of energy and momentum gives you
$$p_\pi^\alpha = p_\mu^\alpha + p_\nu^\alpha.$$ Squaring this yields
$$m_\pi^2 = m_\mu^2 + m_\nu^2 + 2p_\mu^\alpha {p_\nu}_\alpha = m_\mu^2 + m_\nu^2 + 2(E_\mu E_\nu - \vec{p}_\mu \cdot \vec{p}_\nu),$$ which is the same thing you got with a bit more algebra.
Often, the trick to these problems is to rearrange the original equation so that the product of the various four-vectors results in the conveniently placed zero. For example, you know that ##\vec{p}_\pi## and ##\vec{p}_\nu## are perpendicular to each other, so their dot product will vanish. This suggests you try squaring ##p_\pi^\alpha - p_\nu^\alpha = p_\mu^\alpha##.
Thank you vela
11K
